Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 07-31-2012, 09:48 PM   #1
brw0513
Default Diesel Engine in a Heli
I wish I could ask this question without displaying my complete lack of knowledge on the subject i.e. looking dumb. Then again, I'm getting to an age where I just don't care any more.
Why don't we have a diesel engine, instead of a gas or glow variant, in our helis?
Is there an OS91 form factor engine that is a diesel? Or could an OS91 be converted?
Is diesel fuel for this application a mix of kerosene and ether or something else?
Is this diesel engine a bad idea for some good reasons?
brw0513 is offline        Reply With Quote
Old 07-31-2012, 09:53 PM   #2
poor_red_neck
Isn't a glow engine technically a diesel? Relying on the compression to ignite the fuel.
I've seen vids of a few plank motors running on diesel, but I doubt the performance was anywhere close to a nitro blend, and therefor doubtful to work on a heli.
Sent using TapaTalk on my HTC Evo 3D
Please excuse spelling/grammatical mistakes due to fat thumbs.
Blade 130X - Stock
mCPx Brushless Stretch (125mm) - WK10A - 11000kv Inrunner - 550 mah - Full CNC Upgrades
Logo 400 - Parting Out - Need parts PM me.
Retired Helis - Outrage 550, Trex 500, Others
poor_red_neck is online now        Reply With Quote
Old 07-31-2012, 11:12 PM   #3
desertstalker
The power to weight ratio of a diesel engine is not great, even the modern high-pressure injection ones used in cars. I dont think you could build one light enough (with the power needed) to perform well on a heli, at least not with the current tech.
If you want to burn diesel in a heli, your going to need to use a turbine, AFAIK they can run on diesel as well as kero.
Not sure why diesel though, petrol is not exactly pricy at the quantities needed for helis, nor are flight times a particular problem (I am sure you could put a couple of hours worth of fuel onto a heli if you were not concerned about acrobatic performance.
-DX8
Old 08-01-2012, 01:33 AM   #4
brw0513
I'm talking about a glow engine converted to run on diesel.
The power to weight wouldn't equal nitro, but how would it compare to a Zenoah gas engine?
Old 08-01-2012, 02:25 AM   #5
Rc Zombie
Davis diesel was a company in the 90's that offered conversion heads I do know some of them ended up on YouTube but I can't attest to the performance they may still be around though
Sent from my LG-MS910 using Tapatalk 2
Rc Zombie is offline        Reply With Quote
Old 08-01-2012, 03:28 AM   #6
acrow
A better explantion perhaps is this: Diesel engines are so named due to the fuel used.
The term compression ignition is used if there is no sparking device used once the motor has been started. So on that basis, both nitro engines and diesels are compression ignition.
Regards
Acrow
acrow is offline        Reply With Quote
Old 08-01-2012, 08:53 PM   #7
4 stroke flyer
i had an interest in a diesel myself. I talked to some people who tried it, they all said power was excellent. But the constant tuning problems was a nightmare. I never tried it myself. for once I took the advise....... that does not happen often
4 stroke flyer is offline        Reply With Quote
Old 08-02-2012, 03:44 AM   #8
Burt37
Acrow
http://en.wikipedia.org/wiki/Rudolf_Diesel
Maybe this is the reason why it's called Diesel....
Burt37 is offline        Reply With Quote
Old 08-03-2012, 03:13 AM   #9
mcfast
"Isn't a glow engine technically a diesel? Relying on the compression to ignite the fuel."
NO ! glow dose not use compression ignite the fuel, it uses a glow plug to ignite the fuel, the glow plug stays white hot all the time the engine is running. plus the compression is way too low for it to run like a diesel.
mcfast is offline        Reply With Quote
Old 08-03-2012, 10:30 AM   #10
Elgyn
If you raise the compression and nitro level you can get them to "diesel" but the pressure in the combustion chamber would be too much and you have to replace the motor after a few seconds. eg: Top fuel dragsters.
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
Old 08-04-2012, 07:42 AM   #11
jockstrap
I remember the old Diesel model engines... havn't seen any around for a long time..
Most were smaller size that I've ever seen..
Instead of a glo plug they had a wrench at the top that you tuned them with - adjusting the compression to get them to run smooth.
DX7 Mode-1 | T-Rex 250 | EP200SE V2 | Tricopter | Quadcopter
450 pro 6s fbl 3X1000 | 450 pro fbl beastx | Schweizer 300C Gasser Scale |T-Rex550e 600 vbar | Aeolus 50
HeliX T-Rex700 fbl Gasser | HWC600 321puh Gasser fbl| Henseleit TDR
jockstrap is offline        Reply With Quote
Old 08-04-2012, 11:43 PM   #12
ngin
Diesel R?C engines can produce a lot of power (RPM x Torque), and do so at much lower RPM because they rpoduce so much more torque at this lower RPM. That is why they are also so fuel efficient (just as they are in todays advanced deisel engines that we find in European cars).
Unfortunately, the gearing of even the gasser helis that we have in play today, are not ideal for taking advantage of this type of power delivery.
But who is to say that some may not be developed in the future to do so
ngin is offline        Reply With Quote
Old 08-05-2012, 06:00 PM   #13
desertstalker
The are more fuel efficient because of the higher compression ratio, and for the car engines its not so spectacular a difference anyway (compared to a similarly sophisticated petrol engine. Keep in mind that diesel has ~20% more energy (per L) in it than petrol.
The really large diesel engines (ships, locomotives, generators, etc.) are very efficient but are also quite heavy (power to weight ratio) and operate at very low speeds.
-DX8
Old 08-06-2012, 05:12 AM   #14
Azalin
I wonder if small engines can be boosted with small turbochargers!
http://www.youtube.com/watch?v=
Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler | JR x9503
Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | Brain | GV-1 | Stock Zenoah G290RC | RJX pipe | JR x9503
Azalin is online now        Reply With Quote
Old 08-06-2012, 10:18 AM   #15
Doug Darby
Yes Turbo kits are available. I worked in one on a Traxxas truck with a 3.3 nitro motor. I am not sure if there is one out there for a Zenoah! I would bet some ingenious modeler has built one.
I just spent 4 days flying in The Denver area in the foothills of the Rockies and with the field being at 6000 ft elevation I sure could have used one. The 18% loss of power was very apparent with my 270. I just reduced the pitch a degree and it helped.
doug
Doug Darby is offline        Reply With Quote
