Old 07-15-2012, 10:55 AM   #1
bigdessert
Default Well 2nd flight and first problem....
Was hovering around when all of a sudden the tail starts spinning out of control from 30ft up. Hit TH real quick but it still managed to dive bomb into the deck railing. Nothing damaged though.
Upon further inspection the tail servo wasn't working. Found the negative wire just came off the servo board. A quick solder job later and I was back in business.
bigdessert is offline        Reply With Quote
Old 07-15-2012, 10:59 AM   #2
chardur
Glad to hear it survived the crash!
Same thing happened to me on my first flight. Black tail servo wire disconnected at the servo board solder point.
--Hold two league records: most crashes; and I was the only guy to ever take off his main blades and try to stab somebody.-- Currently Flying: 500X, 250 DFC,180CFX, MCPX BL
chardur is offline        Reply With Quote
Old 07-15-2012, 01:04 PM   #3
ericbuzz
Thought it was just me. Lost the positive lead from the board.
ericbuzz is offline        Reply With Quote
Old 07-15-2012, 01:30 PM   #4
bigdessert
Must be from the tail vibes?
Old 07-16-2012, 08:29 PM   #5
mmilan
I had the same experience. White wire broken at the solder point. The black wire was hanging by one strand. It had been bent backward at 180 degrees! Bound to fail. Resoldered and repaired tail damage and all is good.
mmilan is offline        Reply With Quote
Old 07-17-2012, 11:32 AM   #6
Pozzix
Default Tail Servo solder wire, come off from board
Also I have had same problem. Fortunately that issue come in on the ground, while hover.
Wires were solder with the sheath that come off the board and any little touch could get them off.
Now is all ok.
Pozzix is offline        Reply With Quote
