Old 02-10-2005, 04:48 PM   #1
njrcbipes
Default align gyro
I'm new to helis- got a Trex450 full combo; when adjusting gain setting up on the gyro should the TR servo move? also, doing this limits the servo's travel. Not using radio gain, gyro only plugged into #5 slot in rx. with gain set to 0 servo travels normally.
njrcbipes is offline        Reply With Quote
Old 03-23-2005, 01:32 AM   #2
bighands3d
Yes sounds like the old cube style gyros you'll have to set the gain and then adjust the linkage..
How does this unit work.. 1-10
Trex 700N
YS 913DS
Magnum Fuels
JR 11X
bighands3d is offline        Reply With Quote
Old 03-23-2005, 06:04 PM   #3
njrcbipes
Gyro doesn't have 1-10, slotted screwdriver set screw with a - to the left and a + to the right. Been playing with gain setting and linkage setup but can't get enough input to stop heli from spinning with main rotor. Trying to find a heli flyer at one of the local fields to help, but winter just won't quit here in NJ.
Old 03-24-2005, 02:52 AM   #4
bighands3d
I ment scale wise how is it 1-10.. sounds like you need to put a longer arm on your servo to get it to work right.. and make sure you have the pitch slider centered on the tail.. I think your tail pitch slider may not be centered is why it keeps spinning or your head speed is to low.. these micros like a high head speed.
2500-3000rpms..
Trex 700N
YS 913DS
Magnum Fuels
JR 11X
