Old 10-28-2012, 02:10 AM   #1
RCheliski
Default Huh? Am I not supposed to be using Lipos for my servos?
Hi Freaks!
Silly question but another thread I was reading (http://www.helifreak.com/showthread.php?t=466064&page=2) post #14 said You should not be using 2S lipos to power your DS610 servos. Is this correct? What is he talking about? What am I missing here? I have been using a 2S lipo to power my DS610's and DS 620 on my Trex since July-ish. And also using 3S lipos regulated to 6.0 volts for my DS615's and Futaba S9254 tail servo on my Goblin. I'm cornfused.
Thanks!
Ed
GOBLIN 700 Align DS615//Futaba S9254//BeastX//CC ICE2 HV120//CC BEC Pro//Align MX700
TRex 600EFL Pro Align DS610//Align DS650//BeastX//CC ICE2 HV80//Align MX600
Blade mCPx ver. 1 // Blade mCPx ver. 2
Spektrum DX7s
RCheliski is offline        Reply With Quote
Old 10-28-2012, 02:14 AM   #2
Slyster
The are not HV servos and designed for a max of 6V. HV servos are designed to accept 8.4v of a lipo. I'd say you are asking for trouble running them as HV. That's why I am going with Torque servos in my future Goblin... so I can safely run off of a flight pack.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is offline        Reply With Quote
Old 10-28-2012, 02:28 AM   #3
777ER
The DS610 isn't an HV servo so you can't run direct 2S lipo (7.4v)
However you can run 2S LiFe which is 6.6v and safe for the DS610 when running off direct 2S LiFe.
Or keep the current battery and use an regulator
777ER is offline        Reply With Quote
Old 10-28-2012, 02:37 AM   #4
nwmtech
Technically the DS610 isn't rated for anything over 6v. However... there are a lot of us that have been running them at straight 2s lipo for years. Oddly enough I've had one 610 servo randomly die over the last 2 years and it was always on 6v.
Team RCHN Citizen 002, Team SAB, V-Team, Team Optipower
nwmtech is offline        Reply With Quote
Old 10-28-2012, 03:14 AM   #5
RCheliski
Thanks. But Im kinda confused. Isnt that what BECs (or regulators) for? I either connect a 2S to an Align external BEC or I connect a 3S Lipo to a CC BEC Pro and output the voltage to 6.0v. Then that wire goes to power the receiver, which in turn powers the servos (using a step-down for the tail servos) and FBL controller, right?
How else is this done? How do you guys do it? Have I been doing it wrong all this time?
Spektrum DX7s
Old 10-28-2012, 03:23 AM   #6
flybar_mike
You're actually on the right track for the regular servos. The HV servos are different in that they allow you to simplify the system by cutting out the Becs/regulators. The 2S Lipo runs straight in to the Rx which feeds the servos with the higher current. Some I'm told actually run the HV servos directly off the 2S. Apparently the HV servos last longer and perform better because of the higher voltage. Not using them myself yet.
With the CC Bec Pro, I run one off my 6S on my 550, and another off one of my 6S packs on my 600. They are rock solid. Apparently the latest V3 release can run safely off 12S.
Trex 600EFL Pro - AR7200BX
Trex 550 FBL | BeastX | Scorpion 4025-1100 | CC Ice 100 & CC Bec Pro
Trex 450 Pro FBL | BeastX | CC Ice lite 50
Trex 450 Pro Night Flyer | mCPX v1 | Phoenix Sim & DX8
flybar_mike is offline        Reply With Quote
Old 10-28-2012, 03:32 AM   #7
RCheliski
How do you power a receiver directly from the lipo? Do you just solder a receiver plug on the Lipo +/- wires and plug it in the receiver?
Spektrum DX7s
Old 10-28-2012, 06:10 AM   #8
Stevin
yup
Trex 700L Vbar 5.3pro / Mikado Logo 600SX / Trex 450 pro vbar 5.3pro/ Velocity50 Vbar 5.3pro -still the best 600 class nitro-/Trex 600efl PRO vbar/CC HV80
Stevin is offline        Reply With Quote
Old 10-28-2012, 06:38 AM   #9
celltech
http://www.amainhobbies.com/product_...l-JR-Y-Harness
I use this from my LiFE battery into aux 2 and aux 3 on my AR7200
Trex 600efl Pro,Beastx, Blade 450 3D, ZYX Tarot FBL, Blade 450 3D stock, MCPX v2, Sr120, Spektrum DX8
celltech is offline        Reply With Quote
Old 10-28-2012, 08:43 AM   #10
777ER
Just like this:
( ignore the 2.4 antenna, it has been adjusted to 90* after taking this photo)
One into the battery slot, another to a unused channel. If no unused channel available, can use a Y-harness.
