| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
I've got a hyperion 2221-1630kv. Same size as the 6s 1300kv mini protos I believe. Will this work on a mini protos? I will most likely get a 14T pinion.
I'm thinking of retiring my 6s blade 400. It exploded in mid air earlier today. ![]()
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T. Save the flybar !! |
on 4 series with big pinion but you need to crunch some numbers for it with the available pinions and as they stand it is 15 to 18 tooth. the current 14 tooth which is the smallest seems to self destruct. The main gear is only 120 tooth kavic so do the math
Too much Kv for 6S, would work ok on 4S but the HS may be a little low (depending of if you like high HS or not).
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
Thanks for the replies. I guess I'll just get the boring looking black 6s motor.
