Go Back   HeliFreak > Multi Rotor Support > Props-Duration, Performance, Stability
Props-Duration, Performance, Stability Props-Duration, Performance, Stability
Old 09-08-2012, 12:51 AM   #1
helionfire
Question gemfan props
i bought some gemfan 9x 4.7 props for my flamewheel 450, had to drill them out to fit the motors,put them on and when i did a test flight it was pretty stable but when i put it in atti it just kinda went up and down and would not hold its height. i used a drill press to open up the holes and the props were a nice snug fit, i also tightened the prop nuts firmly so i dont think the props are slipping. could this be because i didnt balance the props?
helionfire is offline        Reply With Quote
Old 09-08-2012, 11:00 AM   #2
Stumblebee
I use 10 inch Gem Fans on my F450. I have not had your problem. When I installed mine, instead of drilling out the props, I used a prop reamer to cut the 8mm hole. I did all four props in less than ten minutes by hand. From what you have described, I would try a few more flights and see if you are having a consistent problem or an intermittent one. I say this because I ran into the up and down thing a couple of times when the weather was unsteady and the barometric pressure was bouncing all over the place and the wind was coming from a variety of directions.
MQX Quad,Align 550E/NazaH/GPS,Align450 Pro/CPII, Flame Wheel F450 Quad NazaM/GPS/GoPro3, Blade 350 QX/ GoPro3
Never lend money. It causes amnesia.
Stumblebee is offline        Reply With Quote
Old 09-08-2012, 02:55 PM   #3
petedee
What gain settings are you using?
I am using the same props but with 5mm prop adapters on 2830 motors I do not need to ream the hub.
Always balance both your prop and your motors, it may be causing just the right vibration to upset your Naza.
Pete
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote
Old 09-08-2012, 07:01 PM   #4
helionfire
pitch 95 roll 95 yaw 120 vert 180, attitude gain 120, and actually i dont have a prop balancer, any recommendations where to get one? and im not sure how to balance the motors
Old 09-09-2012, 09:09 AM   #5
Stumblebee
I've been running those same numbers since July. No problems so far.
Old 09-09-2012, 05:59 PM   #6
TioDave
I ran some 8" gem fans on my f450, but I had to rheem the hub down to 2mm thick. I heard the larger ones fit better. I tried some graupner 9" e props. The 9" was to big with 4s. Now I'm running the APC 8" SF with great results. They needed to be rheemed and balanced, but I have the highest gain I have run with so far. It might just be the best balance from practice.
Youtube Tiodave.com
TioDave is offline        Reply With Quote
Old 09-14-2012, 12:59 PM   #7
Dumb Thumbs
I've had GemFan reinforced 10x4.5 props fail on me in flight three times to date. Just today I was out flying with a small onboard vid camera. No props broke, but watching the vids later I heard the props balking when moving the quad around at a moderate clip or when the wind kicked up. I can only guess that the blades were flexing, and given time would break.
I'm not saying GemFan props are bad props, Just that my Quad (NextLevel 650 with 3 cell 5,000mAh batt and a camera) might over stress the GemFan's.
Got myself some Graupner's on the way and I'll see what happens.
Dumb Thumbs is offline        Reply With Quote
Old 09-15-2012, 12:32 AM   #8
Stumblebee
In my limited experience, this is the first time I have heard of a Gem Fans failure, much less three. I can't say I know much about NextLevel machines outside of their reputation for being very well made, powerful aircraft.
