Go Back   HeliFreak > R/C Helicopter Support > 100 Class Electric Helicopters
100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-17-2012, 07:54 PM   #1
cruzroy
Default V911 SKID Mod with Trex 100 Skids and Review
Hi Guys i picked up a V911 on sale for 19.99 shipped, and when i got it i figured, i bought alot of batteries for my TREX 100X and i knew it would bind to my Turnigy 9X, But when i got it i opened the box, and tried a battery, and BAMB! , the batteries dont work, So i would have to buy a charger and baterries......that would defeat the pourpose of being cheap.........So i thought i would get a pair or trex 100 skids and change them with the V911, and that would be only 6.00 bucks shipped, PLUS the V911 batteries are 120 mah and the TREX 100 i have are 160 mah, so i get 2 mods, higher battery power and i can use all my batteries......For only 6.00 bucks....ENJOY!
Here is the 2 birds, the V911 is bigger, and longer tail
next i test the battery........and it dont fit.....BUMMER!!!!!
Ok remove the V911 canopy
I noticed that the V911 has a screw in the rear of skids, the TREX 100 Dont.......NO PROBLEM!!!!!
So remove the screw and get out the new ALIGN 100 skids.
kind off look at the differences before you start
Ok remove the skids
now i see that the wires are bigger, and the tabs are bigger and the trex dont have a screw.....NO PROBLEM !!
So measure the tabs on the TREX 100 skids
Now find a drill bit of similar size.....
Use the drill bit by hand.....no need for drill, and do front and rear holes.......
Now just put a DAB of CA glue to the tabs closet to skids.....just to grab at the end, so if you have to remove them....
Ok let the fun begin.....you are going to check out the old wiring and put the glasses on to unsolder the V911 skids.....
Now cut the TREX 100 skid connector off and tin the red and black wires
Now GENTLY unsolder the wire from the V911 board........take your time, but dont lay the heat on a long time......dont want to hurt the board..
Now save the old skids......or sell them on ebay ?????
Now GENTLY RE-SOLDER the trex skids to the V911 Board.......Carefull dont burn the blades or board......
Now bind to your Radio or Turnigy 9X.....like me
REVIEW ::::::
the V911,s tail holds Better then the TREX 100 and now with the bigger batteries the V911 has way more power......
HAVE FUN!
CRUZROY
cruzroy is offline        Reply With Quote
Old 07-18-2012, 09:10 AM   #2
maxbreaker
Very clever!
I have couple questions for you. Where did you order the V911? Would the V911 bind with the regular T-100 trx? For those who don't have the soldering skill (like me) just splice the wires and re-connect them. Make sure use heatshrink tubing or electric tape so they don't get short. Thx,
maxbreaker is offline        Reply With Quote
Old 07-18-2012, 07:49 PM   #3
maxbreaker
Thanks cruzroy, I going to order one to do this mode. Hopefully can bind to my exist Align trx.
Old 07-19-2012, 07:39 AM   #4
Wanaero
I'm not going to risk doing that as the stock batts are sufficient and the heli has a lot of power compared to an align. And no it can't bind to an align tx as i have tried with mine.
The only problem i have with this heli is the tailboom. Can't take it out incase of the tail motor burn-out. Which will happen when you crash on the tail.
Other than that, it's fun to bash and do some dog-fight with friends!!
Wanaero is offline        Reply With Quote
Old 07-20-2012, 06:11 AM   #5
cruzroy
Default Video ,test run, v911
Hi guys i did a test flight outdoors with the trex skids, and i have to say the 20.00 V911 out performs the Trex 100 x.......just my 2 cents
[YOUTUBE]
[YOUTUBE]
Old 07-20-2012, 05:31 PM   #6
maxbreaker
Did you tried with the trx came with 100X? Thx,
Old 07-20-2012, 05:50 PM   #7
cruzroy
im sorry i bought mine with the ipod a5 adapter.......but if the trex 100x binds to the turnigy it should bind to the trex tx.....buy im not sure ??? but i know that the board in the trex 100s wont bind to turnigy, but the 100x will...hope that helps
Old 07-21-2012, 08:40 PM   #8
Wanaero
I tried it with the 100s tx. It won't bind at all. Not sure about 100x though.
Old 08-03-2012, 11:11 PM   #9
johansipp
hi.
how about using this batt to v911, it can fit? hobbyking
johansipp is offline        Reply With Quote
Old 08-04-2012, 04:06 PM   #10
cruzroy
if you do the trex skid mod you can.....those are the ones i bought.........i got 10...to keep me flying
Old 12-23-2012, 09:01 AM   #11
cruzroy
Default anyone try the mod yet
Old 01-07-2013, 09:11 PM   #12
trout911
I purchased a v911 over the christmas break and i really enjoy flying this heli. I will say however, I do not have the set of skids that your heli has. I have a new version and cannot do this mod. Heli flys great though.
BLADE SR - HOW TO MAKE YOUR OWN TAIL BOOM
http://www.helifreak.com/showthread.php?p=3287300#post3287300
trout911 is offline        Reply With Quote
Old 01-15-2013, 11:21 PM   #13
i2ookthablu1
Could you say why this mod can't be done please? I was keen to try this!
i2ookthablu1 is offline        Reply With Quote
Old 01-24-2013, 10:20 PM   #14
ericdrob67
I did Thanks for the write up, now i get to make use of the 10 batteries i had for my 100x in the V911.
ericdrob67 is offline        Reply With Quote
Old 02-24-2013, 03:22 PM   #15
Nickjo
i have the new version as well but i was able to make it work. i just had to drill a hole on the front connection due to the pin being glued and breaking. so now i can just use one set of batteries and buy the upgraded 160 mah ones.
side note both helis bind with both the 100x and v911 tx's
Nickjo is offline        Reply With Quote
Old 03-02-2013, 07:41 PM   #16
sdsteve
Ok remove the skids
REVIEW ::::::
HAVE FUN!
CRUZROY
Wow! That is clever and sounds like a lot of work when you could have just bought the old style WL V911 landing gear. Tinkering is what we love though.
My bad! I now see you do have the old style landing gear.
Nice fix dude.
Steve
mSR X, WL V911, Scout CX
sdsteve is offline        Reply With Quote
Old 04-09-2013, 03:50 PM   #17
Oreshooter
Default MODS
I also have both a V911 and a TREX 100X. I am going to try this mod tonight. I only have the two batteries that came with the V911 but I have 15 for the TREX 100. The other thing that works well is using a V911 Canopy on the TREX 100. You will just have to put two new holes in the canopy so that the lower pins can fit, but the upper pins fit fine. Its a far superior canopy.
Oreshooter is offline        Reply With Quote
Old 07-16-2013, 01:00 AM   #18
C4Vette
Default Fly-time
Nice mod!
Can you please let us know how long you can fly on those 160mah? Can easyly be seen on that 9X
I get just over 6 minutes on two v911's on 150mah flying outside. Even get the same time on a 120mah because it is lighter I guess.
C4Vette is offline        Reply With Quote
Old 02-06-2014, 02:27 PM   #19
shaggybirdman
well now that the 911 v2 is avalible all ya need do is get the v2 skids, and batteries unless you have a trex 100 then mod the 100 skids on. gotta get a turnegy 9XR now. just what i need. yet another radio.
Jerry
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote
