Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 07-12-2012, 08:23 AM   #1
heliguyG6
Default Fusuno Green canopy
Hello. 2 flights today and the canopy stays have ground a hole in both sides near the motor. Anybody else had this ?
James.
Sent from my HTC Incredible S using Tapatalk 2
heliguyG6 is offline        Reply With Quote
Old 07-12-2012, 09:44 AM   #2
G200driver
Yes..RC Booya has pads to install on the insdie of the canopy for this...another fix is to take the skids stops that are provide with kit, and put them over your canopy standoff, leaving them sticking out just a little...
#1 - Compass 7HV, Scorpion 4530 , VBAR, Kosmik 200
#2 - Logo 700
G200driver is offline        Reply With Quote
Old 07-12-2012, 09:48 AM   #3
Jamesppp
My front canopy standoffs came with rounded inserts installed in them. They are skid pipe ends I believe.
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 07-12-2012, 12:35 PM   #4
heliguyG6
I have them on but the canopy is now crap.
does anybody have a fusano canopy installed with no problems?
james.
Old 07-12-2012, 01:25 PM   #5
heliguyG6
Old 07-12-2012, 03:45 PM   #6
heathy
James, been using the skid olive/grommet mod since day 1, zero issues. That does look bad though! You still got the stock ??
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep
heathy is online now        Reply With Quote
Old 07-12-2012, 03:51 PM   #7
heliguyG6
Originally Posted by heathy View Post
James, been using the skid olive/grommet mod since day 1, zero issues. You still got the stock ??
whats that?
still have the stock, just tested and there is a 1mm gap between the stand and the canopy.
FL are going to send it back for me and hopefully replace it.
James
Old 07-12-2012, 04:04 PM   #8
heathy
The rubber skid grommets, just slide 1 over the stand off, leaving a bit over hanging
Old 07-12-2012, 07:45 PM   #9
GimpyGolden
I use mine as they are stock with no wear on canopy.
Do you maybe have a high freq vibe causing the damage?
Does your tail fin vibe?
Scott
RC
HeliCanada.com
-Rep
Compass 7Hv - Synergy E5 - Logo 600
Next: 6Hv Ultimate
GimpyGolden is offline        Reply With Quote
Old 07-16-2012, 11:57 PM   #10
Airworks
ok , get yourself some fibercloth and some epoxy and beef up the inside spot a little to fix it... then stickers on the outside to keep the paint from fracturing , then , do the mod to the standoffs.
mine , i jsut have the skid ends in not wearing at all , but stock cano...(same one, as fusano makes the cano's).
something else i did was the bottom mount(plastic insert thing) , i wrapped a piece of velcro strap wedged between the carbon mount , and plastic skid , then have a velcro sticky back on the canopy , really locks the canopy onto the heli securly.
Warp, 6HV LED, 7HV, Rush
^^^^Team Compass^^^^
Nankin Hobby
"Tis the season to get everything ready"
Airworks is online now        Reply With Quote
Old 07-17-2012, 02:59 AM   #11
heliguyG6
Hi, not in the game of fixing things that should be right from the manufacture.
if they make the canopy then they made a very bad copy on this one its a completely different shape from the stock one.
I will how ever do the stand off mod you suggested
lets see what Fast-Lads say when I take it back on Friday ???
James.
Old 07-18-2012, 12:34 PM   #12
Rob43
I've been running my green Fusuno Future since last September, and have easily over 100 flights on it. Others who've recently seen it can attest it's like new.
My setup? Simple. See Mr. BBRFST's solution. I followed his lead.
http://helifreak.com/showpost.php?p=...0&postcount=12
For additional protection, simply apply some Shoe Goo, or Goop adhesive to the inside of the canopy where the standoff touches. This will reinforce the fiberglass and cushion the action of abrasion from rubbing between the two.
Best wishes,
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 07-18-2012, 05:18 PM   #13
dunkonu23
I attest!
Scott
Spartan Vortex VX1 Inside
Team A Main Hobbies/ProTek Field Rep.
dunkonu23 is online now        Reply With Quote
Old 07-18-2012, 05:29 PM   #14
Rob43
Thx!
= R
b43 =
Old 07-23-2012, 04:27 PM   #15
Gawl
I'm running the same green fusuno canopy with just the skid pipe ends in and have no wear issues like that at all. I'm not even using anything extra on the pipe ends. I'm wondering if the bracket in your canopy is not mounted far enough in to keep it from moving once the standoffs are secured.
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote
Old 07-24-2012, 04:37 AM   #16
heliguyG6
You mean the connector at the bottom? the holes were pre drilled.... I do feel the connector could be further in so the canopy sits further back. I have had a replacement and this one has done the same. I glued some hard plastic in the inside of the canopy to stop it from ruining another canopy...
Old 07-24-2012, 04:59 AM   #17
snaaakeey
Bit of Zap goo on the contact points inside the canopy makes a nice rubberized pad.
6hv (fb)
7hv
DX8
snaaakeey is offline        Reply With Quote
Old 07-24-2012, 04:11 PM   #18
r.allington
ive cut 1.0 off my standoffs and all is good
r.allington is offline        Reply With Quote
