Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 09-03-2012, 07:52 AM   #1
gazaflex
Default Bee V2 main shaft replacement tip
Hey all,
In my travels around the forum I've noticed a lot of people complaining about difficulty replacing the stock main shaft on their bees, having to split the frame and all, or trying not to destroy components trying to remove the pin that locates the main gear on the shaft. So I had a tinkering brainwave last night, and managed to easily remove the small pin using a walkera pinion puller to push it out. I then opened the hole up very slightly using a round needle file so the pin is snug enough to stay put while installing a gear, but loose enough to pull out with pliers when needed. Anyway I thought I'd share my minor victory, has certainly removed a lot of the pain from shaft maintenance!
Cheers..
Gaza
gazaflex is offline        Reply With Quote
Old 09-04-2012, 10:55 AM   #2
Luke Warmwater
Nice one!
Tips like that are always welcome around here....you certainly know how to make friends....lol
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote
