Old 08-17-2012, 04:12 AM   #1
fourbie
Default Carbie screws on OS engines
Has anyone tapped the screw holes on the OS Engines to take a larger bolt/screw? It is currently about M3 and I want to open it to M4. I'm thinking of going to button head allen bolts.
It will mean having to open up the body holes to 4mm - should be easy enough to drill out , and re-tap the carbie threads to M4; I'll be drilling to approx 3.3mm then tapping.
Have a great day - John
"Do it to them before they do it to you" {Hill Street Blues}
When the blue light is flashing I am kidding. E&OE.
fourbie is offline        Reply With Quote
Old 08-17-2012, 05:53 AM   #2
burntclutch
Why ???
Whoever invented the term “foolproof” underestimated the ingenuity of fools.
burntclutch is offline        Reply With Quote
Old 08-17-2012, 06:03 AM   #3
fourbie
Originally Posted by burntclutch View Post
Why ???
Thought you'd never ask!!
The existing screws got very loose. In fact I have now lost both and yes, I did threadlock them. I have some M3 but they are loose. I know I can use strong threadlock ................and I did time before last and boy were the screws hard to release, so hard I messed up the cross head on one. So I used Loctite last time and guess what!
I have a lot of M4 in all shapes and lengths so are plentiful and being allen headed will remove more easily when I use the strong threadlock.
Old 08-17-2012, 06:32 AM   #4
burntclutch
O.k ,as in principle i see nothing wrong , but to be on the cautious side , have a close look why OS decided on M3 , I am sure it is a engineering decision and not some pinhead that decided that M3 fly better in the wind
Old 08-17-2012, 07:29 AM   #5
fourbie
Indeed, I think you could be very right but it's more a matter of keeping the engine in service and the current size of screw isn't cutting it.
Old 08-17-2012, 07:43 AM   #6
YoungBull
You seem to have good knowledge just do it.
Also you start alot-alot of threads and answer them yourself.?
No pun intended,not that type of person, just board.
450 se, 450 v2, using Jr 2610.
550e 3GX , Dx7, 1 sat. RF6, Redback LiPo's.
600efl Pro, 3GX, bec, Castle HV80, 2 sats.
YoungBull is offline        Reply With Quote
Old 08-17-2012, 12:39 PM   #7
fourbie
What I am looking out for is if someone says don't do it and tells me why. I've never done this before and am thinking out loud rather than answering my own post.
Old 08-17-2012, 11:04 PM   #8
clough42
I do that all the time. My family hates it.
Blade 4503D ZYX-S Tarot DFC
mCP X v2 BL HP05s/XP-7A/twin coreless
clough42 is online now        Reply With Quote
Old 08-18-2012, 03:06 AM   #9
fourbie
Which, thinking out loud or waiting for a "No don't do it"?
Old 08-18-2012, 09:41 AM   #10
clough42
Thinking out loud. I talk through the pros and cons of the options. Drives my son nuts. He just wants the answer given to him and he thinks I'm changing my mind over and over.
