Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 08-16-2012, 12:27 AM   #1
chris982
Default Voltage Step Down BLS251
Has anybody use a step down for their BLS251? If so, how did you configure your wiring? Was it neat or did it take up more space than planed?
chris982 is offline        Reply With Quote
Old 08-16-2012, 01:46 AM   #2
CyprusFlyer
Advice is don't bother with a step down, do not use it myself and reports of others using for years at 5.6 -6v and no ill effects. Also rational is that fully charged batteries used of old reached those voltages anyway.
TREX 550E
LOGO 500SE & 600SE & 600SX
Synergy E7
zzzzzzzzzzzzzzTDR
CyprusFlyer is offline        Reply With Quote
Old 08-16-2012, 01:53 AM   #3
ChrisH
BLS251 are rated for 6V, use them at 6V.
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is online now        Reply With Quote
Old 08-16-2012, 07:56 AM   #4
Chris Sexton
I am running 3 of these at 5.6-6V no issues at all. As stated, they can handle 6v. The speed specs are for 4.8v but it's cool.
Team Synergy/Team Scorpion
Chris Sexton is online now        Reply With Quote
Old 08-16-2012, 08:37 AM   #5
chris982
I understand this but the specs say 4.8V. Wouldn't this cause a servo failure in the long run? I brought the step down but won't have any place to put it. So, I'm going without but don't want to crash the chopper. Why is it rated at 4.8V if it can do 6V?
Old 08-16-2012, 09:15 AM   #6
jockstrap
It's to do with the 4.8V ratings referring to older nicad battery packs which, when fully charged were approx 6V rather than the nominal rated 4.8v ..
A bit like a car batt rated at 12v but is actually 13.8v
DX7 Mode-1 | T-Rex 250 | EP200SE V2 | Tricopter | Quadcopter
450 pro 6s fbl 3X1000 | 450 pro fbl beastx | Schweizer 300C Gasser Scale |T-Rex550e 600 vbar | Aeolus 50
HeliX T-Rex700 fbl Gasser | HWC600 321puh Gasser fbl| Henseleit TDR
jockstrap is offline        Reply With Quote
Old 08-16-2012, 09:21 AM   #7
chris982
I think I can live with that.
Old 08-21-2012, 03:11 AM   #8
TommyBear
Regardless of what people say. I would still use the step down diode on the BLS 251. I have been using BLS 251 on my TDR, T700 and Logo 600SE with step down.
Silverline VBAR 5.3 PRO : TDRs - LOGO 700 XXTREME 600SX 600SE - Whiplash - FAIFA SRIMOK
TommyBear is offline        Reply With Quote
Old 08-21-2012, 03:50 AM   #9
geekindenial
I use the Align two way step down to step down from 6v. Cheap and works.
geekindenial is online now        Reply With Quote
Old 08-21-2012, 04:27 AM   #10
CyprusFlyer
Personal choice of course, but another point of failure in the way when the servo will run happily on 5.6 - 6v is not one for me.
TREX 550E
Synergy E7
zzzzzzzzzzzzzzTDR
Old 08-21-2012, 04:43 AM   #11
Dumbthumb75
+1.
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T
Futaba 2.4 GHz
Dumbthumb75 is offline        Reply With Quote
Old 08-21-2012, 04:44 AM   #12
chris982
I just returned my step down to amainhobbies. I didn't see Jan using it per the manual.
Old 08-21-2012, 01:46 PM   #13
ChrisH
It's not "what people say" ... it's what the manufacturer specs
http://www.mhm-modellbau.de/pdf/tech...rvos-robbe.pdf
Edge Rotorblades
450 Pro V-Bar
130X
Old 08-21-2012, 09:38 PM   #14
chris982
So, I need to reorder the the step down? I just don't see where I can put it on the TDR.
Old 08-21-2012, 11:29 PM   #15
ChrisH
NO, the BLS251 is rated to 6V on that spec sheet from Robbe (Futaba Europe).
Edge Rotorblades
450 Pro V-Bar
130X
Old 08-22-2012, 12:32 AM   #16
jhunter
I'll give you a step down if you want one but I have well over 100's of flights on bls 251's at 5.6 of the jive.
TDR, Srimok N x 2, Banshee 31, avant aurora, Dune!
jhunter is offline        Reply With Quote
Old 08-22-2012, 07:55 AM   #17
jointer
I had 700 flights with BLS251 at 6V from Jive - do not worry, it is working just fine.
(i must say, better then the Outrage i have now)
- TDR #2, 4525LE, YGE 160HV, MKS HBL950 (JR MP82S=crap), Outrage BL9188, Gryphon Quasar, silver Vbar + 2x sat, 12S Billowy 50C 5200mAh, Radix V2, EDGE 105mm, DX7
- TDR #1 sold (standart setup, 700+ flights)
- HPI e-Firestorm FLUX, Spektrum DX3S
jointer is offline        Reply With Quote
Old 08-22-2012, 03:11 PM   #18
chris982
Thanks! I should be getting my kit shipped next month.
