Old 07-11-2012, 10:54 AM   #1
Maypole
Default Tri-Flow is your friend, and other notes of interest.
Ok, I just recorded flight number 29 and thought I would report on something that so far, has been working very well.
When I got my 130, I went through it just as if I had bought a used bird. Using what I had learned from you guys (thanks a ton btw!), I damn near took it completely apart and during re-assembly set the thing up according to the findings here on HF. Switched o-rings for grommets, adjusted boom, checked for level swash, zero pitch, seated gears and proper mesh, etc.
One thing I found that was disturbing was that several of the screws that mount the servo bodies to their boards were loose. I knew to check for this due to prior experience with the mCP X. One more thing to add to your maintenance list.
Now to the Tri-Flow. I have been a strong believer in this stuff for a long time and the uses on this bird are no exception. Before each flight, I have been applying a liberal amount to both A/B and C/D meshes, and about every third flight just a small amount on the bearings, and allowing 2 or 3 minutes for it to dry somewhat.
I am pleased with the wear results I've gotten on the A gear. The picture below is not in very good focus on each of the teeth, but hopefully close enough on others for you to get an idea. Taken on my phone and my camera doesn't have macro.
Again, this is after 29 flights.
Edit: The Tri-Flow I'm using on the gears is the Superior Dry.
Nano CP X, mCP X BL, 130 X (Love the little ones)T-REX 500 Efl Pro DFC
Phoenix Sim, DX8, Gibson Les Paul, AMA #987871
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." Thomas Jefferson
Maypole is online now        Reply With Quote
Old 07-11-2012, 12:25 PM   #2
atv223
Lots of people are talking about silicone grease on the gears. Do you think the triflow oil works any better?
atv223 is offline        Reply With Quote
Old 07-11-2012, 12:32 PM   #3
AcidDrink
Trfilow oil doesn't do anything to these gears, it's going to be spit out in first 5 seconds of flight.
If you want to lubricate them use grease.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote
Old 07-11-2012, 01:01 PM   #4
Maypole
Sorry guys, my bad. I forgot to mention that the Tri-Flow I'm using is the Superior Dry version. It goes on as an oil and leaves behind a wax coating after drying. It will still fling off eventually, which is why I apply it before every flight, but could probably hold up for more than just one flight. Even grease will fling off in time. Again, sorry for the oversight.
Bottom line, it works damned well and it's hard to argue with the results.
http://www.triflowlubricants.com/Dry_Lubricant/dry.html
Old 07-11-2012, 02:10 PM   #5
Goatkeeper
I haven't tried that kind of triflow. But I'm approaching 50 flights with the first set of gears using lithium grease. The same stuff I use ony fusion 50. And I fly pretty agresive.
Goatkeeper is offline        Reply With Quote
Old 07-11-2012, 02:56 PM   #6
GSPI
You know that tri-flow you are talking about is a petroleum based lubricant not a silicon or synthetic. I'm not discounting that it's helping at all but you might want to be aware that the MSDS indicates the petroleum distillates which can attack certain plastics. Your main component that is really helping you is the PTFE (Teflon) that is present which is a sacrificial material that coats wear surfaces.
Keep up the good work on keeping them flying!
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote
Old 07-11-2012, 03:23 PM   #7
Maypole
Good point.
And yes, I am aware of what some petroleum distillates can do to certain plastics. The main fear I would have with todays materials would not be the plastics being in danger as much as the cheap rubber used in some of our models. Since I have been using this particular lube on Blade products for almost two years with no ill effects whatsoever (not even the cheap rubber or the Lexan the canopies are made from), I have the utmost confidence in it being able to continue to perform.
Old 07-11-2012, 05:03 PM   #8
Krea
Isn't lithium grease also petroleum based? I just ordered some for my heli - is it safe for electrical and plastic parts?
Krea is online now        Reply With Quote
Old 07-11-2012, 05:16 PM   #9
naturecannon
I tried the trflow synthetic grease. Man that stuff sure is a dust magnet and flings on everything, even when lightly applied. Naked eye didn't notice much but a close up photo revealed a dirty blob invasion on the mainboard.
Lithium grease will give me different results?
MCPX- V2, 300x, 450 3D
DX6i Dx8
Flamewheel 550-Naza/GPS
naturecannon is offline        Reply With Quote
Old 07-11-2012, 06:23 PM   #10
naturecannon
Well I found out Tri-flow synthetic grease is made w PTFE, which is basically teflon by Dupont. Good stuff for PLASTIC.
DX6i Dx8
Old 07-11-2012, 06:38 PM   #11
atv223
What about Super Lube?
Old 07-11-2012, 07:04 PM   #12
Goatkeeper
It says on the tube that it's plant derived. And safe for plastic.
Old 01-07-2013, 09:39 AM   #13
concretefingers
Triflow WILL damage plastic gears. As I have found to my cost when I was a photocopier engineer. Nylon gears should not need lubrication. maybe using SPG (special Plastic Grease) would get you out of a spot. But correct adjustment of the mesh and accepting that they are a consumable item that wear out is probably best.
this is addictive
concretefingers is offline        Reply With Quote
