Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim
Phoenix Flight Sim Phoenix Flight Sim
Old 07-16-2012, 10:04 PM   #1
Rick Dizzle
Default Phoenix glitching after update???
So I have not flown on Phoenix for a few months....Just fired her up and it did its normal auto update...now it keeps glitching? For example be flying and can fly fine for about 5 seconds than it freezes for a second, fly about 5 seconds glitch for a second and so on...what the heck is causing this? I am using Phoenix 4 version K as it just updated. I have even tried adjusting the display settings from high to low and it still is not fixing it! Lil help plz?
Trex 500 ESP w/ KBDD Tail blades and paddles
Trex 600 Nitro DFC/ OS 55HZ limited edition
Phoenix 5.0 Sim, DX9
Rick Dizzle is offline        Reply With Quote
Old 07-17-2012, 06:07 AM   #2
puzom
I'm still using version J as K is indeed causing issues for some.
puzom is offline        Reply With Quote
Old 07-17-2012, 11:54 AM   #3
Rick Dizzle
Poop...is there anyway to revert back to J...or am I stuck with K?
So I tried to fly again today my FPS go from about 60 a the high end down to 1 and it just stays at one now for like 5 seconds then goes up to 60 and back down to 1...so frustrating...I just wanna fly...any ideas?
Old 07-18-2012, 09:13 AM   #4
puzom
You could ask support if there is a downgrade from K to J............if not I could upload the vJ phoenixRC.exe. But no idea if that will give you a stable version.......
Old 07-18-2012, 12:09 PM   #5
Rick Dizzle
So after tryin almost everything...I found the issue... (Im not computer smart unfortunatly), I went into my computers task manager and found i had some weird tool bar update running. It was sucking up 98% of my pc's ability to run properly. I found it was not anything i needed and could end the application...upon doing so...bam! I was back in the money with 45-60 fps. Which is good enough for me to fly and practice. So long story short, it wasnt even Phoenix causing the issue.
