Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 08-15-2012, 09:38 PM   #1
enzo b a
Angry hp06v2 unbalanced
hello my hp06 is too unbalanced, high-frequency vibrations have I think is to blame for all my problems tail.
try to balance it with tape but it was a failure ..
I'm about to buy another hp06
enzo b a is offline        Reply With Quote
Old 08-16-2012, 02:00 PM   #2
dbennettya
I've balanced several HP08 motors and it is a trial and error process with tape. Sometimes the bell can be a little wobbly from shipping damage. I have straightened out a wobbly HP08 bell using a runout gauge and fixture. Then tweek the struts slightly to get the runout to zero. Try running the motor slowly in the frame without it contacting the main gear to balance it and see if it is woobly or not.
Good Luck, Don
dbennettya is offline        Reply With Quote
Old 08-16-2012, 03:05 PM   #3
Dylwad
Or contact the place you bought it from, oversky is pretty good about taking care of factory defects.
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote
Old 08-16-2012, 08:42 PM   #4
enzo b a
acquired it in http://astroid-designs.myshopify.com/ : Lol:
I have problems with the tail (rebounds) with less than 79% throttle.: Thumbdown:
I'll upload a video
Old 08-17-2012, 01:10 AM   #5
Dylwad
I'll upload a video
Shoot them an email about it
Need more info on your setup to troubleshoot the tail, but its most likely vibe related if linked to headspeeds.
Old 08-17-2012, 02:53 AM   #6
enzo b a
my confi: 3 in 1 v1, xp-12a blheli 4.1, hp06v2 9t , rame stock + Carbon lower frame brace + cage, sr-120 tail + rrc 65mm, canopy xtreme and landing gear xtreme.
at 70% throttle it seems blender sounds pretty ugly: : Slap:
Old 08-17-2012, 11:10 AM   #7
jmisuraca
I am running the xp-12 + hp06v2 + 9T, in a MH "X" frame, with a BL Tail.
I had issues at 70%. My bird likes the higher head speed, try running it at 80%, 85%, 90% and 95%. Mine likes 90-95%.
I was thinking of moving to a 8T, I have one and a pinion puller just been a bit occupied with the 130x (not fixing, but flying).
T-Rex 500efl
Mini Protos 6s Stretched
2x 130x (hp08 xp-12 10T, hp10s xp-12 10T)
jmisuraca is online now        Reply With Quote
Old 08-17-2012, 12:19 PM   #8
enzo b a
then the point of having Governor if they can not run speeds below
Old 08-17-2012, 12:23 PM   #9
coredump
The governor try to give constant HS. The motor don't want to run too slow,
it will have high current due to the slow speed and result is less efficient
motor. In otherwose, the governor can help reducing bogging.
MCPX HP05s/HP03T Xtreme Frame (Beater)
MCPX HP06v2/HP03T MH X Frame (Precious)
MCPX HP08/HP03T MH X Frame (Grounded)
MCPX stock DIY firmware (Experimental)
coredump is offline        Reply With Quote
Old 08-17-2012, 01:56 PM   #10
jmisuraca
+1.
T-Rex 500efl
Old 08-18-2012, 12:49 AM   #11
fusionsx00
im in the same boat with the hp06 vibrations
ive already isolated the problem down to the motor, i have 5 other motors
my 2 spare hp05s run perfect, my spin motor , heck even my old worn out walkera inrunner
so i wanted to make sure 100% it was the motor, i had a extra shaft already and ordered a 2nd spare now.
if i cant balance it with the brand new shaft installed, it will get the shaft
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is offline        Reply With Quote
Old 08-19-2012, 07:33 AM   #12
enzo b a
many people do not understand how you can run lower speeds and this even tic-toc, no tail blowouts (used hp03t)
tail bl makes the difference?
Old 08-19-2012, 09:16 AM   #13
jmisuraca
My hp06 is smooth. No probs at all. Have about 125 flights. Now my hp05 is my trouble bird. It's has vibes and is my hanger queen.
T-Rex 500efl
Old 08-19-2012, 11:37 AM   #14
enzo b a
I surrender .. I'll buy another hp06v2.
Old 08-23-2012, 02:01 AM   #15
fusionsx00
well my problems are solved thanks to dylan astrioddesigns.
i ordered a new shaft and pinion, i got it over the weekend.
he didnt have to give me another bell, bit after installing it. my hp06 is back to new.
dylan we need more people like you in this business
Old 08-23-2012, 02:43 AM   #16
Dylwad
Ill send you another bell with the order you just made
Old 08-23-2012, 02:44 AM   #17
Dylwad
Thanks!
I do what I can
