Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 09-06-2007, 09:41 AM   #1
pilotwi
Default Why -3 degree pitch?
Why is the pitch set at -3 degrees when the throttle is closed?
pilotwi is offline        Reply With Quote
Old 09-06-2007, 12:06 PM   #2
borocouncilman
You want a little negative pitch available so you can get the bird to the ground in windy conditions. It's always good to have a little negative available to you in normal flight mode.
AMA #890682, Spektrum DX7/6100
T-REX 450 - SA Frame, V2 head/tail, Align 430L/ESC, GY401, JR DS285, JR DS3400G, Gorilla Gear
HB King V2 - Esky BL 3100kv/25A ESC, E-Flite S75 (head), HiTec HS-56HB(tail), G90 Gyro, 1800mah LiPo
Blade CX2 - Something to fly inside on rainy days
borocouncilman is offline        Reply With Quote
Old 09-06-2007, 02:03 PM   #3
ev0l
Yup if its windy the thing will still climb even though you have let off the throttle. With the slight bit of negative in there you can "pull" it back down from the winds grasp. I have had to kick mine up into idle 1 to bring it down before because the -3 in normal mode was not enough. Granted I probably should not have had it up in the first place in that much wind.
ev0l is offline        Reply With Quote
