Old 09-03-2007, 03:34 PM   #1
scoter12@msn.com
Default hs-65hb or 65 mg?
what one is the best for the rex?
scoter12@msn.com is offline        Reply With Quote
Old 09-03-2007, 03:53 PM   #2
txflyer
hands down the 65mg
trex 450 sa 70% converted to se
401
9650
3x65mg
eflite 40amp dual bec esc
ar6000
430l
txflyer is offline        Reply With Quote
Old 09-03-2007, 04:19 PM   #3
rabidguineapig
65MG all the way
T-Rex 450SE V2- HS-65MG's, 401+9257, 430XL 11T, evo 25, evolite, Stiffies
GO SABRES!!!!!!!!
rabidguineapig is offline        Reply With Quote
Old 09-03-2007, 04:27 PM   #4
scoter12@msn.com
thanks guys
Old 09-03-2007, 05:01 PM   #5
Street Flyer
Well it depends on how often you crash. For example, I hardly ever crash because I don't try stuff I know I can't do. So the HS 65HB servos work for me, but for the normal flyer they will need 65 mg servo.
t-rex xl cde
t-rex se V2 with scorpion -8
t-rex 600n
t-rex 700n
Street Flyer is offline        Reply With Quote
Old 09-03-2007, 05:03 PM   #6
Street Flyer
Also the mg servos aren't full proof. The MG servos do have a plastic gear in them as a fail safe.
You know something has to break, but changing out the gears in the servos is a pain, so go with the MG servos.
t-rex xl cde
t-rex 600n
t-rex 700n
Old 09-03-2007, 05:35 PM   #7
flyboy320
If you have the 65HB, can you convert them to 65MG?
flyboy320 is offline        Reply With Quote
Old 09-03-2007, 05:50 PM   #8
rabidguineapig
Yep, you can buy the gear sets here:
http://www.readyheli.com/Hitec_HS65_.../hs65mgset.htm
They have fast shipping and good customer service
GO SABRES!!!!!!!!
Old 09-03-2007, 08:55 PM   #9
bugdozer
The first gear is a plastic gear but it's not a fail safe but more to isolate the motor from the metal gear train. Suppose to keep noise/interference down or so I've read.
bugdozer is offline        Reply With Quote
Old 09-03-2007, 09:16 PM   #10
jeffros1805
My 65mg stripped after a minor crash, took back off and ended up crashing hard (didnt know it was stripped).
still rebuilding after 1 1/2 weeks and $100+
Jeff
Trex 450 SE V2
Futaba 6EX 2.4
Gy401 + S9650
Hs 65s
BC6, FP evo 2500
(rebuilding after the big one)
jeffros1805 is offline        Reply With Quote
Old 09-03-2007, 09:22 PM   #11
najones
I just made the conversion from HB to MG. I got the gears and servo grease from servocity.com. The gears were 12.95 each and 3.99 for the grease (which looks like I could rebuild many servos with this little container). Shipping was 5.95, and I received them very quickly.
najones is offline        Reply With Quote
