Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 07-22-2012, 09:28 AM   #1
gitbse
Default FB blades on FBL setup. Big deal?
I'm running 710 fb blades on my new FBL setup, and having massive problems that I can't figure out. I was in the thought that the only difference is the blade CG. Is that true? Or wil FB blades on a FBL head cause all sorts of problems?
Skookum Support Rep
Mini Protos SK540,Rave ENV SK540, 4525 LE
Runways are for models and wings are for fairies.
gitbse is offline        Reply With Quote
Old 07-22-2012, 09:43 AM   #2
AmishKyle
I used to run align fb on my 450pro fbl,, never had any issues, maybe when scaled up things change idk
Sent from my Desire HD using Tapatalk
AmishKyle is offline        Reply With Quote
Old 07-22-2012, 10:41 AM   #3
kidphc
Shouldn't cause problems. Fbl are a bit more then just cg, the weight on the chord is a different location.
I've put edge fbl on my 450 and 600. Compared to the align fb blades they felt alot more stable in all aspects of flight. The fb felt a bit more "wild". I was also able to up the gain a bit with the edge blades.
It's hard to describe so if you can ask a buddy to borrow a set of blades and give then a try. It's no different then trying different fb blades. They all fly different, but the true feeling they give can't be described properly with words.
MSR,McpX 250SE, 450SE (pro now) V2 3g,12s Trex 550e
Sold: Trex 500 3g, 600n
kidphc is offline        Reply With Quote
Old 07-23-2012, 09:35 AM   #4
PrivateerConcepts
Generally speaking, no FB baldes won't cause major problems. Yes, the bigger the blade the more the effect. Yes, 450 guys run FB blades with no problems - I do and know others that do. That being said... did you do the simple stuff like check balance and blade set-up. New blades can move the geometery a tad. I actually spaced out once and put a blade on backwards - go it on the test bench though. Measure the new blades against one another. It's very rare but a mis-match may have slipped by.
No one really knows how helicopters fly?? No wonder this has taken me some time to figure out
PrivateerConcepts is offline        Reply With Quote
Old 07-23-2012, 09:40 AM   #5
kidphc
You might get better answers if you list and describe your problems.
Old 07-23-2012, 07:57 PM   #6
audio131
Default fbl or fb
i actually prefer fb blades on my fbl ships, that are faster around center . and dont feel as weighted
audio131 is offline        Reply With Quote
Old 07-24-2012, 02:29 PM   #7
frypan
Registered Users ):>
Agreed! I dont think I'd ever buy FBL blades.
700n
Dan }:>
frypan is offline        Reply With Quote
Old 08-08-2012, 03:01 AM   #8
Iceberg86300
Has anyone tested the stiffness of the fbl blades? Both "wing load" and torsion?
Kind of a stupid Q now that I think about more, but I'm thinking stiffness would be beneficial to all blades, but still subscribe to the fly what works for you philosophy.
Steve
Sent from my Desire HD using Tapatalk 2
Align T-Rex 450 pro v2 g3x FBL (in progress)
Stock except for Hyperion 35A ESC in gov mode
Futaba 7c transmitter
Hyperion 720i NET charger & RDU data logger
Iceberg86300 is online now        Reply With Quote
Old 08-25-2012, 09:04 PM   #9
bad007
Interesting info here, must read. It's all about the foil and COG
http://www.vstabi.info/en/node/74
Align 450Pro 3GX, Align 500 3G
Align 550 3g, Velocity 50 Vbar
bad007 is offline        Reply With Quote
Old 12-20-2012, 12:27 AM   #10
dreich
So you guys are flying FB blades on FBL with no issue? Reason I ask is a lot of the align FB blades for my t-rex 500 are significantly cheaper than their new "3G" blades. Currently I'm running EDGE blades but I just think they're worth the money. You guys haven't experienced any kind of issues? I might buy a set just to see if I can feel a major difference.
dreich is offline        Reply With Quote
Old 12-21-2012, 04:19 AM   #11
Turttle
I purchased an align 500 pro fb heli and converted it to dfc fbl.I purchased a new set of align 3g blades and honestly there the same thing except for the 3g emblem.Maybe they goofed idk but I pute the 3g and regular blade on the ballancer and they both ballance the same and there cg is also the same?Fbl blades are supposed to be a little hevier and the weight should be out a bit more for more stabilization and a more solid rotation geomitry so you dont over work your servos and you can dial in the gyros gain more precisely I believe.
PS.on my 450 I am running thunder power blades 330mm and they work great.
Turttle is offline        Reply With Quote
Old 12-21-2012, 07:39 AM   #12
marc8090
Using Edge FB blades on my Trex 700 fbl with zero issues. Tried fbl blades and absolutely hated them. So there's a little info on a bigger machine.
marc8090 is offline        Reply With Quote
Old 01-12-2013, 12:52 PM   #13
stevembusa
I wouldn't even try it on 700 size. I didn't see nay difference on my 450, either fb or fbl, but on my Protos 500 fbl, if I put fb blade, it shakes like hell. Even I balanced really good, but still makes very unpredictable on the air. It fly, but make very unpleasant and put lot stress on heli. That's why one of my servo burned.
stevembusa is offline        Reply With Quote
Old 01-13-2013, 05:18 AM   #14
johnahamelv
The SmackTalk Rotor Blades video discusses FBL vs FB blades.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is offline        Reply With Quote
Old 01-13-2013, 02:50 PM   #15
toneitdown
after reading the vstabi article and learning the differences between blades and balancing along with COG that helps determine how a blade is going to react . i`ve noticed that that brass sleeve that the bolt goes thru doesnt seem to be an issue ? that distance from where it is inserted to the tip of the blade.
I`m very new to the rc heli world .
toneitdown is offline        Reply With Quote
Old 02-21-2013, 07:11 PM   #16
theflyingman2
Just over a year ago I had a Custom Heli Parts DL 700e and I ran it with the Futaba 750 and actually preferred the Edge 693 FB blades over the FBL blades. It has a more connected feel and made the heli track better I thought.
theflyingman2 is offline        Reply With Quote
