| 130X Blade 130X Helicopters Information and Help |
#21 |
I've got about 50 flights on mine and no issues with anything. I damaged a tooth on the A gear in some heavy grass but this just gave me the excuse to install the optional metal gear....
Love flying this little guy... Been great to me.... Knock on wood.... |
#22 |
Thumbs up on the positive post!!!
I'm at 60+ 7crashes and all original parts until yesterday. I broke a blade grip. I'm lovin it!!!
Lynx Heli Innovations team pilot. Mavrikk field rep.
#23 |
Somewhere around 75, 68 of which were completely succesful. The resulting crashes from the other 7 have yielded only minor damage. Loving this thing.
Nano CP X, mCP X BL, 130 X (Love the little ones)T-REX 500 Efl Pro DFC Phoenix Sim, DX8, Gibson Les Paul, AMA #987871 I really think this "Internet" thing is going to catch on. You can quote me on that. |
#24 |
+1+1 on this post.
I have 90 flights 4 crashes and out of the four crashes I stripped one main gear and I still flew with the stripped main gear. I was planning on getting a 300 but change my mind because this lil guy is tough crashable and flies like its on rails Be blessed Isaac Sent from my DROIDX using Tapatalk 2
Jesus Rep all over, Team Outrage USA Rep Orange Power To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. O Fusion 50, BL mcpx ultra, 700e, trex 450 pro all FBL 3g, vbar 5.1(blk), 3g, kds ebar GOD BLESS |
#25 |
Well over 100 flights, 50+ crashes. Stripped 6 A gears, not hitting TH fast enough. All flights are 8 flight sets, back to back no cool down. Lost one servo, broke a blade grip, 2 booms, random little things. But I cant complain, If I were slammed into the ground, concrete, trees, fences, tables, etc., I'd need a little maintenance as well lol.
Blade 130x. Gaui X5 Forumla I'm Back Snitches!!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#26 |
Got 30 flights in and 5 crashes, sofar one servo broke, brass bolt broke off and broke the CF rod inside the canopymount
This thing is as durable than my MCPX Grtz Rudi
DX6i +Trex 450 pro 3GX + MCPx |
#27 |
0 because mine is still at the store
. I need people to pay their bills![]() |
#28 |
Guys, loving those high numbers! I had a busy day and only got 8 flights in right before dark.
I'm happy to report that i put on the HP blades, upped my pitch to 110% in radio and rebuilt my tail pitch assembly and replaced my main shaft. I also installed KBDD tails and went for it. With the fresh uncrashed parts and tails, my heli was more locked in than ever. I had WAY more power w/ less bogging thank to the blades. Can't wait to test KBDD mains next week! I had enough power for cntinuous tic tocs , 4 point tic tocs and the tail held up through back flipping loops. @ 128 boys/gals...
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD |
#29 |
I must have around 120+ flights, 4 or 5 crashes. Broke one of the grips and replaced and glued a metal pin on the tail slider (repair is still holding even though I have the replacement part brand new in a baggie). I would fly more but only have two batteries and two chargers.
#30 |
Cullen, your making this attractive.
#31 |
The purpose of this post is to not only make this heli more appealing to those who are hesitant, as I am totally enjoying mine, but also to debunk some of the myths that people have constructed around this heli. It is fun, durable and can be made to fly like new for cheap.
I was so downright dirty to this bird right out of the gate that in 2 weeks time, it had gotten sloppy from all the flights and crashes. But with just a few $ worth in spares, I was able to revive the machine to it's full glory, and some. Those who haven't should try the high performance blades, if doing 3D, they are a big difference from the bulleted blades in this respect. KBDD are hoping to create a main blade somewhere in between, that performs 3D with ease, yet still provides some of that stability for full out open throttle flight.
#32 |
Got 3 more flights in after work yesterday.....need more batteries or a faster charger....anyway....still loving this heli....had to ditch it with throttle hold twice yeterday lost orientation inverted...hit the ground hard both times...only damage was a broken carbon rod on canopy mount...a little C/A should fix that....and will try and get three more flights this afternoon....WISH ME LUCK....LOL
#33 |
I hit 140 today and developed a nast tail wag. I cleaned the servo brushes and lowered the tail gain 4 clicks. My tail was perfect for a couple flights before the wag crept back.
#34 | |
..I hope these servos are not going to be a "consumable" item.We shall see..Still loving this little beast,I have a FBL Trex700 n (that has yet to see its maiden flight) just sitting on the bench waiting for my attention.. ![]()
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class( To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ).Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even. .Who is John Galt? |
#35 | |
#36 |
80 flights 1 tail blade departed, 2 broken tail grips all before any crashes. I am new so taking it slow. In the next 20 flights 3 main blade ball joint failures one in flight 2 from crashes. I replaced tail beaings and 2 c gears, it continues to fly better than my abilities. Lots of fun.
#37 |
Stopped counting around 50, might be around 80 at this point.
Added longer boom supports, added metal A gear and have gone through 3 C gears, totally my fault on stripping the D's in the C's. Also changed the tail box bearings. Using performance blades only, never tried the bullets. Didn't like 'em on the MCPx, saw no reason to try on the 130x. Will use them to stir paint. Oh yeah, the heli is flying fine.
Gaui X5 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. sweet! Warp 360 KST, B4503D Savox- all beastx, 250 SE flybarred-current shelf queen, 130X, Mcpx BL, Nano cpx, Mini Dragonfly, DX8 AMA #982022 |
#38 |
i figure im around 100 flights. I have 5 batteries and the progressive RC charger adapter.
Crashed into a barbedwire fence today and stuck into the wire, plucked it from the fence, checked it over, and finished my flight! I love this bird it is really improving my 3D skills, especially inverted hovering. Somtimes I break stuff when i crash but its cheap to fix and easy to work on once you know what your doing.
T-rex 600E Pro Blade 450 3D, 130x, MCPx brushless DJI F550 Naza - GPS |
#39 |
155
#40 |
I have 26-27. Flew 19 the first day, and not many the past few days (none today) due to the c gear rounding out so much (used all my spares) and the heli only lasts for a minute before the tail goes. Tried gluing it won't work.. Thats really the only thing that I don't like about this heli.
Compass, ProStar Hobby, Giant Power/OnlyFineHelis, Protek/Amain 7HV, Warp, 3D+ Lincoln To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> |
