Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Old 07-08-2012, 01:01 PM   #1
krauley
Default parallel charging question - help
simple question but i cant find the answer, when i am charging 4 packs using my 306b and a parallel charge board can i set the charger to just "charge" or does it need to be set to "balance charge"?
btw i just went from a 50w to this thing and its so much nicer to have a pack ready in 20 minutes or so compared to the hour+ im used to. i cant wait to get a decent PS.
EXI 500 DFC/3GX v3.1 ICE 75 Bec Pro
Align trex 500DFC Pro w/ 3GX v3.1
DX8 V2.06
krauley is offline        Reply With Quote
Old 07-08-2012, 01:19 PM   #2
SeanM
Always use balance charge.
- 6S TREX 450 Pro FBL - µBeast, MKS DS95 and 8910A+, DFC Head, CC ICE Lite 50, 450MX 1700kv
- Goblin 500 - Kontronik Pyro 600-12, HeliJive, iKon, MKS
- Spektrum DX7
SeanM is online now        Reply With Quote
Old 07-08-2012, 02:01 PM   #3
The WoodCrafter
I always balance charge no matter what.
But don't parallel charge new LiPo during break-in.
Charge them one at a time.
The WoodCrafter is offline        Reply With Quote
Old 07-08-2012, 10:26 PM   #4
krauley
alrighty guys thanks
now how about storage, one at a time or can i do that multi pack? im assuming the answer is no on that too but just gotta ask. i just got the 306b and was using a 4 port (4 in 1) multicharger so all this is new. i was able to do it all at once but of course it was like having 4 chargers going at once, although it was only 50 watts each.
DX8 V2.06
Old 07-08-2012, 10:39 PM   #5
The WoodCrafter
You CAN put them at storage voltage in parallel.
Always remember, When the packs are connected in parallel, it is ONE pack.
Voltage of each pack will always be the same no matter what.
Old 07-08-2012, 11:29 PM   #6
krauley
good to know thanks, im using a modded pc ps to run the 306b and its not really very fast at this point although its still better than the old charger. looking forward to upgrading to a good ps and having a good charge station.
DX8 V2.06
Old 07-08-2012, 11:48 PM   #7
The WoodCrafter
You can get surplus computer server power supplies pretty cheap off the internet.
Some under $10 each.
If you are handy with a soldering iron and can follow directions, they are very easy to convert.
The 306B needs 2 wired is series so you power the charge with 24V.
Old 07-12-2012, 07:50 AM   #8
R3L72
Question Parallel Charge Setup
With the 306B with a Parallel charging board, if I connect 4 3S 2200mAh Lipo's, do I need to input total mAh (8800) in to the 306B or does the 306B automatically calculate this?
I read the manual that comes on a disk with the iCharger but am looking for further clarification as I don't remember reading about it. Thanks!
CY NextD Rave 3D, MSH Mini Prôtos (6S) Stretch, Prôtos 500 Stretched
Blade 450X, 300X, 130X, mCPX, Nano, DX6i, DX8
Align Trex 450 V2 Pro DFC, & too many others to list...
...living the Hobby 4+ minutes at a time
R3L72 is online now        Reply With Quote
Old 07-12-2012, 08:21 AM   #9
The WoodCrafter
You need to tell it the rate you want to charge at.
Like 8.8AMPS for a 1C rate.
Old 07-12-2012, 10:12 AM   #10
R3L72
Thumbs up Thanks!
Thank You!
So for Parallel Charging 'total' mAh for the 306B is determined by Charging Rate e.g. 1C=2.2 Amps x 4, would be 8.8 Amps.
When I actually hook the Lipo's to the iCharger 306B, I'll better understand it and get use to it. I'm still 'breaking-in' some new Lipo's so I'm doing a solo charge on them for right now.
Old 07-12-2012, 11:43 AM   #11
krauley
306b manual pdf
http://www.progressiverc.com/media/i...B%20Manual.pdf
DX8 V2.06
Old 07-12-2012, 02:20 PM   #12
The WoodCrafter
Originally Posted by R3L72 View Post
Thank You!
I'm not sure what you are refering to when you say "Total mAh".
mAh is a measurement of amps over time. It is of measurement of how much power was moved.
Either into or out of you battery.
You do not tell the charger how much to put into the batteries.
You tell it the rate you want to charge at and the battery tells the charger when it has had enough.
These chargers wil back off the rate as the battery fills up.
Old 07-12-2012, 02:50 PM   #13
R3L72
Question
Okay, so with this charger, when I'm parallel charging (2ea) 3S 2200mAh Lipo's at a 1C rate, all I have to input is 4.4 Amps?
I can charge a single Lipo all day but now that I'm getting into parallel charging with the iCharger 306B, I just want to know that I'm not going to fubar anything with setting it up to charge parallel.
Old 07-12-2012, 05:13 PM   #14
aramb
You are correct - charging two 2200 mAh batteries in parallel requires you to set the 306b to 4.4 Amps for a 1C charge.
Megavolt 800, Trex 800e, Goblin 770, Fusion 50
Spektrum DX18 / AMA# 959345 / IRCHA #3954
Team Lynx Team HeliDirect
aramb is offline        Reply With Quote
Old 07-12-2012, 07:25 PM   #15
krauley
i dont know how much power you have for the 306b but if you can get 10amps to it then you can charge all 4 of those 3s 2200 packs at 1c
2200 or 2.2a X packs= 8.8amp so you would be charging all four at 1c and if you have the power then 17.6 amps would give you 2c. so to get 1c on all 4 you would need:
2.2a X 4 = 8.8a X 12.6v = 110.88watt power supply minimun and of course your gonna want have more. i think 20% or around a 150w. seems kind of low so maybe someone can confirm my math, maybe its the 3S packs and im used to 6S
DX8 V2.06
Old 07-12-2012, 08:04 PM   #16
The WoodCrafter
You got it right and yes, I'm used to 6S also.
Old 07-12-2012, 09:09 PM   #17
Allen_H
yes you do need to add up the mah and put it in the charger so if you have 4x 2200 you would set it to 8800 mah
Allen_H is online now        Reply With Quote
Old 07-12-2012, 09:25 PM   #18
The WoodCrafter
The charger doesn't work in mAh only AMPS, so he needs to put it in as 8.8AMPS.
And I think we covered that one.
Old 07-12-2012, 10:12 PM   #19
krauley
crap i was charging my 4 3300s when i got an alarm, 5000mAh over alarm. i wasnt thinking about this but im glad it happened, so if i put back in around 2640mAh which is 80% of these packs (although i rarely put back in more than 2200) thats 2640 X 6 = 15840mAh total. do i set my alarm for something around 16000, turn off the mAh over alarm or what are you guys doing for when you parallel multi packs?
DX8 V2.06
Old 07-12-2012, 10:23 PM   #20
pctomlin
The default "capacity cut-off" for the 306B is 5000 mah so it you are parallel charging multiple packs this value needs to be set higher in order to keep the charger from shutting down early. I have mine set at 30,000 mah since I could parallel charge six 6S 5000mah batteries at the same time. I left the time out value at the default 120 minutes.
Paul
Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G
Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G
Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188
pctomlin is offline        Reply With Quote
