Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 08-06-2012, 05:03 PM   #1
QYT001
Default 700FL main shaft instead of 700 main shaft for FB heli?
700FL main shaft is 7 mm shorter then 700 main shaft for FB
Is anyone used 700FL main for FB machine?
T-Rex 700N: JR DS8717HV; Vbar 5.3+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG; OS MAX 91HZ-R
T-Rex 700E: JR DS8717HV; Spartan Quark + Outrage BL9188HV; CC ICE HV 160A; RCM-BL700MX (470KV); WR Super BEC
T-Rex 250SE 350Watts
QYT001 is offline        Reply With Quote
Old 08-07-2012, 01:47 PM   #2
weaselbean
I personally have not I would think you won't be able to get much pitch range with the standard FB shaft and my helicopter fly barred I could barly get +/- 13deg If you are happy with +/- 10deg you might be able to pull it off?
"Quit crying about your airplane and fly it already!"
weaselbean is offline        Reply With Quote
