| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
any 1 now why logo 600 tail vibrate.
You should give us more details in order to understand better.
Vibration could be a lot of things.If is a wag, check first the belt tension, Mine, as soon as the belt is bit loose, keep wagging.. Chris
Logo 600 3D MiniV 5.3 Pro SAB Goblin 500 MiniV 5.3 Pro Rigid 480 6S Beast X MCPX BLS |
thanks.... what i mean , in normal mode i c it not vbrate.. in idle 1 get vbrate. aim using 85% throttle. it sit because tail blade. using align tail blade..
reduce the tail gyro gain
Vibration or wag? If its just vibration and you get a buzz when you reach a higher RPM, your tail blades could be out of balance, or even the tail shaft could be bent.
Wayne To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Logo 600/ Logo 600se/ Logo 700 |
#6 |
#7 |
I'm having the exact same isssue with my 500se. I just swapped the tail bearings and shaft.Get the noise and everything.It's so bad that when I go from normal to idle up that it sends the mini Vbar into a tizzy and it dives to the left hard.Have almost crashed it because of it.I've lowered the thottle curve down to 65 percent just so I can fly it. I know it's headspeed related because when i'm doing a powered decent and have my collective like i'm doing an auto and the headspeed rises the problem show it's ugly face. I'm pretty sure the hub grip assembly is out of balance as when i spin the tail with the belt disengaged I can feel the vibration "no blades" and yes I have tried 3 differant sets of tail blades. Has anybody retro fitted an align tail hub assemby to the logo before with success.
Trex 700e Trex 600nsp Trex 450pro Eflite 400 Trex 250 |
#8 | |
mr nemisis... try open the main blade and give some throttle , care fully see the head. |
