Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 07-13-2012, 08:30 AM   #1
shadco
Default Tail drive gear mesh?
Is this offset normal or do I have something wrong here. The gear in the tail box sits high compared to the gear on the main shaft.
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar
SAB G500 Savox 4050 KST/MKS HV YGE HC3SX
Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8
shadco is offline        Reply With Quote
Old 07-13-2012, 08:42 AM   #2
Wh1teAfr1can
It's as designed so nothing to worry about and also if you notice the gear train is a little tight that is normal too it will get super smooth after about 10 flights or so
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Wh1teAfr1can is offline        Reply With Quote
Old 07-13-2012, 09:14 AM   #3
nivaldin
Mine has the same misalignment, don't worry, it will work perfectly.
Fusion 50 FBL * Mini-Vbar * 10s battery * CC Phoenix ICE2 80HV * Scorpion 630KV
nivaldin is offline        Reply With Quote
Old 07-13-2012, 06:16 PM   #4
Arcturus97
Yep, I asked the exact same question a couple of months ago
* Outrage Fusion 50 FBL, Torq HV BL servos, SK-540, Quantum 4125-560, ICE2 HV80, 12S, Edge 623
* Align T-Rex 500E, DFC Head, SK-540, ICE 75, Mavrikk G5 Pro
* Blade Nano CPX / mCPX / 120SR / mSR * Futaba 8FG Super & Spektrum DX7 dsm2
Arcturus97 is offline        Reply With Quote
Old 07-13-2012, 10:57 PM   #5
nivaldin
Even in the pic of the manual, you will see this misalignment lol.
Old 07-14-2012, 03:58 PM   #6
OnTheSnap
If the mesh is tight don't expect it to loosen up much by itself with black gears. I had to slot all the boom mounting holes by .25mm to fix the mesh on mine.
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e
HeliDirect, Team iKon, GrandRC
OnTheSnap is offline        Reply With Quote
Old 07-16-2012, 03:54 PM   #7
Wh1teAfr1can
I have seen the complete opposite. they go from only being able to free wheel a little to super smooth.
Team Kontronik
Team minicopter
Old 07-17-2012, 05:37 PM   #8
dantemcc
Its funny now that some one brings this up. I've always seen pic of both, either a little low or a little high. I have yet to see any pics of the f50 where its all even. But as long as it preforms well, then that's all I really care about.
Why does everyone keep calling me Dan? My name is Dante
dantemcc is online now        Reply With Quote
Old 07-17-2012, 11:10 PM   #9
ericcolon
Well here you go. Pretty even to me. Click image for larger version
-- Outrage Fusion 50 FBL, Outrage 560k motor/CC HV80 ESC, Torq 9180/9188 servos, Skookum 540
-- SAB Goblin 500, Scorpion 4020-1350kv, CC Talon, Skookum 540
Lynx Heli Innovations Team Pilot | Southwest PR RC Crew
ericcolon is offline        Reply With Quote
Old 07-18-2012, 04:55 AM   #10
rex09
I have found the mesh betweeen these two gears (only the black ones) a problem each time I changed them, the first set where fitted because they looked good & the mesh was OKish, took about 20 flights to free up. but the last set
The Tail gear under the main gear ran off centre, It would become tight evey 1/2 rotation, The outside of the gear it's self was 0.001" out of round, I measured the run out when mated with the main gear at 0.008", I moved the clutch housing 90 deg at at time, each move it changed, put another new gear in, it was the same, ended up turning it over, best I got was 0.005", tried a new umbrella gear set, no change.
Turned the inner race of the clutch 180 deg, it was best with run out at 0.002.
so now it is even, but still tight with no backlash ? compared to the white gears.
With the blades off, it is firm to turn, blades on from 2180 rpm stops in about 30 sec, the white one would take a miniute.
Being an aircraft/helicopter engineer for 35 years, to me this tight a mesh is not good, increased load, heat, & worst of all, vibration, in a FBL that is not a good thing,
Time to improve there quality?
rex09 is offline        Reply With Quote
Old 07-18-2012, 06:22 AM   #11
dantemcc
"Time to improve their quality"! AGREED!
Old 07-18-2012, 10:47 AM   #12
RyuuChi
Lets face it, all of these companies could stand to improve their overall quality... im not sure if any of my helis with this configuration have perfect alignment on those gears. I've never had any major problems with the quality of parts on anything other than cloned birds really... and even the minor ones were made good on.
and not to be a jerk but, ignorance is defined as a lack of knowledge or information, which has nothing to do with intelligence, which is defined as ones ability to aquire and apply knowledge and skills. just thought someone should politely point that out.
Thank god i have snowboarding to keep me occupied when its too cold to fly!
RyuuChi is offline        Reply With Quote
Old 07-29-2012, 02:33 AM   #13
rex09
UP DATE:
It was well worth the time to get these gears right, The Fusion had always been smooth or so I thought untill now, The diffrence is like flying a whole new super heli, The AR7200BX has helped the flying, Spent hours getting the setup within 0.1 deg, not one feild adjustment required, smooth as He**. Very happy.
