| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Anybody?
CHECK OUT GRANDRC.COM THEY HAVE THEM IN STOCK
TEAM SHELDON'S ALIGN 700N DFC~~~600EFL~~~DX8 VOLTZ~~~~~MAVRIKK To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
KDE just released a new aftermarket one. Ordered mine last night.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Thats not a main gear it's an tail gear.
KDE just began shipping the helical main gear. AFAIK Align has not delivered theirs yet.
Steve Graham TREX 700N FBL...................GAUI X5 FBL...................TREX 450 PRO V2 Alees Rush 750 Still in the womb. |
#6 |
I've been running the Align helical main gear for some time now. Have even stripped a couple.
#7 | |
Thanks but I already use that. I need the main gear...Preferably anywhere but Grandrc. |
#8 |
Its the same gear used in the 700E...
Synergy E7 | Synergy E7 | T-Rex 450 Pro GrandRC | Tekin Racing
#9 | |
Two downsides. Mucho expensive and just came out so no track record. OTOH KDE stuff has always been very good for me as I also could not find the align gear anywhere. I also would not do business with that particular vendor as I tried repeatedly for 18 months to order from them and could never even get the courtesy of a "bugger off kid your bothering us" BTW just ordered a bunch of stuff from A main hobbies. Not the first time but I was impressed at the amount of stuff they have that is not chronically listed as "out of stock" or "check for availability"
#10 |
The new helical pinion http://www.align.com.tw/shop/product...oducts_id=4422 works, as Align mentions, only with the CNC helical main gear H70020B, which is issued for the 700E. That's where you need to look in order to find it.
http://www.align.com.tw/shop/product...e=en%20target= here you go: http://grandrc.com/p51151/H70020B-CN...duct_info.html ![]()
At the precipice, we change! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team GrandRC |
#11 |
KDE helical main gear is made of the same material as the straight one. If you have used the straight one before, you will know exactly what to expect. Same good quality and self lubricating property. It is also super strong.
I used the straight one for about a year with numerous crashes. Still works fine. Used the helical version for just over a month now. Works great. Cheater
Cheater To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#12 |
Thanks guys.