Old 10-28-2012, 04:58 PM   #11
RCheliski
Thanks for clearing that up for me. Have one more question though.
Could you put a 5.1v voltage regulator between the Lipos and the receiver, so you can power non-HV servos almost directly from the Lipos? instead of using the 5.1v voltage regulator only between the receiver and tail servo?
Spektrum DX7s
Old 10-28-2012, 05:18 PM   #12
bj660raptor
bro youve been running them 2s lipo with no probs and other people do as well,if your worried run a 2s life pack with no regulator,20 dollar packs and youll have no worries.
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote
Old 10-29-2012, 05:04 AM   #13
skunkworx
If you put a 5.1V step-down before the RX then you will have only 5.1V to all the servos because they draw power off the parallel buss inside the RX. The reason why you use a step-down specifically on the tail is that there are virtually no current cyclic servos that are only rated at 4.8V (nothing stopping you from running that low if you choose, but they typically accept anywhere from 6V to 9.0V).
High Voltage servos simply means they can accept up to the rated output voltage of a 2S Lipo or 8.4V. Some go as high as 9.0V, but I think that's just for overshoot. Almost any other servo will be able to run up to 6.6V without any cause for concern unless they're specifically rated at no more than 4.8V (such as tail servos).
I wouldn't doubt that in the next couple of years we'll likely see servos capable of up to 12.6V inputs since those are pretty standard on a lot of robotics. The higher the voltage (usually) the faster the servo can operate and it usually adds a pretty large amount of torque as well.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
Old 10-29-2012, 05:58 AM   #14
Heli,Ed
+1
Works awesome , I have switched over 2 of my 550s and will this winter take off the Castle BEC pro and do one more with a life battery,(Nothing wrong with the BEC pro,just like life battery better,and it also helps to balance cg on the 550 better)
Also a life battery is VERY stable compared to standard lipo , so never worry about leaving them in the bird,instead of feeling like I have to put them in my ammo cans with the rest of the other lipo's
I am flying 3 550s ,all with Align servo's and all with AR7200BX in them
Went to the other side
For sake of time and money, went to planks for a while
Heli,Ed is offline        Reply With Quote
Old 10-29-2012, 07:01 AM   #15
povern
From a chemistry standpoint yes, but from a voltage standpoint.... A little different.
They hold their voltage until the end, then it falls off a cliff. If you know and understand this, you are fine. But I have seen a couple birds go in, because they let their LIFE RX packs get to low. No warning and then the RX shuts off.
Screw It, I'm gonna fly.
Synergy E5, Synergy E5s
Couple planks, couple quads
vControl and Neo
povern is offline        Reply With Quote
Old 10-29-2012, 07:45 AM   #16
bloftin
Smile
+1 I've been running DS610's on a 2S lipo (on multipal birds) since Burt Kammer started doing it when he still flew for align (for years). Even though they are not "rated" for it, they run very well on 8v. I've logged hundreds of flights with multipal helis running 610's @ 8v.
Brian Loftin
ΜΟΛΩΝ ΛΑΒΕ
bloftin is offline        Reply With Quote
Old 10-29-2012, 07:50 AM   #17
Heli,Ed
Exactly ,
I was referring to the stability (chemistry) stand point,meaning ,not have to be AS concerned about them being so volatile .Still don't take them for granted , but seems a little safer to leave in the bird's
Old 10-29-2012, 10:03 AM   #18
povern
Exactly ,
I agree, more stable.
Also, knowing about the voltage drop off, I will be using Life for RX packs over Lipo. Safer, etc. I just will have a large safety factor, as far as MAH usage.
vControl and Neo
Old 10-29-2012, 07:35 PM   #19
SQRT(-2)
Yes, you can put a UBEC or regulator between the RX battery and the electronics of your heli to run them at what ever voltage you want. It is a common practice. Just get one rated for enough amps. Castle, Align, Hobbywing and several others make such devices.
This one is also an on board glow starter.
http://helidirect.com/voltage-regula...-1_1619_93.hdx
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 10-29-2012, 07:57 PM   #20
Heli,Ed
Not such good recommendations
That cc shown can't handle a 550 and the align 2in1 has some failure issued
If anything use a cc bec pro or a western robotics of similar output or still yet a life battery
A life battery drops to 6v quickly and stays there for a good while
