Old 07-10-2012, 04:07 AM   #1
SJo1
Default My 4525 rewinding project
I got inspiration for this while a go, by reading HF and my local forum.
Got wires from elosal and insulation and varnish from brocott.
Knipex pliers from local hardwarehell for 26eur
Motip freeze spray from local garage
I took motor apart, cutted old wires away. Stator removing from end was pain as I used mounting points for pushing stator away turn by turn. In between stator and screws there was different height of hard metal pieces. maybe leaving wires to stator would left it to one piece. but any way stator is now 3 parts and those glassfiber end insulates needs to be re build for good.
Now question is, should I use cyanoacrylate for gluing stator lamelles or vernish and then use compression for whole stator pack?
Cheers
Sami
2x Kasama Srimok 90 FB & FBL | MA Stratus BW | Hirobo Turbulence D3 EX | Henseleit TDR 2011 HK4530 5+4 1.5YY SJo Power | JR Vibe 50 | MSH Protos | Futaba FGS 8
http://www.helifleet.com/SJo1
SJo1 is online now        Reply With Quote
Old 07-10-2012, 05:44 AM   #2
Heli G
I used ca for the stator insulation. Didn't find it nessecary to glue the insulation paper between the slots, worked fine as is once you get the hang of it. I'm also new to this so there may be better ways no doubt.
Heli G is offline        Reply With Quote
Old 07-11-2012, 12:31 AM   #3
SJo1
Thanks G
Still need to get confirmation for stator lamelles, how to fix or build stator core.
I read from one source that each lamel surface has insulation layer and that is for avoiding this eddy current?
Maybe slow cure CA or varnish or some green or red locktite.
I wish I could get help to choose right method to proceed forward with this stator core build / fix howto.
I have gone through powerditto pages translated by g00gle ger 2 eng.
There was this Laos 800 build started with stacking lamelles to tool and putting slotsstraight.
What after that, maybe thin ca that wick or capillarly penetrates in between layers?
Sami
Old 07-11-2012, 01:12 AM   #4
powercroco
this way was made, because these special plates havn't the little positioning points on the hammerstalks.
look here also:
http://www.croco.powerditto.de/crocopaketieren.html
by using the normal plates you dont need to glue them together.
only the endplates have to be glued.
http://www.powerditto.de/statorisolieren.html
after this you can hold the package together for winding by using a thin cord or copper wire around the hammers, you don't want to wind at this moment.
using YY scheme, you only need 4 free arms every time.
this method spares time and effort.
powercroco is offline        Reply With Quote
Old 07-11-2012, 02:40 AM   #5
SJo1
Thanks Powercroco,
Target is to wind this motor to 4525 Ultimate 5+6 YY or was that correct winding scheme?
I have 1.32, 1,4 & 1,5mm wires from Elosal.
Old 07-11-2012, 08:09 AM   #6
ZuvieleTeile
Depending (Ralph's favorite word) what your desired Kv is, the 5+6 YY is a good choice.
If it is your first wind, then you would maybe use a 1.32 or 1.4 mm wire.
1.25 would even be easier, but you don't have this wire available.
Contrary to Ralph's suggestion, I'd glue the stator together with CA.
Since it is your first one, it will be easier for you.
Just hold the stator together and put some CA on the places where it has been apart.
It'll pull itself in.
Kind Regards ZT - TDR, Logo-400SE
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote
Old 07-11-2012, 02:15 PM   #7
SJo1
Thank ZT,
Target is same 520 KV as 4525 Ultimate has.
I have fixed stator with thin CA under compression of 20*70 bolt with stator size spacers
I applied it all round then filed excess off with diamond file.
Next will be insulation glassfiber sheet filing to the ends.
Then winding begins with 1,4mm wire, if that look's good it will ne replaced with 1,5mm wire.
Old 07-15-2012, 08:53 AM   #8
SJo1
I got nice fiber glass pieces from one of my heli mate as He is doing custom windings too.
I managed to finish insulation filing and I'm pretty happy about result of it.
Then I found these flat jaw Knipex pliers and as a lazy guy while visiting step fathers workshop I managed finish several pliers in good time with perfect tools polished jaws doesn't leave marks to wire.
Next I need to start learning curve on world of winding.
