Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 11-15-2012, 09:08 PM   #1
kuzican
Default Spacers for Blade Grips
I got Align blades to put on my B450, and I need to make shims for the blades.
I know some people used old credit cards and cut them to use. I'm wondering how exactly people did this, as in just a little circle with a hole in the middle, and do you put the shims on the top or bottom? or does it not matter?
Blade 450 3D, 130X, Nano CP, Inductrix
kuzican is offline        Reply With Quote
Old 11-15-2012, 09:20 PM   #2
chambers
Put one on the top and one on the bottom, just cut out 2 small peices for each blade, then drill a hole in the center. Worked good for me for a long time till I went fbl.
Trex 700l Dominator. Microbeast
Futaba 10j Tx
Icharger 406Duo
chambers is offline        Reply With Quote
Old 11-15-2012, 09:27 PM   #3
kuzican
alright, thanks for the info. Now I have to find a credit card or something to cut up to use as shims. think a hole puncher would work for the center hole?
Old 11-15-2012, 09:39 PM   #4
chambers
Keep the center hole the same size as the bolt though.
Futaba 10j Tx
Icharger 406Duo
Old 11-15-2012, 09:45 PM   #5
Slyster
when I had 450s I cut out circles from the plastic lid of an ice cream tub.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 11-15-2012, 10:21 PM   #6
kuzican
Ice cream tub, might actually have one of those....let me go look.
Old 11-15-2012, 11:15 PM   #7
Skidpad
Here's a solution that's a little less, um, "shade tree-ish" :
http://www.helifreak.com/showpost.ph...12&postcount=5
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote
Old 11-15-2012, 11:28 PM   #8
kuzican
thanks, I think I might actually check that out tomorrow when I go pick up the parts for my heli. Hope i can get it back in the air tomorrow or saturday.
Old 11-16-2012, 06:16 AM   #9
H2ORower
For $3.29 you can buy some real Blade shims. They're listed under 450 X parts, but I've been using them myself on my 450 3D ever since I began using Align carbon blades. They work perfectly!
Part #. BLH 4304
H2ORower is offline        Reply With Quote
Old 11-16-2012, 09:56 AM   #10
Champy
I'm using the Revolution blades and made the spacers needed from an old pair of wood blades for my cp pro2. Took the black plastic pieces off, cut to size and drilled out the hole enough for the bolt to fit through. Works but I ordered the 450x shims like h2o suggested.
Up and In with a Grin But what goes up, must come down
MCPX V2 with flashed xp-7a and CO5M
extended,solid, 2mm tail boom
Blade 4503D with Hughes 500E fuselage
Champy is offline        Reply With Quote
Old 11-17-2012, 12:58 AM   #11
kuzican
I got some of those number 8 nylon washers that I'm going to use.
