| Gas, Glow and Turbine Helicopters *No Commercial Ads - Liquid Fueled Helis Only |
****SOLD***
: Miniature Aircraft – Whiplash Gasser (90/700) Add your own receiver and go fly!!! Willing to consider parting it out, just let me know what you are interested in and I'll think about it. Really just trying to offload the whole thing. Bought this model brand new and have run about 4 gallons of fuel (overall) through the motor. Currently running Coleman Camp Fuel to try to reduce the odor in the house since I keep this model in my office. Prior to using Coleman, this engine has only ever used 87 octane Pure (ethanol free gas)We have a new baby in the house and my wife is freaking out because the says even if you can’t smell the fumes of camper fuel, it’s still there. I’m at my wits end and not going to push the issue any longer and am unwilling to store it in my garage because of humidity. Not leaving the hobby, but am going to make the switch to electrics so [hopefully] the “fume” argument will be over. Send me a PM with a reasonable offer. When you see the list of what is included you can do the math yourself. Bottom line is I realize I will take a little bit of a loss, but this model is in pristine condition and I will not part with it unless the price is right. This model is complete and ready to accept your receiver and either the CGY750 listed below, or whatever FBL controller you use. PayPal or money order will be accepted on a first come first serve basis. Shipping will be negotiated during the selling process (will be reasonable for both parties). I will NOT accept PayPal “gifting” so understand that PayPal will penalize me 3% and figure that into your offer. I will add a few pictures here, but am willing to take any other pictures you may want upon request. ***LOOK CLOSELY AT THE PICTURES BELOW. THEY ARE ALL DIFFERENT AS I HAVE LAID OUT ALL OF THE VARIOUS SPARES SINCE THERE ARE TOO MANY TO FIT INTO ONE OR TWO PICTURES*** Kit Includes: · Complete MA Whiplash Gas FBL Model · (2) not one but two first quality Canomod standard Whiplash Green canopies (one still in unopened box) · (1) set Used (installed) but undamaged Mavrikk 690mm G5 Pro CF FBL main blades · (1) set New in box, Mavrikk 690mm Sport Flybarless Wide Chord main blades · (1) set of Lime Green 105mm KBDD tail blades · Toxic TRM VX270TT motor · Century V5 exhaust · Miniature Aircraft CF air filter · Silver ADA Racing Fan cover (replaces pull starter, pull starter will also be included) · Rare Earth Magnet quick release front canopy mount (originals will come with as well) · RCBooya quick release rear canopy mount (originals will come with as well) · Fromeco AZ Regulator with Pin flag switch · (1) PowerEdge 3000mAh 2S 6.6v LiFe receiver pack · A total of SEVEN high quality digital servos o Futaba S9252 throttle servo o New in box, JR MP80G tail servo o JR DS8900G tail servo (installed on model) o JR DS8717 Cyclic Servos (3 installed, 1 spare) · Your choice of – Futaba CGY750 complete FBL controller (includes CIU-2 update adapter), Futaba GY-701 (gov only), or Futaba GV-1 governor · Stator Gator RPM sensor · Color - printed and bound instruction manual Equipment Included: · Sullivan DynaTron super high torque starter with “A Finer Edge MFG” Makita Li-Ion adapter (Makita batts not included) · Jersey Modeler Gas can with hand pump (specially designed for gasoline powered models) List of spares included (most in original package): · (2) spare NGK-CMR7H spark plugs · (1) Champion RZ7C spare spark plug · (1) copper exhaust gasket (uninstalled) · Titanium Lunsford racing turn buckle style pitch link rods (both from servos to swash (4), and swash to head(4)) · (1) complete spare clutch kit · (2) complete torque tubes with ends and bearings · (2) Tail booms · (1) set of two boom supports · (1) metal tail pushrod with ends · (2) sets of skid tubes (4 total tubes) · (2) sets of landing gear struts (4 total) · (1) CF spare vertical fin · (1) fuel tank · (1) set of white/clear 80D dampers · (1) set of blue 90D dampers · (4) CF break away tabs · (7) Pem nut inserts · Over a dozen 3mm MA 0009 washers · (1) MA128-57 tray mount · Package of several Phillips tapping screws MA 0032 · (1) spare CF front gyro tray with Delrin mounts · (1) unopened Walboro 990 carburetor · (1) set of (2) flanged clutch spacers MA133-119 · (1) fuel fitting MA 0405 · (2) fuel fitting MA 0410 · (3) M3x65 mm control rods MA 121-7 · (10) plastic ball links MA 0133 · (4) M3x30 control rods MA 121-4 · (6) plastic ball links MA 0133-1 · (1) CF bellcrank bracket MA 131-131 · (1) modified (complete) tail pitch slider MA 131-75 · (3) Spindle shafts MA131-187 · (1) lower Jesus bolt MA 131-201 · (1) Upper Jesus bolt MA 131-200 · (1) 9x17x5 bearing MA 131-181 · (2) CF damper washers MA 131-184 · (1) swash follower (with bearings) MA 128-314 · (2) sets 5x10 thrust bearings MA 131-66 · (1) CF anti rotation bracket · (2) washout links MA 0869 · (1) Swashplate anti-rotation pin MA 131-83 · (1) 10mm swash level tool MA 3000-10 · (1) tail pitch control bellcrank (with bearings) MA 131-130 · (2) torque tube end set MA 131-57 · (2) tail rotor output shaft MA 131-70 · (1) tail rotor hub MA 131-64 · (1) tail bevel gear (shaft side) MA 131-17 · (1) tail bevel gear (TT side) MA 131-18 -- Josh ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Seasick78; 09-11-2012 at 07:33 PM.. Reason: added additional info |
Give me a number/ price , I see what u have but prices range so much I dont wanna even start to guess... I am interested whats the number !!
i dont have any cash. but i offer 1 sightly used wife, and 1 no good kid..............LOL, good luck on sale
Lol. Now that's funny sh@t right there. Lol. Slightly used wife and a kid !!! Lol hahahahha
That joke should at least knock off 2400 bucks. |
#6 |
#7 |
I am also willing to sell the airframe (no blades or electronics) with the engine and exhaust pipe, spare canopy,and following list of spares (below)
List of spares included (most in original package): · (2) spare NGK-CMR7H spark plugs · (1) Champion RZ7C spare spark plug · (1) copper exhaust gasket (uninstalled) · Titanium Lunsford racing turn buckle style pitch link rods (both from servos to swash (4), and swash to head(4)) · (1) complete spare clutch kit · (2) complete torque tubes with ends and bearings · (1) set of two boom supports · (1) metal tail pushrod with ends · (2) sets of skid tubes (4 total tubes) · (2) sets of landing gear struts (4 total) · (1) CF spare vertical fin · (1) fuel tank · (1) set of white/clear 80D dampers · (1) set of blue 90D dampers · (4) CF break away tabs · (7) Pem nut inserts · Over a dozen 3mm MA 0009 washers · (1) MA128-57 tray mount · Package of several Phillips tapping screws MA 0032 · (1) spare CF front gyro tray with Delrin mounts · (1) unopened Walboro 990 carburetor · (1) set of (2) flanged clutch spacers MA133-119 · (1) fuel fitting MA 0405 · (2) fuel fitting MA 0410 · (3) M3x65 mm control rods MA 121-7 · (10) plastic ball links MA 0133 · (4) M3x30 control rods MA 121-4 · (6) plastic ball links MA 0133-1 · (1) CF bellcrank bracket MA 131-131 · (1) modified (complete) tail pitch slider MA 131-75 · (3) Spindle shafts MA131-187 · (1) lower Jesus bolt MA 131-201 · (1) Upper Jesus bolt MA 131-200 · (1) 9x17x5 bearing MA 131-181 · (2) CF damper washers MA 131-184 · (1) swash follower (with bearings) MA 128-314 · (2) sets 5x10 thrust bearings MA 131-66 · (1) CF anti rotation bracket · (2) washout links MA 0869 · (1) Swashplate anti-rotation pin MA 131-83 · (1) 10mm swash level tool MA 3000-10 · (1) tail pitch control bellcrank (with bearings) MA 131-130 · (2) torque tube end set MA 131-57 · (2) tail rotor output shaft MA 131-70 · (1) tail rotor hub MA 131-64 · (1) tail bevel gear (shaft side) MA 131-17 · (1) tail bevel gear (TT side) MA 131-18 - Josh Last edited by Seasick78; 09-11-2012 at 07:35 PM.. |
#8 |
Sell the wife..........keep the heli!
#9 |
#10 |
***SOLD***
