Old 07-18-2012, 11:18 PM   #1
new bee
Default Main gear
Was wondering if I could get some feedback on this set up?
http://www.microheli.com/store/produ...321dfb6bca7af0
new bee is offline        Reply With Quote
Old 07-19-2012, 01:52 AM   #2
Tasteles
I was looking at that also. I think it's pretty much useless though because you still won't have tail control to do auto-rotations. I noticed that they have two setups to use it on different shaft and also to work with the older shafts. Wait I see now that you can also use that without a oneway bearing. Interesting!
Tasteles is offline        Reply With Quote
Old 07-19-2012, 01:53 AM   #3
UKHeliBob
As you know, the popular belief is that the main gear is designed to slip down the shaft in the event of a crash to avoid damage to itself and other parts of the heli if it crashes with the motor running. I have always been sceptical of this as I believe that there is no evidence for it but I am prepared to put up with pushing the gear back up again when necessary in case it is true.
I have seen reference to people putting a screw through the stock main gear to hold it in place and they report that it causes no problems.
Checking that the gear has not slipped down is part of my pre-flight checks for every flight and pushing it back up only takes a few seconds.
The fact that the gear linked to is made of Delrin may be more a of a problem than it being fixed to the shaft as I remember bad feedback about the Xtreme Delrin main gear but I too would be interested to hear any feedback on replacement main gears.
UKHeliBob is offline        Reply With Quote
Old 07-19-2012, 07:45 AM   #4
new bee
Yea I could care less about the one way bearing. Still wonder how it would hold up. To late for me to find out though. Already placed my order and passed on this.
Old 07-19-2012, 08:21 AM   #5
boltsinneck
I'd still like to know if there is any advantage between the CNC main gear and the injection molded one.
boltsinneck is offline        Reply With Quote
Old 07-19-2012, 08:24 AM   #6
new bee
+1
Old 07-19-2012, 12:58 PM   #7
MiataJohn
"In theory" the CNC gear should have tighter tolerences the a moulded one. Somebody would have to measure each one.
2x Stock mCPX, 1 B/L HP05 mCPX Blade 400 3x HS65mg, GY520, Align 425
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP,Parkzone T-28, All on Dx6i
AMA 732104
MiataJohn is offline        Reply With Quote
Old 07-19-2012, 02:27 PM   #8
jabu32
anyone have a link to the cnc gear?
Hello My Name Is Joe
Blade mCP X BL - HP06V2 / Blade mCP X BL - Spin 16.3K / Blade 400 - DS760, 450MX / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX
jabu32 is offline        Reply With Quote
Old 07-20-2012, 08:50 AM   #9
boltsinneck
CNC Main Gear with Hub:
http://www.microheli.com/store/produ...58a42aa7fb3662
Molded Main Gear with Hub:
http://www.microheli.com/store/produ...roducts_id/759
Scroll down close to the bottom of this page to see the hub and gears seperately:
http://www.microheli.com/store/index.php/cPath/3_69
