Old 07-31-2012, 04:27 PM   #1
nickypoo
Default quick question lipo or nimh for a transmitter?
about to head to the hobby shop....
should i get a stock 9.6v nimh (i think 9.6) or a 3 cell transmitter lipo?
will the higher voltage damage my dx7? i just got it brand new from my boss. its an old dx7 but i got it new in the box never used
nickypoo is offline        Reply With Quote
Old 07-31-2012, 04:58 PM   #2
Dajavu*Xion
Good question and i look forward to the responces..All i know is that i have run both and only change i can tell is that the lipo last a heck of alot longer bettween charge ups.
Dajavu*Xion is offline        Reply With Quote
Old 07-31-2012, 05:14 PM   #3
Maypole
I've run both on my DX8 and prefer the lipos. By a large margin. Longer between charges as mentioned and surplus power for the vibe/tone timer alert I use.
Nano CP X, mCP X BL, 130 X (Love the little ones)T-REX 500 Efl Pro DFC
Phoenix Sim, DX8, Gibson Les Paul, AMA #987871
I really think this "Internet" thing is going to catch on. You can quote me on that.
Maypole is offline        Reply With Quote
Old 07-31-2012, 06:35 PM   #4
tukkus
If the DX7 isnt made for lipos you can buy a Tx lipo pack and solder 2 diodes together on the battery so the Tx will only see 11.2v fully charged.
I have been doing that for over a year on my JR 9303 2.4 Tx with no problems. You have to take the battery pack out to charge but that is a minor inconvience.
The packs are pretty cheap, roughly $20-25 and the best part for me is that they charge quickly.
tukkus is offline        Reply With Quote
Old 07-31-2012, 07:29 PM   #5
hANDYman
I've been wondering about LiPo's in a TX also... I just got a DX8 which can take a LiPo. So what am I missing here? A LiPo will last longer in the TX between charges, but I thought that you weren't supposed to leave LiPo's charged. It's supposed to be bad for them. What am I missing?
Dx8 / Dx7 (modded)
mCPX (brushless) / FBL 450 PRO (beastX) / FBL 550E V2 (3GX)
TH Edge 540 / 3DHS Extra 300 SHP / Radian Pro
RealFlight 6 / iCharger 306B
hANDYman is offline        Reply With Quote
Old 07-31-2012, 08:25 PM   #6
tukkus
To get a long life out of your lipos the best option is to always keep them at storage voltage but you'll still get years of use out of them by using them like you would normally do in a TX.
Old 07-31-2012, 09:06 PM   #7
pinguin
If your Tx use 9.6v NiCad battery, you can use LiFe battery. The voltage close to 9.6v NiCad batt.
pinguin is offline        Reply With Quote
Old 07-31-2012, 09:14 PM   #8
desertstalker
2 things:
Leaving a LiPo charged increases its internal resistance, this is bad when you are trying to suck 50A from it, not an issue when you only need 100mA.
LiPo's designed for low discharge rates (TXs phones laptops etc.) are damaged much more slowly by being kept full, compared to the high-C LiPos used for flight packs. So the damage will be slower.
You will get several years out of a TX LiPo, or longer, especially if you dont mind that it only holds half what it did when new (for the DX8 that would put it around the same place as the stock NiMH pack at ~2Ah).
-DX8
Old 07-31-2012, 09:42 PM   #9
hANDYman
Cool... good info, thanks guys. I may have to look into getting one.
Dx8 / Dx7 (modded)
Old 07-31-2012, 10:29 PM   #10
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I use Eneloop NiMH packs in my DX7 and X9303. You can use the stock charger and they hold their charge a lot (months) longer than regular NiMH.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is online now        Reply With Quote
Old 07-31-2012, 10:41 PM   #11
RCTada
I use eneloops as well for my DX7SE. All 8 of em!
Sent from my DROID BIONIC using Tapatalk 2
RCTada is online now        Reply With Quote
Old 07-31-2012, 11:58 PM   #12
backburner1955
I use a Hyperion 3S LiFe Pack and get 4x the life per charge as the NiMh pack that came with it, plus no modifications to avoid overvoltage damage.
AMA# 982814
backburner1955 is offline        Reply With Quote
Old 08-01-2012, 12:07 AM   #13
TheBum
Are you saying you can actually use the stock charger? I tried to do that, believing Hyperion's claim that it was safe, and I ended up with two puffed packs: the one I bought and the warranty replacement.
HeliFreak Support
Old 08-01-2012, 12:17 AM   #14
jperkosk
My understanding from reading FMA multi-chemistry charger manual is that LiFe charging is pretty much governed by the same rules as for LiPos, so nope, no trickle chargers.
Jerry
jperkosk is online now        Reply With Quote
Old 08-01-2012, 07:47 AM   #15
TheBum
Hyperion advertises the following:
The pack includes Safety PCM circuits to allow charging inside Transmitter, using standard wall NiMH charger.
In my experience, those circuits aren't as safe as they say.
HeliFreak Support
Old 08-01-2012, 10:39 AM   #16
nickypoo
What is a life pack? They are safer for the tx? Stronger than a nimh?
What about these eneloops? You put them in a 8 AA harness that fits in the stock battery tray?
Old 08-01-2012, 10:49 AM   #17
TheBum
It's a lithium battery of a different formulation than lipos. The full name is LiFePO4 (lithium iron phosphate). The main advantages are their flat voltage discharge curve and nominal 3.3V/cell output, making them especially attractive as a receiver pack for LV servo setups without a regulator. The same goes for transmitter packs because there's less "excess" voltage vs. lipos when used in place of NiMH. They also tend to be less volatile than lipos.
You can do that or get premade packs (or get tabbed cells and solder and shrink wrap your own pack). I have a Radio Shack 8-cell battery holder with AA Eneloop cells in my DX7. In my X9303, I have a premade pack I bought here:
http://store.batteriesamerica.com/sa...eadytouse.aspx
HeliFreak Support
Old 08-01-2012, 11:01 AM   #18
nickypoo
Life or Sanyo?
Old 08-01-2012, 11:18 AM   #19
TheBum
Life or Sanyo?
My link is to Sanyo packs. I don't trust lithium of any sort in transmitters anymore.
HeliFreak Support
Old 08-01-2012, 11:23 AM   #20
lotus7
MMV.
I have been using the same lipo in my DX7 since end 2007. I never discharge more than 3,8V and never charge inside the tx . Same goes for my 2 sons
Lotus7
Compass 6HV
Compass 600E
lotus7 is offline        Reply With Quote
