Old 11-23-2012, 03:56 PM   #1
lightfighter363
Default DFC head?
i'm thinking about upgrading my heli head with this Align Trex 450 PRO SPORT SPORT V2 DFC Main Rotor Head. any idea or reviews i want the pros & cons please
Tarot 450 DFC split lock rotor head assembly
Trex 500 AW1 cobra ,Trex 450 pro MH-6,Trex 450 SE Apache,Trex 450 Sport MD 500,120 SR Seahawk, MCPX, DX8.Dji phantom.
lightfighter363 is offline        Reply With Quote
Old 11-23-2012, 05:18 PM   #2
ragge1
tarot head looks cool
| Atom 6HV : vbar NEO pro rescue | Goblin 700 : vbar 5,3 pro | HD Cell 500 : vx1e |
ragge1 is offline        Reply With Quote
Old 11-23-2012, 05:28 PM   #3
ragge1
see a good thing on the tarot head that all heads should have , got it on the Goblin head , a 0 pitch mark very nice
Old 11-23-2012, 05:40 PM   #4
HeliSmith
Bought the Align 450 DFC head but I am afraid to fly it. The links from the turnbuckles to the swash or so flimsy I am 100% positive that when I smack 3D my 450 it will come apart. I guess I will thread a rod into it and replace the end, but before you buy the Align 450 DFC think about it carefully. Can you wait a little longer for some kind of a fix? I feel like I threw away 50 dollars, I will make it work but still.
P.S. The Tarot head does look nice, I have no input on it though
helism th
HeliSmith is offline        Reply With Quote
Old 11-23-2012, 06:25 PM   #5
SeanM
My Align DFC head has been working great for months. Just be sure to buy the head that clamps onto the main shaft and not the one that relies only on the jesus bolt. Align released the revised head shortly after releasing the DFC head upgrade, but I'm not sure if the DFC kit comes with the head I'm referring to. You might have to piece it together if you want the align kit with the split head.
As for the turnbuckle links, they work just fine... Just be sure to apply enough pressure when threading them on so that they thread on correctly. Not doing so will cause the threads to strip off as you twist it on.
- 6S TREX 450 Pro FBL - µBeast, MKS, Castle Creations
- Goblin 500 - Kontronik Pyro 600-12, Jive 100lv, iKon, BK servos
- TBS Discovery - Pixhawk
- Spektrum DX7
SeanM is offline        Reply With Quote
Old 11-23-2012, 08:33 PM   #6
lightfighter363
i guess tarot win.
Old 11-24-2012, 09:28 AM   #7
Luigi_tuga
And for several reasons. Tarot rocks
Logo 480, Warp 360 , Sport 360
T500 AP
PZ StrykerQ DX8
Luigi_tuga is online now        Reply With Quote
Old 11-26-2012, 06:53 PM   #8
escsniper
Grrrrrr! Just had a flimsly DFC turnbuckle come out of the ball link. Thought I was extremely careful threading them together,but I guess not. And this was during simple slow flight. I was able to minimize damage, but a very frustrating crash. I am beginning to join the mounting number of skeptics on the new 450 DFC!!!
escsniper is offline        Reply With Quote
Old 11-29-2012, 12:41 PM   #9
Camporeale54
I have the align version. I like the simplicity of the head and it was very easy to set up. I did however also have a problem with one of the links breaking. Not sure if it was the cause or the result of the crash.
I replaced it but haven't had a chance to fly again because of the weather. The Tarot links look stronger so I am interested in everyone's feedback.
Bob
Camporeale54 is offline        Reply With Quote
Old 11-29-2012, 06:38 PM   #10
Luigi_tuga
Everything is stronger on that tarot head: 2.5 jesus bolt, two extra bolts to clamp the shaft, 2.5 feathering shaft bolts and the bearing placement is better.
T500 AP
PZ StrykerQ DX8
Old 12-12-2012, 10:04 AM   #11
ragge1
har anybody tried the tarot head yet , can the align pro feathershaft and the alignDFC main shaft be used with this head
Old 12-12-2012, 11:15 AM   #12
dct
I have about 20 flights on my Align head works fine for me.. And it's the one that comes in the new kit ... With the new swash ...
I had no trouble putting on the plastic ball links .. Used a slow drill to install threaded links and heated up plastic ball links in hot water .. Worked fine..
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote
Old 12-12-2012, 01:24 PM   #13
charliebfla
Default Screwinbg on plastic ball links
I found that if you take an exacto knife #11 blade and slightly champher the hole to the ball link that it will screw in pretty well.
120 SR, 450 3D, Align 450 Pro DFC w/BEASTX, Align 500 EFL PRO w/BEASTX
charliebfla is offline        Reply With Quote
Old 12-12-2012, 02:34 PM   #14
ragge1
intrested on the Tarot head as it was the marking for 0 pitch make setup very easy that why I was wondering if it will work with the align feathershaft and the align dfc mail shaft , if anyboby got those would be nice and try and give as some feedback thanks
Old 12-12-2012, 03:58 PM   #15
Mojappa
The marks are nice but making a zero pitch tool is easy as is supporting RDLohr here and buying the one he makes. Much more consistently accurate than machines marks.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote
Old 12-12-2012, 07:18 PM   #16
lcc014
I have been using RDLohr 0 pitch tool in my 250, very accurate !!
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
Warp 360, Scorp 1360KV
lcc014 is offline        Reply With Quote
Old 12-12-2012, 08:01 PM   #17
HeliSmith
On my Align DFC I am not liking how mine felt when I put them on and I tried several times until I ran out of links. I didn't heat them up in water or anything first. I guess I will buy some new links and try that because I am a strong guy with the proper tools but I don't feel confident it threaded correctly. It feels like it doesn't start to grab the thread until half the threaded rod is already into the link. So I think I have half threads only holding
helism th
Old 12-12-2012, 09:06 PM   #18
ranchhand
Do this and forget about them. Read jhunter68
http://www.helifreak.com/showthread.php?t=450401&page=2
I did, works great! Less filling lol
KDE Direct Team Pilot, MAKE IT YOURS
Carbon G700c, KDE700XF-505-G3, Kosmik 200
Trex 700L v2, KDE700XF-505-G3, Cool Kosmik 200
Dx9, Axon, BK servos.
ranchhand is offline        Reply With Quote
