Old 07-06-2012, 10:42 PM   #1
Lower!
Default Manual Posted KX018E15 T-REX 700E DFC HV Super Combo V3
Hi Guys,
I posted a scan of the manual for the new 700E V3 on our website.
It is in 3 parts, we need a new scanner but it is not too bad.
Enjoy!
Ken
http://www.lowerheli.com/servlet/the...e/manuals/Page
LowerHeli.com
T-Rex Kits, Parts, and Upgrades
sales@lowerheli.com
"Fly Lower!"
Lower! is offline        Reply With Quote
Old 07-07-2012, 12:11 PM   #2
smaze17
Hey man thanks so much for the post bro! I was looking all over the internet for this yesterday
S
Trex 700e DFC / iKON / CC ICE2 120HV / Align 700MX
Trex 450L Dominator / iKON / RCE-BL45X / 460MX
smaze17 is offline        Reply With Quote
Old 07-07-2012, 01:08 PM   #3
msallua
smaze17, my 700 dfc hv combo is coming soon,
Can you give me some advice on how to power the unit 3GX? I have a 7.4v lipo 2s Align http://www.ronlund.com/rcheli-prod/E.../HBP19001.html
But this lipo comes with a JST connector
The kit comes with an adapter or I need to buy one?
How do you connect it?
Do you use power switch?
Align 800e PRO DFC // Align 700N DFC, 105HZ-R HV // Goblin 700Comp // Goblin 420 // Align 700E 3-Blade HV.// Futaba 14Sgh - RealFlight 7.5 // neXt - Powered by Pulse - IKON's // Castle ESC's
msallua is offline        Reply With Quote
Old 07-07-2012, 01:44 PM   #4
smaze17
Hi there. I personally will not be using the 3GX but my Beastx will be powered by a 2-cell lipo directly into the unit. Since we have HV servos we no longer need regulators....nice!!
I would recommend making a y-harness from the battery to the 3GX. This way you will have 2 leads coming from the battery which will distribute the power more evenly hence reducing the chance of a power "bottleneck" situation. At least this is how I understand it. Hopefully guys will chime in who have more knowledge and experience with regards to powering our FBL controllers properly
You could also get a simple switch that already has 2 leads coming from it. I have used this switch in the past and it worked great. You just plug your battery into it then plug the 2 leads coming from it to 2 open ports in your 3GX.
http://www.perfectregulators.com/ind...&product_id=82
S
Old 07-07-2012, 09:49 PM   #5
Lower!
We use the Castle BEC Pro up here to eliminate the hassle of charging the extra reciever battery - just set it to 8v and go. Been having very good luck with them when run on 6s (just one leg of the 12s pack in a 700E). I have some pics on our facebook page of the y-harness layout.
Definatly 2s lipo straight into the 3GX with dual wires works great too. I run that on my nitro.
LowerHeli.com
sales@lowerheli.com
"Fly Lower!"
Old 07-23-2012, 01:29 PM   #6
-Richard-
Thanks very much Ken, much appreciated. I see once again they haven't included part numbers
-Richard- is offline        Reply With Quote
Old 07-23-2012, 09:54 PM   #7
rcflyerheli
Making up a Y connector for the JST really doesn't solve your problem, as it is like a servo lead, and only rated for maybe 10 amps. I would just replace it with (I use Deans ultra) a higher amp female on the bat side, and parallel solder two heavy duty servo extensions to plug into your FBL or RX.
Goblin 700, Trex 700 V2, Trex 700DFC, Gaui X7, Logo 600SX, Logo 690SX, Forza 700
Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Team
Rep
rcflyerheli is offline        Reply With Quote
Old 09-08-2012, 03:41 AM   #8
trexfan
Smile trex 700 e hv combo
hi guys ,
havnt really posted anything before so new here im a bit concerned about all this talk about the 3gx setup and how it is suppose to be done,having said that im having my 700 built by helihobby so im sure they know what they are doing. but just for my sake and peace of mind would like to know how it should be set up and also has anyone had any troubles with the align system or the brushless servos.
thanks guys
justin
trexfan is offline        Reply With Quote
Old 09-08-2012, 12:24 PM   #9
backburner1955
I already posted the Full .pdf version of this very manual from Align's website in this thread. It much more clear and easy to read than a scan.
http://www.helifreak.com/showthread.php?t=448687
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Reply With Quote
Old 09-08-2012, 12:46 PM   #10
yonatan1
Default yeaa
Thank you!
I was looking for it,
Can't wait for mine!!
yonatan1 is offline        Reply With Quote
