| Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support |
#41 |
It's the new 750mx, 530kv, 10 pole
Sab Goblin 700 Yellow // Align 700 DFC HV. BeastX :// Align 550 V2 DFC. BeastX // Align 450 Pro V2 DFC . BeastX // Futaba 10Chg - Phoenix RC |
#42 |
Yes, I didn't know if the specs for the 700MX in the Castle chart was the same, but it appears it is. That chart is nearly 18 months old.
If you look at the newer chart for the 600, it shows V4 firmware and 12 kHz pwm for the 510Kv motor. Don't know. ![]()
Warp 360 Spartan Vortex VX1 |
#43 |
I read on one of the other threads regarding fw v4.* that 8kHz was a bit iffy in the new programming and they recommend going to 12kHz on all outrunners.
Fly first ask questions later. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0 MSH PRŌTOS 500 FBL "Sky Whip" | ZYX v4.0 Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion |
#44 |
I am running an Ice 2 120HV with a 4525 520 Ultimate in my Kasama and found the ESC to run much cooler on 8 kHz, power seemed the same...not the same motor but just to show the 8kHz setting worked fine..
Kasama Faifa 4525 520 Ultimate Ice 2 120Hv VBar (gov) Goblin 700 4530 540 LE Ice 2 160HV VBar (gov) Brushless MCPX |
#45 |
It’s good to try different PWM settings to see what works best. Just NEVER try to use the outrunner mode with a helicopter.
#46 |
Do you have to re do the end points after upgrading to a newer version of firmware?
#47 | ||
#48 | |
Actually higher PWM puts more stress on the ESC. A small change like going from 12 to 16 will definitely not harm the motor. . |
#49 |
That sounds like opinionated speculation. It was all working very well on the night before I changed things and roasted the motor. Coincidences happen but it's less often than not.
#50 | |
I have an email and answer from Clint Akins: 8 or 12 will be fine... I prefer 8 and normal timing... Clint Akins Outside Sales and Support CASTLE CREATIONS, INC. 540 North Rogers RD, Olathe, KS 66062 Office phone: (913) 948-7581 Cell phone: (912) 481-3690 E-mail: clint@castlecreations.com Hi, I have a new Align 700 DFC HV with CC 120A HV (all stock , no mods )…the motor is 750mx – 530kv – 10 poles I’m ready for the maiden flight Can you help with the PWM? 8Khz or 12Khz? Thanks in advance
#51 | |
I haven't noticed any problems with Outrunner. What does it do worse than 8 or 12kHz?
Tarot 450 Pro FBL. ZYX, Blade 450 X tail grips, 6S, Ice Lite 50, DS92A+ cyclics, DS215MG tail. BL Blade mCP X (HP05S, XP7A, dual coreless tail), mSR (sold), DX6i |
#52 | |
If you are not aware the outrunner mode is a variable PWM frequency mode that’s needed for high pole count motors that run at a very wide range of speeds, typical airplane operation. Helicopters run at a constant RPM in a fairly narrow speed range and we use relative low pole count motors so that’s not really needed. . |
#53 |
Thanks, I understand it a bit better now
I don't think my $20 HobbyKing motor had any sort of documentation/suggestion for settings I tried the PWM formula on my motor, and got about 12KHz, so that is at least a nudge in the right direction. I can try 8KHz as well and see if it does anything weird.
#54 |
I'm a new CC-ICE user and when I downloaded the castle link software there was a warning that the new software would make motors run hotter/faster than previous. I can't find this when I look back at the website again though. I understand new firmware requires re-calibration of throttle, so for a first time use (i.e. brand new set-up) this warning is no problem?
I'm a long-standing SK270 user and haven't figured out yet what I'll do about governing (I seldom used it on my scale helis).
Nelson JR DSX9 II; DX6i (relegated to the Phoenix sim), Atom 500 in AS350 body (retired), TRex 450 S in MD500E. Trex 450 S for sport practice. TRex550 in Funkey/Century Jet Ranger. SK720 all round. SR120 (abandoned). MCP-X. |
#55 | |
http://www.castlecreations.com/downloads.html Also the FAQ page has lots of useful information. http://www.castlecreations.com/tech-support.html . |
#56 |
Does the Hyperion sensor still work with vBar gov and Ice HV?
-Goblin 700: Crashed but re-building, still needing electronics To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. -Goblin 630: CC Ice 120HV, vBar |
#57 |
#58 |
Thank you :-)
#59 |
A suggestion for Mr.Mel.... It is probably good to update the info on the VBar&Escs page (http://heli.dacsa.net/MrMelSite/VBarESC.html). The part for the CC is outdated.
LOGO 400SE: ICE75, 500MX, DS510M+DS650, VBAR 5.3 PRO, EDGE 473, KBDD 72.5 LOGO 600SX: JIVE 100LV, HKIII-4025-1100, BLS451+BLS251, VBAR 5.3 PRO, EDGE 600, EDGE 95 |
