Old 10-07-2012, 02:59 PM   #1
Victor Kovalev
Question Trex 450 Pro V2 3GX Gyro Gain Settings
Can any one direct me to a link or thread that address how to go about setting/fine tuning gyro gain?
Thanks.
Thorr
Trex 550E DFC V3, Trex 450 Pro V2, Trex 450 Sport V2 DFC
Blade 130X, MCPX V2.
AR7200BX FBL. DX6i
Victor Kovalev is offline        Reply With Quote
Old 10-10-2012, 09:29 PM   #2
Tyharp21
Default gyro gain settings
I run my settings for stunt anywere from 35 to 38.
Tyharp21 is offline        Reply With Quote
Old 10-11-2012, 08:18 PM   #3
Victor Kovalev
Thanks.......but how do you go about testing and adjusting gyro gain?
Thorr
AR7200BX FBL. DX6i
Old 10-11-2012, 09:18 PM   #4
Danny Dugger
For the 3GX to be in heading hold mode your gyro gain on your radio has to be set above 50. You want all the gyro gain you can get without tail wagging. Turn it up 3 to 5 points at a time on your radio until the tail starts to wag in flight, then back off a couple of points until it doesn't wag and you're set.
Danny Dugger is offline        Reply With Quote
Old 10-14-2012, 12:24 AM   #5
ferebeed
What radio are you using?
Sent from my iPod touch using Tapatalk
ferebeed is online now        Reply With Quote
Old 10-16-2012, 01:30 AM   #6
sal98
Default Gain settings
Usually if a person states that he has to run his gain over 50 to be in heading hold, he is using a spectrum or JR radio. Futaba radios are different as they usually run in the 30 to 35 range for gain in the GY Mode. My Hitec Aurora can be set to run it's gyro menu either way.
There is a really good video on youtube of a guy setting up the microbeast and he basically shows you step by step how to test your heli to set up the best possible gain settings. It is for a different FBL controller but the theory is the same no matter what unit you use.
sal98 is offline        Reply With Quote
Old 10-16-2012, 08:10 PM   #7
Victor Kovalev
Excellent......thanks!
Thorr
AR7200BX FBL. DX6i
