Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 08-22-2007, 08:09 PM   #1
jgiot
Lightbulb Gorilla Gear on the Mini Titan
I recieved my gorilla gear today,
will try it out and let you all know how the landing gear, paddles and tail do.
Mini Titan E325, gorilla gear tail. Align Pro 325 Blades,
Gorilla Gear Skids, Kasama Rotor Head and washout base.
Metal Tail and z10a ZPower 3000kv (15T pinion).
DX7. DS285 Servo's
Walkera Gyro WK-G006, FlightPower (3Cell) EVO25
jgiot is offline        Reply With Quote
Old 08-23-2007, 10:14 AM   #2
doeni
Gear and Paddles work fine on the MT great stuff
doeni is offline        Reply With Quote
Old 08-23-2007, 10:40 AM   #3
RCHeliJim
I have had both the gear and the paddles on my Mini Titan for quite a while now and they work very well
RCHeliJim is offline        Reply With Quote
Old 08-23-2007, 04:12 PM   #4
trexzznl
is it a direct fit? no mods needed? pics?
trexzznl is offline        Reply With Quote
Old 08-24-2007, 05:55 PM   #5
doeni
You need to do new holes in the Gear, the holes are a few mm to near together to fit in standard version.
But just drill one new hole and it works great
greetings
Old 08-24-2007, 05:59 PM   #6
LITHIUMSTATIC
greetings
I've heard the same thing from others. I will buy a set soon.
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote
Old 08-25-2007, 12:49 AM   #7
txflyer
if you have a cp or cpp with superskids, that you dont fly anymore. the skids fit my trex, they have 3 or 4 holes on each side of the skids. the middle small hole lined up perfectly with the trex skid mounts..
thought id throw that out there and maybe save some one a few bucks...
trex 450 sa 70% converted to se
401
9650
3x65mg
eflite 40amp dual bec esc
ar6000
430l
txflyer is offline        Reply With Quote
Old 08-25-2007, 04:00 AM   #8
henrik04
Talking
Yep! Gorilla gear flybar paddles and landing gear. I hold the gorilla gear landing strut with a rubber bands when not flying. I insure that the back is more tight (therefore a bit higher than the front.) When flying I remove the rubber bands, of course. This gives the E-325 a tail a bit higher, just enough to always have the front touching ground first..
MT E-325: TT metal head and swash. CF boom and tail, Scorpion HK-2221-10 V2, Phoenix HV45. SAB 320. Linear BEC on 2S1050 mAH. GY401 Rx:RS-10DS. Servos:65MG 9650. Zippy 4S 2200 25C.
E-620: Kasama head and tail, Phoenix HV110A, Lipo 10S, custom CF frames, Z-50A 600 V.2. GyroS-760. Servos: BLS451 BLS251. Video Tx on 1.01GHz JR 9XII /Assan 2.4 GHz
henrik04 is offline        Reply With Quote
Old 08-25-2007, 07:29 AM   #9
fixxxer
Is that not a little tail heavy ?
Cheers,
Fixxxer
fixxxer is offline        Reply With Quote
Old 08-25-2007, 12:56 PM   #10
henrik04
Smile
Not really tail heavy. The grass makes it look that way. Tail is made of 2xPV0824 'araldite' together. With Flightpower 2,500 mAH and 2S 1,050mAH for servos, Rx and Gy401 gyro through a softerm BEC I get a nearly perfect centre of gravity.
