Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 07-10-2012, 07:29 AM   #1
jchen
Default Fusuno Compass Atom 5.5
Hi Guys,
Thats how the Canopy looks like on the stretch Atom. Makes it look so much better
jchen is offline        Reply With Quote
Old 07-10-2012, 08:39 AM   #2
g2driver
Default Nice!
That canopy looks great!
Raj Patel
COP Global Aviation
Senior Intl Captain
Humble, TX
g2driver is offline        Reply With Quote
Old 07-10-2012, 08:44 AM   #3
jchen
This canopy is almost 6 HV size, in order to fit this canopy, requires a simple mod. Just swap the canopy post with the gyro plate bolt as shown in the photo & your done. At the same time you have to mark position of the rubber grommet & drill new holes. If you were
to order this canopy, tell Fusuno not to pre drill any holes, I told them not too but it came drilled. Worse of all nothing lines up & it's really badly done. This canopy is very flexible,
what Im gonna do to prevent high flexing which might misbehave in flight, Im gonna add rubber canopy support thats from an Align 550. Aside from this I've used 6HV tail fin but has to cut down a little due to height as well as 6HV Struts & Skids which were shorten by 2 inches to make the whole proposion of the heli look right. Last thing on the list is to
add boom support . Haven't found the correct lenght , might have to end up with a diy option. For guys thinking of 8S or 12s conversion, this is the way to go. I'm keeping it
6s but running 3700mah packes which balances the heli out nicely.
Name:	Atom DSC01004.jpg
Old 07-10-2012, 03:38 PM   #4
Magnazan
Looks awesome - you could almost mistake it for a 6hv.
6HV HC3-SX | Atom 500 HC3-Xtreme | MCPX Brushless | DSX9
Magnazan is offline        Reply With Quote
Old 07-10-2012, 03:40 PM   #5
Ah Clem
Beautiful!
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 07-10-2012, 04:08 PM   #6
maddog57
I like it...yes sir, i like it alot!
Chris
maddog57 is offline        Reply With Quote
Old 07-10-2012, 08:31 PM   #7
jchen
Thanks Guys, yep when I finish with it it will look like a 6HV.
The looks of the stock Atom stretch was what turned me off when
I flew my other stretch Atom. Just didn't look right in the air. As
mentioned with this new canopy, it opens up the possibility of
going 8s or 12s conversion
Old 07-12-2012, 11:33 AM   #8
rallyant
Hmmmm that's nice!!!
I think I'll run one even on my non stretched atom.
Didn't you get 2 canopys? I want to see the other one now
Sent from my Galaxy Nexus using Tapatalk 2
rallyant is online now        Reply With Quote
Old 07-12-2012, 12:07 PM   #9
jchen
your too demanding rallyant. tomorrow ya. btw will not look good on
stock atom coz it is out of proposion
Old 07-12-2012, 10:33 PM   #10
rallyant
While I'm in a demandind mood how about a side by side with the 5 vs 5.5 canopy?
Yeah it looks like it might be BIG on a 500, but so is the 7HV. I just want extra visibility. I don't care if it doesn't look right. I'll have one of each. I may even stretch it but keep the 500 blades for cheaper crashes. Also gives me the versatility to run 500 or 550 at anytime by swapping the blades.
Old 07-23-2012, 03:15 PM   #11
Wiebe_nl
Received mine today!!! As already been discussed it has pre-drilled holes which are not very good located. Need some extra work to fit well.
The BEASTx controls my Protos 500. Vbar for Logo 500
Wiebe_nl is offline        Reply With Quote
Old 07-23-2012, 03:54 PM   #12
sly the dogman
The canopy you have is not the one shown in Fusono's site, it's blue ans not very pretty, I must say. Yours has cool colours.
We do accept FB parts for Compass 5.5
sly the dogman is offline        Reply With Quote
Old 07-23-2012, 03:56 PM   #13
Wiebe_nl
Thanks!.
Fusuno works with custom designs if you want. This is my own design.
Old 07-23-2012, 08:44 PM   #14
jchen
Hi Wiebe,
Did you stick the Compass name on the blade yourself ?
Old 07-24-2012, 03:47 PM   #15
Wiebe_nl
Hi Wiebe,
Yes. These are holographic stickers. They make the spinning blades look like a CD ROM disk in the sun.
Old 07-25-2012, 04:54 AM   #16
Jeremyts
That's nice where did you get those?
Jeremyts is offline        Reply With Quote
Old 07-25-2012, 07:08 AM   #17
xspare
Probably here... http://www.rigidheli.com/Webwinkel-P...-Atom-500.html
xspare is offline        Reply With Quote
Old 09-05-2012, 04:52 PM   #18
Steve1712
Hello,
i came across this posts After i Received my canopy yesterday....
I did Some modification too but on the canopy itself... I Drilled New holes in Front of the Old ones... I also use now tenax mounts so the Old holes are getti g covered!
The bottom Mount i did by myself... Just improvisated... I elevated the Mount to ajust the canopy horizontally so tha it Looks like how it supposed to me...
Steve1712 is offline        Reply With Quote
Old 09-05-2012, 08:30 PM   #19
rallyant
Could you use breakaway's instead of redrilling?
Sent from Android via Trap a talk 2
Old 09-06-2012, 06:54 AM   #20
Steve1712
What do you mean with breakaways?
