Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Electric
MA Electric IonX2, Razor and Furion Support forum
Old 08-21-2007, 09:24 PM   #1
mudbogger2
Default Ion-X to Ion-X2 Conversion Thread
I just got in my second Ion-X2 conversion kit. I wanted to share this one with everyone by means of a photo build thread. If you have an Ion you can see what is involved with the X2 conversion. It is really an easy mod to do. I don't have the instruction for the conversion yet but this is how I did my last one. Should help you guys out with conversions untill the manuals are done.
The first part will cover disassembly. My conversion donor is a backup airframe that will be my #1 machine when done. It was a 2 stage setup so if you are converting from a single stage setup there may be some minor differences.
The second part will cover the assembly steps.
Here is the donor before work starts.
ID:	24828   Click image for larger version
Jon Jennings
mudbogger2 is offline        Reply With Quote
Old 08-21-2007, 09:27 PM   #2
mudbogger2
Here is all that is included in the conversion kit. Mine will be setup for an actro motor with an 11.3:1 ratio for a 12s setup.
Jon Jennings
Old 08-21-2007, 09:31 PM   #3
mudbogger2
Remove the battery mounts and standoffs on both sides of the heli.
These parts will not be needed any longer.
ID:	24831   Click image for larger version
Jon Jennings
Old 08-21-2007, 09:36 PM   #4
mudbogger2
Next remove the boom and boom supports from the frame.
Jon Jennings
Old 08-21-2007, 09:39 PM   #5
mudbogger2
Remove the Landing gear and lower baseplate.
The lower baseplate is optional on the X2 conversion. I choose not to run them.
Jon Jennings
Old 08-21-2007, 09:46 PM   #6
mudbogger2
Next remove the maingear assembly, mainshaft with the swash and all other head parts. Remove the split collars from inside the frames also.
Jon Jennings
Old 08-21-2007, 09:49 PM   #7
mudbogger2
Remove the aileron and pitch bellcranks and servo wheels. Also remove the elevator servo wheel and linkage.
Jon Jennings
Old 08-21-2007, 09:54 PM   #8
mudbogger2
Remove the 3 cyclic servos.
Jon Jennings
Old 08-21-2007, 09:57 PM   #9
mudbogger2
Remove the rudder servo if installed. Mine was already removed.
Remove the rudder servo mount.
Jon Jennings
Old 08-21-2007, 10:02 PM   #10
mudbogger2
Remove the tail boom holder halves from inside the frames.
Jon Jennings
Old 08-21-2007, 10:04 PM   #11
mudbogger2
Remove the front and rear landing gear brackets. The front C channel should have all of the bolts out of it with the front landing gear bracket removed.
Remove the fron C channel.
ID:	24840   Click image for larger version
Jon Jennings
Old 08-21-2007, 10:12 PM   #12
mudbogger2
Remove the anti-rotation bracket.
Jon Jennings
Old 08-21-2007, 10:15 PM   #13
mudbogger2
Remove the upper and lower mainshaft bearing blocks.
Jon Jennings
Old 08-21-2007, 10:20 PM   #14
mudbogger2
Remove the motor mount for the 2 stage motors at this point. Mine was already removed on this airframe along with the seconday gear.
Next remove the secondary gear and bearing blocks along with the upper pinion.
Jon Jennings
Old 08-21-2007, 10:23 PM   #15
mudbogger2
Now remove the rear C channel.
Jon Jennings
Old 08-21-2007, 10:25 PM   #16
mudbogger2
Now remove the pitch bellcrank that is in the middle of the frames.
Jon Jennings
Old 08-21-2007, 10:29 PM   #17
mudbogger2
Now split the 2 frame sides. Remove all the standoffs and spacers from the frames. The frames will not be reused on the X2.
Jon Jennings
Old 08-21-2007, 10:33 PM   #18
mudbogger2
At this point we are pretty much done with all the dis-assembly. Take this time to check over all your parts. Lube your bearings or replace them as needed. It wont be this easy to do untill.........you know. Clean everything up and we will get ready to start the assembly.
Jon Jennings
Old 08-21-2007, 10:40 PM   #19
mudbogger2
Before assembly starts you will need to install some PIM nuts in your rear C channel. The holes will need to be enlarged to fit the pim nuts. My first conversion kit needed the front and rear channel pim nuts added but this latest conversion kit has a new front channel with the pim nuts already installed. Only the rear channel pim nuts needed to be installed on this conversion.
I used an 11/64 drill bit with a drill press. The nuts can be pressed into the channels with a good size pair of pliers and a little force.
The last pic shows what your channels should look like when all the pim nuts are installed.
ID:	24852   Click image for larger version
ID:	24853   Click image for larger version
Jon Jennings
Old 08-22-2007, 06:14 PM   #20
mudbogger2
I am going to start the assembly with the left side frame. The right side frame has the mount for the rudder servo on it. See the first pic.
First install the rear upper spacer to the left frame half.
Next install the rear channel on the left side frame.
ID:	24893   Click image for larger version
Jon Jennings
