Well, before I start I should introduce myself. Hey everyone, Chad here. I am new to helifreak, came over from RR. I don't like their setup at all. Why lump the trex 600 with the 450s? Not the same heli or setups at all...just mt 2 cents.
Well, here is my setup. Trex SE CC35 TP2100 3C prolites 401w/S9650 430XL motor DX6 Radio I wanted to try a higher head speed to get used to idle up mode(I am a noob so bear with me). I have just been hovering in normal mode. I set the normal throttle curve at 0,85,100. I had already done two previous flights with these settings. Charged the batteries. Started my 3rd flight for the evening, and all hell broke loose. The heli was about 20ft up when the motor just lost power I was just checking my castle creations 35 ESC settings. I think the problem might be the current limiting setting. It was on normal. Could this be an issue with the TP2100 lipos (430XL motor 3700kv) and the current limiting setting? The TP lipos are only 15C. Anybody have any insight on this situation? ![]()
<<450SE V2, CC35, Kong Power 3S 25C 2200, 430XL, 401 w/9650, HS65MG, tail weight mod>> <<Blade MCX with glow-in-the-dark setup, carbon fiber canopy>> <<Yellow 600SNP, 8717s, 770 & 8900G, AR7100, Multigov Pro, Align 2 in 1(used for glow driver only)>> |
Well although I cant comment on your particular problem, wanted to say welcome, and youve picked a good site. Someone here should respond with some help shortly.
Good luck. |
