Old 09-14-2007, 03:32 AM   #1
farren
Default Pich Curves for throttle hold
Anyone have any suggestions on the pitch curve in throttle hold? How little how much ETC
Farren
farren is offline        Reply With Quote
Old 09-14-2007, 04:01 AM   #2
bullaculla
I run my hold curves exactly the same as my idle up curves. 0-100.
I dont like the heli to jump when I flip modes or hold.
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount.
T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount.
JR X9303.
bullaculla is offline        Reply With Quote
Old 09-14-2007, 06:09 AM   #3
Squirrlybird
Same with me.
I run ALL of my pitch curves exactly the same. I dont want a jump when I hit a switch.
Squirrlybird is offline        Reply With Quote
Old 09-14-2007, 09:28 AM   #4
Big Fil
Run your hold curves the same as whatever mode you are flying around in most. In most cases this would be idle up.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote
Old 09-14-2007, 03:19 PM   #5
jgunpilot
I agree with the above answers. At first, I used the common advise - throttle hold -4 to +10. But I didn't want to have the pitch jump if I started on auto, so I changed to using the same as in idle up and find works great. I also use my normal mode at a flat 0 degrees so I don't start flying in normal and turn it upside down and run out of pitch.
jgunpilot is offline        Reply With Quote
Old 09-14-2007, 11:05 PM   #6
bullaculla
Same here. I just use normal for checking HS. But I have slightly negative pitch on my flat curve. It could get light on the skids if a gust of wind comes while i'm taching the head
JR X9303.
