Old 10-09-2012, 12:24 PM   #1
badbandit
Default No soft start? What to look at?
hi,
today i received my 300X and i checked and set up everything. as far as i can see, everything is fine so far.
my first small try was a normal and manual spool up, which worked (beside of some vibrations). after that i pulled TH, set Stunt1 (75% throttle), moved the throttle-/pitch-stick up to 60% and pushed TH.
the 300X went directly to full throttle and circled very fast around itself.... luckily nothing happend.
i always do the same with my 130X and 450X and it works.
what could i have set um wrong? where do i have to look at?
badbandit is offline        Reply With Quote
Old 10-09-2012, 01:07 PM   #2
JustPlaneChris
Did you wait 20-30 seconds before restarting? If not, there's your problem! The soft start has a "reset time" and you either need to pull power and re-arm or wait 20-30 seconds before restarting to get a soft start.
As far as I know this is an "undocumented feature"
Chris Boultinghouse
Team MSH USA | Team Lynx Heli
JustPlaneChris is online now        Reply With Quote
Old 10-09-2012, 01:20 PM   #3
badbandit
chris, thank you for your help!
i am quite sure that i did not wait 20 to 30 seconds before i restarted. good to know about this "feature". i never had these problems before, but this may have been luck.
i will try again tomorrow and report.
Old 10-09-2012, 02:41 PM   #4
Chris Gardill
I wonder if the ESC on the 300X may be set up, like the stock ESC on the Blade 4503D/X, to quickly come back to RPMs unless it's sitting for a while to bail out of autos. On the 450X at least, engaging TH and then coming back out of TH quickly allows the motor to come up to operating RPMs very quickly to enable the heli to bail out of an auto. i recognize this won't work on a 300X with no one-way bearing but I wonder if all the heli ESC's are set up like this?
Synergy E7SE (KDE 700XF-495) (under const.); Synergy E5 (KDE 600XF-530); Goblin 500 (XNova 4020-1200); Gaui X3; MSH Protos; Blade 350QX; Blade 200QX.
Chris Gardill is offline        Reply With Quote
Old 10-09-2012, 02:58 PM   #5
JustPlaneChris
That is my assumption. Even without a one-way bearing if you were to accidentally hit TH in flight it could save your bacon!
Chris Boultinghouse
Old 10-09-2012, 10:49 PM   #6
superjet112x
when you say all helis do you mean Blade helis?
Trex 700n DFC Beast x...Trex 600n Beast x...
Trex 450 pro V2 DFC Beastx KDE XFC Ice lite 50
MCPXs'' HPO7..HPO5s..CO5m..V2 stock..Nano Cpx
Blade 300x Phoenix 25esc Park BEC Blade upgrades
Ducati Desmo 1/5 scale nitro superbike
superjet112x is offline        Reply With Quote
Old 10-10-2012, 12:05 AM   #7
choopi
So the ESC is program for soft start? If I was to hiddle up from zero, it should spool up nicely right?
SAB GOBLIN 500 with IKON, DX8, Taranis, PL6, Phoenix Sim
for more info
www.youtube.com/user/flyfast
choopi is offline        Reply With Quote
Old 10-10-2012, 07:02 AM   #8
Chris Gardill
Yes I did. That was what I meant.
Old 10-10-2012, 08:56 AM   #9
badbandit
chris, as expected you were right. soft start works very well and i enjoyed my first test-hovering :-)
Old 10-10-2012, 09:26 AM   #10
JustPlaneChris
Excellent.
Chris Boultinghouse