Old 07-23-2012, 02:40 AM   #9
SJo1
I tried with 1,32mm wire and that was going well. I decied to start wrap 1,4mm wire from another point. It's going pretty well, so I removed those1,32mm wires and contnued with 1,4mm.
Now I have 1st stator started from inside 5 turns at bottom outside jump to 2nd stator winded in another 5 turns at bottom. Each stator slot have 1 wire out on top.
Do I need to add turns or was it fine for 4525 ultimate.
I recieved Megger from ebay and K2 kv/rpm/pwm meter from Aoerc
Sent from my GT-I9100 using Tapatalk 2
Old 07-23-2012, 05:15 AM   #10
Heli G
Ultimate is wound 5+6 for 520kv as per Scorpion specs. You need to count the wires inside the slots.
Old 07-23-2012, 10:10 AM   #11
ZuvieleTeile
For the desired Kv you might need to ad a turn, like Heli G mentioned.
Before you go any further, scrape the insulation off of the wire ends and test the group, you just wound, against the stator for continuity and/or do a 1000 Volt test.
Can you post a pic from the top and the bottom of the stator?
Old 07-23-2012, 03:39 PM   #12
SJo1
Ok, now I got it. From bottom view it is now 5 rounds from in to out jump's another stator out to in 5 rounds and for this last I'll add 1 round.
In case pliers slips and leaves mark to wire, would it be possible to fix this some other way than strip stator pair and rewound it?
Old 07-23-2012, 03:53 PM   #13
ZuvieleTeile
Yeah, just ad one turn for each group and you'll have 5+6 then.
For insulation/repairing some minor scratches like this, I am using the electrical varnish from Brocott, which you have. It needs a while to dry. Full cure in about 24 hours.
Old 07-23-2012, 04:06 PM   #14
SJo1
Thanks ZT
My progress is bit slow as I need watch over kid's too.
This is My last holiday week and wife has planned some amusement park visit for kids.
I'll hope it'll be ready by end of a week.
Old 07-24-2012, 11:12 AM   #15
HeliFX
I had posed this very same question several month back.
Regarding insulation wire repairs using heat resistant paint works just as well.
This was a recommendation directly from Ralph himself.
SJo1 my first motor took over a week to do but once you get one under your belt the process is much faster. 12N10P motor now takes me about 2 to 3hrs.
Making those nylon custom wedges demonstrated on Ralph site makes a world of difference with the process.
It avoids all the different wood wedges and toothpick
Using "Knipex" pliers when modified work very well to help stabilize and add equal linear pressure on the wire.
Standard needle nose pliers slip and nick your insulation when doing larger O.D. wires like 1.4 mm
HeliFX is offline        Reply With Quote
Old 07-25-2012, 12:09 AM   #16
powercroco
using the right tools is the half of the way.
but of course, to buy / make them, makes only sense, if you plan to build more than only one motor. otherwise the tools are more expensive than let make someone experienced the winding for you.
on the other hand, it's a uncompareable feeling to use an "own" motor.
and to use a really own motor (selfconstructed - including plate shape, magnetic circle and housing) is the very best feeeling.
ralph
Old 07-25-2012, 12:18 AM   #17
aviator493
ralph
Powercroco,
Do you offer motor winding services? I have a Scorpion 4530-540 that I want to rewind to a lower kv for a Goblin 770. I will be using either a Kosmik or YGE 160. I am open to anything that will create a lot of power! I also have a Scorpion 4035-500 Id like to get rewound possibly to! I did find your website, but will need to do some translating!
Thanks for any help you can provide!
Sent from my DROID RAZR using Tapatalk 2
aviator493 is online now        Reply With Quote
Old 07-25-2012, 01:41 PM   #18
powercroco
No - I have no commercial winding service for offer.
only sometimes (very seldom) I do very special (extreme) windings on the newest scorpion-prototypes for my charities - but very expensive.
but you can ask www.slowflyworld.de.
They wind for money evrything you want.
ralph
Old 07-25-2012, 04:02 PM   #19
NRPY
I believe Dekker and GMauro offer rewinding services too.
NRPY is offline        Reply With Quote
Old 07-25-2012, 05:11 PM   #20
aviator493
ralph
Ah ok, thanks for the info!
Tags
stator repair 4525
