Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 11-20-2012, 04:50 AM   #1
acrow
Default Throttle Servos For Gassers
Hello Gasser RC Heli pilots.
I have searched the forums and haven't found any recent discussions on suitable throttle servos for gassers.
What I'd like to see is:
1) What qualities are needed for a gasser throttle server.
2) Recommended throttle servos for low voltage (nom 5 volts).
3) Recommended throttle servos for LiFe(2S).
4) Recommended throttle servos for LiPo (2S).
A discussion in one thread should be useful for newcomers to gassers and others needing to replace throttle servos.
Regards
Acrow
acrow is offline        Reply With Quote
Old 11-20-2012, 05:32 AM   #2
fastflyer20
I think you don't see much discussion since it is not a highly stressed servo. I grab used cyclic servos I have kicking around, DS610, DS620, S9452 have all worked without issue. On any heli with a governor, you do need reasonable speed for the servo to react quick enough. Just because gassers are not cheap, I would not use a cheap servo on the throttle.
Linkage on a gas servo is important.
fastflyer20 is offline        Reply With Quote
Old 11-20-2012, 05:36 AM   #3
Azalin
+1
I use DS650's on my 2 gassers. Over 2 years and no problems so far.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote
Old 11-20-2012, 08:00 AM   #4
Doug Darby
I run Futaba BLS 451 on all my Gassers at 8.4V.
Works fine. No Failures.
doug
TRM Power - RC Racing Engines - - VP Racing / Powermaster Fuels
Aero Hobbies - Lewisville, TX (972) 420-1414
Doug Darby is online now        Reply With Quote
Old 11-20-2012, 10:51 AM   #5
Rudy
As I'm running Savox servos, I went it the SC-0352 Digital servo
Dimensions(mm):* 40.7X20.2X39.4
Weight(g):* 42.0
Speed(@4.8V sec/60):* .16
Torque(@4.8V oz-in):* 58.3
Speed(@6.0V sec/60):* .13
Torque(@6.0V oz-in):* 90.3
Gear:* Industrial Plastic
Bearing:* 2BB
Case:* Plastic
All for $27.00
Powered with a LiFe 2100mah pack.
Works for me
Rudy - Currently in ??? It depends on the day of the week where I am
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is online now        Reply With Quote
Old 11-20-2012, 07:56 PM   #6
martin_
I plan high voltage system as I already have 3 HV for cyclic, I made a long search and I bought this:
Hitec HS-5495BH Digital Standard High Voltage; 23,95$ + 7$ shipping.
Karbonite gear
Speed: 6.0v / 0.17 sec/60
Speed: 7.4v / 0.15
Torque: 6.0v, 88oz
Torque: 7.4v, 104oz
I don't know if it's good, other HV option are 4X this price.
T-rex 600E pro
T-rex 450L
Coaxial Collective Pitch 550
martin_ is offline        Reply With Quote
Old 11-20-2012, 08:33 PM   #7
desertstalker
Hyperion make some nice servos, they have HV ones that are less than $40. Not tried their STD size ones, but no issues with their mini or micro versions.
-DX8
Old 11-21-2012, 01:40 AM   #8
acrow
Thanks for the replies so far.
I was hoping there would be more discussion on nylon gears versus metal and things to watch out for due to additional vibrations from gasser engines.
Regards
Acrow
Old 11-21-2012, 08:07 AM   #9
martin_
From what I have read, most of the time guys seems to use what they have laying around for throttle servo, and it's often plastic or carbonite gear. I read a few case of stripping metal gear, I can guess it's due to the gear ratling with vibration, but other have reported good success with metal gear, I can't comment further, I don't have any experience with this.
I would like to read here some experience with metal gear also.
T-rex 600E pro
T-rex 450L
