Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 07-27-2012, 11:59 PM   #1
hijakdgtr
Default F50 swash to bellcranks linkage bending
Hey guys just looking at my Heli and relised my linkages from swash to bellcranks are bent and on both sides,they look very weak to me,the Heli has freshly built and never crashed,my trex 550 have much thicker linkages any ideas?
TREX 700E V2 V-BAR 12S CC120HV-ver 2
TREX 600N-LE OS.55 B320
TREX 600ESP SCORP 4025 1100kv CC100-ICE
TREX 450 PRO-MCXP BLADE - JR-11X-love this
hijakdgtr is offline        Reply With Quote
Old 07-28-2012, 12:15 AM   #2
Slyster
Wow first I've heard of that... other than Rob Cherry insanely beating on his X7. Do you fly VERY hard with high head speeds? I doubt you could find thicker links with the right lengths unless you cut and made your own and somehow add threads. Good question... I'll wait for more replies.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 07-28-2012, 09:43 PM   #3
hijakdgtr
Update,I checked the linkages and found on full negative with aileron the tip of the bell crank touches the linkage "swash to bell crank" rod,so I dremeled 1.5mm off the bell crank end and now looks like it won't bind anymore
Old 07-30-2012, 08:52 AM   #4
BaconRaygun
You sure you don’t have something on backwards? Can you provide a picture?
~Outrage~ Fusion 50 (FB) ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team Boca Bearings****Team LYNX Heli Innovations**
The member formerly known as Vicovaludemero
BaconRaygun is offline        Reply With Quote
Old 07-30-2012, 09:13 AM   #5
hijakdgtr
Here's a pic of the trimmed bell crank it's still close but I don't think it will ever touchClick image for larger version
ID:	336492Click image for larger version
Old 07-30-2012, 10:24 AM   #6
BaconRaygun
IDK man, something is not right, my heli does not have any such issues.
AMA# 977012
Old 07-30-2012, 10:30 AM   #7
airbound
I would have to say something is wrong--I am running 14.5 pos & neg pitches--with no binding what so ever--stock setup--well over 300 flights--no issues .
MQX---TREX 450 PRO FBL---TAROT 450 PRO FBL/AIRWOLF Fuse---FUSION 50 FBL--TDR---Mini-V--Beastx--Full V-Bar --Scorpion -- Kontronic Jive --- Pyro----DX8--Rotormast V-22 Osprey
FLYING IS SIMPLE---NOT HITTING THE GROUND IS HARD
airbound is online now        Reply With Quote
Old 07-30-2012, 11:30 AM   #8
hijakdgtr
It dosnt bind now it was slightly touching before so I ground them
Old 07-30-2012, 05:48 PM   #9
hijakdgtr
It only binded on full neg and ail
