Old 08-08-2012, 07:11 AM   #1
SynergyAero
Default Manual for new 450 Pro DFC kit?
Has anyone seen a pdf of the manual for Align's new T-Rex 450 Pro DFC Super Combo? Its part# KX015087.
Thanks!
Cris
Cris Trebbi
Ci+izen #012
SynergyAero is offline        Reply With Quote
Old 08-08-2012, 07:00 PM   #2
Euwan
Subscribed
Waiting for something special
Euwan is offline        Reply With Quote
Old 08-09-2012, 06:04 AM   #3
JoeW
Align doesn't have it posted yet. It's usually up on their site shortly after the kit actually hits the streets.
I'll keep an eye out for it though.
TRex 250 DFC | TRex 250 DFC (Scale)
2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale)
TRex 550 DFC
DX8 + Telemetery on all
JoeW is offline        Reply With Quote
Old 08-10-2012, 03:47 PM   #4
350Z_Al
What do you need?
It's really not much different than the 3GX PRO.. Just use that manual, it will get you 95% of the way there.
Assembling the DFC head, and the new tail linkage assembly is pretty straightforward. If you've done an Align heli in the past, you won't need the manual.
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote
Old 08-10-2012, 04:19 PM   #5
Euwan
I need to find out if the new bearing blocks will fit in the v1.
Sent from my Nexus 7 using Tapatalk 2
Old 08-29-2012, 03:22 PM   #6
Dipweed
Talking
Same here
HD pics on the 450 Pro DFC would be nice
I need to see the new wire placement
And
I would like a view of the split Al block
And
Tail
And
Plz
Someone scan the 3 or 4 manual pages that show those parts.
I have 3 Align's but they are the older Pro's. I have wired one like the new 450 Pro DFC
But
The servo wires are just to cram close to the gears.
I would like to C how Align fixed that.
Align&HK450 L/470L/150 DFC/Blade stuff
DJI/AR Drone
Dipweed is offline        Reply With Quote
Old 08-29-2012, 05:21 PM   #7
Euwan
Here we go it has now been listed on the Align site
http://www.align.com.tw/shop/product...oducts_id=4505
Old 08-29-2012, 07:49 PM   #8
Dipweed
Cool On Order
On order
But
Again I would hope someone could scan their manual so I could at least have the install pages.
DJI/AR Drone
Last edited by Dipweed; 08-30-2012 at 11:02 PM.. Reason: Change to reflect post orginal content.
Old 09-02-2012, 02:40 PM   #9
Dipweed
Exclamation Viral sight
Order a 2nd 450 Pro DFC head block.
But
I still would like manual or pages on Head block servo wire install!
DJI/AR Drone
Last edited by Dipweed; 09-03-2012 at 06:15 AM.. Reason: seller loads a virus on your computer but is off subject of post.
Old 09-02-2012, 03:33 PM   #10
felborn
Shame Align cant keep a bloody webpage updated, been looking for it for weeks
Nano CPX, 130x, Trex250,
SAB Goblin 380, 500 & 700
Oxy3
- Lynx Team Pilot -
felborn is offline        Reply With Quote
Old 11-09-2012, 12:28 AM   #11
mrmarc
Was looking for this earlier, too, and just ended up scanning my 450 DFC upgrade set manual.
EDIT: Oops, I just realized you wanted it for something regarding the bearing blocks. This is just for the head. Sorry.
♫ It was 96 in the shade... ♫
Trex 450 DFC - 6S at last! Now to stretch her out
VWINRC Align Tarot Turnigy KBDD BeastX
mrmarc is offline        Reply With Quote
Old 11-09-2012, 11:30 AM   #12
Sailman
Maybe it can help here is the manual for the 450 plus DFC on align web site
http://ms.align.com.tw/mpeg/manuals/...n%20Manual.pdf
Align 450 pro DFC
Blade mCP X v2(dual BL,SPIN 16k and HK 12K, DFC head and swash from Lynx)
DX8
Sailman is offline        Reply With Quote
Old 11-09-2012, 08:20 PM   #13
Snowboard_Nut
Talking DFC bearing blocks do fit V1 Pro.
Direct fit. And what a blessing they are, trust me! Pinion adjustment is a snap now, only have to remove 5 screws on the front piece of the block assembly and both servos slide right out as a single unit and can hang off to the side if you plan your wiring properly with just enough servo lead to hang off the side. Another plus for us that have servos with mounting holes that are larger than the mounting screws is that before with the old blocks, once you removed the servos, they never go exactly back in the same spot which equates to up to a 1mm of variation in the servo-to-swash linkages. With these blocks, that is no longer a problem. Another plus is you don't lose your main shaft alignment in the bearings once you do the "Drop the main shaft in with no head on it and it should fall through the bearings under it's own weight test". The best $17.99 I ever spent. On a Pro V1 frame, you will need sand/cut the frame just a little for the elevator servo lower mounting screw to clear the frame since the elevator servo will now bolt in from outside the bearing block instead of being sandwiched between it. What I did was used a file and elongated the servo vertical cutout in the frame at the bottom where the lower mounting screw goes until i filed into the existing hole. Once I was partly into that hole, i then took a round tapered file and filed down against the edge i just filed down until i opened the existing hole up into a bigger radius to accomodate my washer and mounting screw to easily pass through. You COULD buy a new frame side, as they have changed the design just a little by bringing the frame a little closer to the main gear to make up for the servo cutout being a little deeper. I have had no ill affect of removing that material, as once the blocks are tightened down to the frame they become a single load-bearing unit anyways. I could try to take pictures of my wiring scheme if anyone is interested, not sure how well my camera would do a macro closeup though, but i'd be willing to try if anyone asks.
Went ahead and added pictures for anyone interested:
https://www.dropbox.com/s/uufm2e6gm0ofwrq/DSCF0834.JPG
https://www.dropbox.com/s/4ydi04k1r12xchy/DSCF0835.JPG
https://www.dropbox.com/s/dnx94vqzkvpczg7/DSCF0836.JPG
https://www.dropbox.com/s/i3aqssp01ao70af/DSCF0837.JPG
https://www.dropbox.com/s/pza7jqbmedy8nk3/DSCF0838.JPG
https://www.dropbox.com/s/5r2ccx8yqhxzaz6/DSCF0839.JPG
https://www.dropbox.com/s/9kenqa2kqp8qge9/DSCF0840.JPG
By the way, how do I Embed an image rather than just inserting links to it?
Snowboard_Nut is offline        Reply With Quote
Old 11-10-2012, 01:58 PM   #14
dct
The link times out or doesn't work for to 450 pro DFC manual ..
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote
Old 11-11-2012, 02:48 PM   #15
DudeInMyrtleBeach
Worked for me, but took a long time.
... and just noticed that it's the wrong manual. it's for a 450 plus dfc with a belt tail.
DudeInMyrtleBeach is offline        Reply With Quote
Old 11-26-2012, 09:14 PM   #16
satgod
manual took a long time but it did work
might have just timed out for you try to refresh
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote
Old 03-03-2013, 02:00 AM   #17
ronlund
Default 450 Pro DFC Manual
http://www.ronlund.com/rcheli/SUPPORT_MANUALS.html
www.ronlund.com
800-321-9909
ronlund is offline        Reply With Quote
Old 03-03-2013, 06:59 AM   #18
Chep
Thanks, Ron! This helped me realize the 2X8mm collar screws for the tail links were short. Big design flaw!
T-Rex 700 HV DFC, Logo 550SX, Logo 480Xx
JR Forza 450, G380, OXY 285
I'm proud of my crashing skills!
Chep is offline        Reply With Quote
