Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 10-15-2012, 11:23 AM   #1
thomascoleman
Default AR7200BX Firmware update
Anyone updated their firmware via the below?
http://ar7200bx.beastx.com/
Hi all you owners and fans of the Spektrum AR7200BX. Available now is the updated firmware for your AR7200BX unit via a dedicated website. Continue through to get the details for updating to the latest firmware and some exclusive info/notes we obtained to run your update.
AR7200BX Software Update How-To
Downloading and Installing the Spektrum™/BeastX™ Software Bundle
1. Visit the BeastX website to download the Spektrum Software Bundle, by clicking HERE.
For Windows®:
http://ar7200bx.beastx.com/software/...wareBundle.msi
For Mac®:
http://ar7200bx.beastx.com/software/...wareBundle.dmg
**Note: Yes, the bundle for Mac was just made available today, as of this article**
1. Save the Spektrum Software Bundle to your computer’s hard drive.
2. Double-click on the installer and follow the instructions.
Connecting the AR7200BX to Your Computer
1. Power OFF the AR7200BX.
2. Connect the Spektrum™ USB Interface (SPMA3030) **Note: SPMA3030 is not yet available from Spektrum, the interface is due to be released on or about September 7th** or BeastX USB2SYS (BTXA76007) **Note: Available now from your BeastX dealer** to your computer.
3. Connect the servo extension to the USB interface and the BND/DAT slot on the AR7200BX.
4. Power ON the AR7200BX.
Retrieving the AR7200BX Firmware
1. Open the BeastX Updater.
2. Select the appropriate USB-Interface.
3. Highlight and Copy your AR7200BX Serial Number.
4. Visit the AR7200BX product page at http://ar7200bx.beastx.com/.
5. Enter your email address and paste your AR7200BX Serial Number and click Submit.
6. You will receive an email with the latest AR7200BX software.
7. Save the firmware file on your computer’s hard drive.
Updating the AR7200BX Firmware
2. Connect and Power ON the AR7200BX.
3. Click “Open File…” and select the new firmware file. IMPORTANT: DO NOT disconnect the USB interface or power off the AR7200BX during the update process.
4. Click “Start Update…” to install the firmware on the AR7200BX.
5. When the update processes is complete, power OFF the AR7200BX and disconnect the USB interface.
Using AR7200BX Microsettings application
1. Using the AR7200BX Microsettings requires version 3.1.0 or higher.
2. Refer to the updating instructions detailed above to update your AR7200BX to version 3.1.0.
3. Launch the AR7200BX Microsettings application.
4. Connect your AR7200BX to the USB interface.
5. Click “Connect” to modify the desired Setup Menu or Parameter Menu Settings.
6. Please refer to your Spektrum AR7200BX instruction manual for detailed programming.
7. Additional Microsettings features and instructions can be found at www.beastx.com.
Release notes: 3.1.0 adds the capability for the AR7200BX to use the AR7200BX Microsettings PC/MAC application. There are no other changes to the features or performance of the AR7200BX©
Source: Spektrum AR7200BX website and Horizon Hobby Tech Support
DX18 | Goblin 700 Comp LTD-E BeastX Plus | T-Rex 700N PRO DFC AR7200BX | T-Rex 600N PRO DFC AR7200BX | Logo 480XGPRO | 300 CFX |
thomascoleman is offline        Reply With Quote
Old 10-15-2012, 11:57 AM   #2
Chris Gardill
I have not yet done this on my 450X but I did it in conjunction with a rebuild from a crash and a relocation of the AR7200BX unit on my 300x. Very straightforward upgrade using the MicroBeast USB cable. Software works pretty well.
Synergy E7SE (KDE 700XF-495) (under const.); Synergy E5 (KDE 600XF-530); Goblin 500 (XNova 4020-1200); Gaui X3; MSH Protos; Blade 350QX; Blade 200QX.
Chris Gardill is offline        Reply With Quote
Old 10-15-2012, 12:08 PM   #3
thomascoleman
I couldn't find a change log. Also does it destroy the 450x custom firmware?
Old 10-15-2012, 12:18 PM   #4
steveap1
There's a thread in the 300X forum. I doubt if I will upgrade now:
http://www.helifreak.com/showthread.php?t=446870
steveap1 is offline        Reply With Quote
Old 10-15-2012, 03:40 PM   #5
Coco66
There was a thread about 450x already:
http://www.helifreak.com/showthread.php?t=446839
[SIZE=2]Goblin 500Warp 360Blade 450XBlade 450X Nightflyer ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8
Coco66 is offline        Reply With Quote
Old 10-15-2012, 05:14 PM   #6
ShaneJourdan
Much appreciated works awesome, been waiting for this!! Thanks much.
Just FYI guys, you must connect your device to the updater to acquire your serial number for download.
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - BD3sx -CC 50
Gaui X2 - BD3sx - Talon 25 - DS95i
ShaneJourdan is online now        Reply With Quote
Old 10-17-2012, 07:15 PM   #7
Temptation
What does it do, or change?
Temptation is offline        Reply With Quote
Old 10-17-2012, 07:51 PM   #8
ShaneJourdan
No changes in actual firmware other than allowing firmware update and micro software GUI. In other words you can now change setting via a software interface, which I enjoy.
Old 10-17-2012, 08:20 PM   #9
EEngineer
What does the GUI for Parameter Menu A look like?
EEngineer is offline        Reply With Quote
Old 10-19-2012, 04:31 PM   #10
Chris Gardill
I haven't changed it on my 450X yet but I did upgrade it while I was rebuilding my 300 after a crash. Looking back, I'm glad I did this as I've ended up playing with 3 different tail servos getting it balanced and with good tail authority with a more durable tail servo. The GUI has made changing tail servo frequencies and centers while swapping those servos a snap.
To your question, there are a number of different steps in both the Setup and Parameter menu that aren't in the GUI and have to be done using the transmitter. I can't remember if the A parameter is one of those but I think it's not there. I know the control behavior B Parameter menu is not in the microsettings GUI. I will try and check it tonight and confirm back on which specific menus are (and are not) available on the GUI if that would be helpful.
