Go Back   HeliFreak > R/C Batteries and Charging Support > Brand Specific Charger and Battery Support > Duralite
Duralite Duralite Battery Li-Ion Li-Mn Chargers Support Forum
Old 10-11-2007, 01:51 PM   #1
hookmaker
Default Li-Ion, Li-Manganese difference??
Hi,
I have two GREAT Duralite 4300 mAh Li-Ion packs. Now I see that Duralite also has Li-Manganese batteries - what's the difference?
/henrik
Hookmaker
Kasama Srimok 90, Kasama Srimok 90E, JR Vibe 90 SG, JR Venture 90, JR Vibe 50 3D V-bar,
Bergen Intrepid Gasser, Vision-SX 90 (x 2)
MSH Protos "Monsterheli", HDX-450
hookmaker is offline        Reply With Quote
Old 10-11-2007, 05:40 PM   #2
DavidH
Li-Mag
NEW! High Current alternative to Li-Poly
• Non combustable chemistry
• Non flammable if punctured or overcharged
• Highest Discharge - 20c continuous with 40c bursts
• Great low temperature toleranace
• High charge rates up to 10c
• Stay Balance curcuit built into pack - no need for external balancing
• Longer life cycles than li-polymers
• Dual lead system - choice of power output leads/connectors, plus charging lead w/yellow connector
Li-Ion
Rugged - Compact - Reliable
• Lightweight & Powerful - constant voltage to servos
• High Energy Density - Long Cycle Life
• Built in Pack Redundancy - Available In all 4 & 6 Cell Packs
• No Memory & No cycling - Easy to Use
• More Robust than Li-poly's - Cylindrical design can
better withstand impact & vibration of model
• Max Discharge Continuous - 2C
Look at the discharge rates and you will see one of the main differences.
David
DavidH is offline        Reply With Quote
Old 10-13-2007, 01:54 AM   #3
hookmaker
David, -thanks for your answer.
Now, I have never gone to "battery school" so please tell me:
1) Is this more a sub for "flight" Li-poly battteries (as in T-Rex 450 etc.) and/or
2) Will I gain significantly by using the Li-Ma battery as Rx battery on a nitro machine over a Li-Ion Rx battery?
KR/Henrik
Hookmaker
Old 10-13-2007, 07:28 AM   #4
DavidH
KR/Henrik
Li-Mag does not have the discharge rate of Li-Po I don't believe. So really not a sub for that application I don't believe.
As for using the Li-Mag over Li-Ion as a receiver battery. If your electronics is a high amp current draw setup then yes I would suggest the Li-Mag. For example if all your servos use a lot of power and draw a lot of current. Then I would suggest them, for a 30 or 50 size you would probably be OK with Li-Ion.
David
Old 10-13-2007, 10:09 AM   #5
spork
Your post above says: Highest Discharge - 20c continuous with 40c bursts
That seems as good as some of the better LiPo's. I was (am?) very encouraged by that statement. I was wondering though about the weight of these cells. Any info?
Nothing is ever as good or as bad as it seems.
spork is offline        Reply With Quote
Old 10-13-2007, 11:30 AM   #6
hookmaker
Thanks Dave - got it!
/henrik
Hookmaker
Old 10-16-2007, 03:19 PM   #7
Ah Clem
I just started using one, so I can report back my findings in a couple of weeks.
So far, I have just charged it with my Duralite charger. I flew five flights today with my new Knight 50 (8317's on cyclic, 9256 on tail, 9254 on throttle w/governor).
So far, so good. Watching the way the voltmeter was reading with each flight, I probably could have flown another five times with no problem.
Again, I will post again as I know more.
Old 03-29-2008, 08:16 PM   #8
Mike Early
What gives? Wave of the future?
Mike Early is offline        Reply With Quote
Old 07-28-2008, 02:04 PM   #9
whisperdancer
The LiMn sure are heavier than an almost equivalent 20C Lipo.
If I take the FlightPower Evolite 2100mAh v2 (20C), compared to the 20c 2200mAh LiMn, the later weights almost 100gr more!!!
whisperdancer is offline        Reply With Quote
