Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters
Walkera Helicopters Walkera Helicopter Support
Old 12-20-2012, 02:08 PM   #1
shawnr1
Default Walkera V450D03 tx settings
Need some help with tx settings for DEVO-10. So far, I'm happy with the factory settings. It starts to spin up at 0% throttle. I would like to fix this, but not sure what settings is best. I want to start with beginner settings. Any advice?
shawnr1 is offline        Reply With Quote
Old 12-22-2012, 07:31 PM   #2
shawnr1
Anybody?
Old 12-22-2012, 10:10 PM   #3
shawnr1
My throttle curve value for normal normal throttle:
PL = 0.0%
P1 = INH
P2 - INH
PM = 50%
P3 = INH
P4 = INH
PH = 100.0%
Old 12-23-2012, 10:40 AM   #4
CX2Pilot
I sent shawnr1 a PM and said to make sure the throttle trim was all the way down
and to check that the throttle curve value was set to "0" on PL.
Shawn, also check the throttle sub trim and make sure it is set to "0".
And check that the left and right trim switches next to "Gear" and Mix" are centered.
Click them "+" and "-" and listen to the beeps. You will hear a high beep when you reach center
position.
I would also do a Stick Calibration which is in the Main Menu - System Menu.
Your throttle stick may be off Calibration.
Other than what I have posted I can't see any Tx setting that would cause it to start to spin up at 0% throttle.
There is a throttle bug in the firmware for the V120D02SV2 that would not allow the blades
to stop spinning after hitting throttle hold. This bug has been fixed in a new firmware release.
Your heli may have a throttle bug also.
I just checked with Walkera and there is no firmware update for the V450D03.
I would see if anyone who has the V450D03 has the same problem you are having also.
If so let me know and I will inform Walkera about this.
Tom
CX2Pilot is offline        Reply With Quote
Old 12-23-2012, 01:43 PM   #5
vronny
position.
Tom
My V450D03 would spin when spooling down at zero throttle but changed my settings so no more problems.
vronny is offline        Reply With Quote
Old 12-23-2012, 02:19 PM   #6
shawnr1
Mind posting what you change your settings to?
Old 12-23-2012, 08:22 PM   #7
vronny
Whats wrong with your stock setting mine not beginner settings. Really they work better for my style of flying. I use alot of neg expo on tail rudd. p.s. I have a Devo8S tx.
Old 12-23-2012, 08:51 PM   #8
shawnr1
Whats wrong with your stock settings.
It spins up at 0% throttle and with throttle hold. Have you experience this with yours?
Old 12-24-2012, 12:57 AM   #9
vronny
Not at startup did you setup throttle hold? It needs to activate for that heli. All the trim set to zero on tx, Once I started up to fly it would keep spinning when I would come back to land from flying.
Old 12-24-2012, 08:15 AM   #10
CX2Pilot
Throttle hold on the Devo 10.
Throttle Hold - Hold Status- Active
Hold Position = 0.0 %
You can also try Hold Position = -15% if the blades still spin.
Tom
Old 12-25-2012, 01:26 AM   #11
jakozzz
I just found this... Hope it helps....
Originally Posted by Hexperience View Post
Got mine from ehirobo, it arrived two days ago, but just got to hover it tonight in the lunch room at the office. I use deViation firmware on my 8s and it took all of 2 minutes to get the basic settings in and hovering. 100% everything, no expo, no d/r, straight throttle. All I did was set the pitch curve to -15%,0,+70%, set the throttle hold switch, set gyro to 60%
Lifted off very nicely after it go up to speed. But it went through a big vibe to get there. And did the same after landing. really got the shakes for a fraction of a second as it was spinning down. (At about 500 rpm). I would think that is the blades out of balance? But at normal head speed its vibe free and very stable. Can't wait for a clear day...!!!!
This will be fun, pretty inexpensive to buy.... happy camper
jakozzz is offline        Reply With Quote
Old 12-25-2012, 10:43 PM   #12
shawnr1
Thanks for all the replies. I love this heli. Had a chance to take it outside today and hover it for a minute. It is very stable. The -15% hold position worked. However, it still spins at 0% throttle, which I can let go for now.
If anyone else come up with some more info on this heli please post.
Thx!
Old 12-25-2012, 11:47 PM   #13
jakozzz
THis is how you do the big helis... Might work for this model...
Go into the Travel Adjustment menu and set high and low to 25%
Remove blades.....
Plug in heli...
Throttle stick all the way in up position....
Set high travel adjustment until it beeps and then go a couple of more (might go over 100%)...
Throttle stick all the way down...
Set low travel adjustment until it beeps and then go a couple of more (might go over 100%)......
Unplug heli
Turn off transmitter
Plug in heli
Turn on TX with throttle in lowest position
Try this and let me know....
Old 12-26-2012, 12:07 AM   #14
jakozzz
Another thing to try is select a new model and start from scratch (DO NOT copy old settings) and program according to manual... Here is the link....
http://walkera.com/cn/upload/explain/V450D03_expe.pdf
Old 01-08-2013, 09:09 PM   #15
Blackhawk Crew
That link doesn't work for the manual. Anyone else have a link to the PDF format of the manual?
Blackhawk Crew is offline        Reply With Quote
Old 01-08-2013, 10:02 PM   #16
shawnr1
Try this link: http://www.devention.com:82/cn/uploa...50D03_expe.pdf
Old 01-19-2013, 08:58 PM   #17
Blackhawk Crew
Negative...that doesn't work either.
Old 01-19-2013, 09:44 PM   #18
Ghostrydyr
sounds like the esc needs to be recalibrated to know where throttle 0, you probably did a bind while the throttle was a hair up and now it thinks thats 0 throttle.
Ghostrydyr is offline        Reply With Quote
Old 02-28-2013, 04:09 AM   #19
rcfascination
I also have the DEVO-10 and the main blade still spin at 0 throttle.
Has anybody come up with any other ideas?
Oh by the way first time posting on this forum
rcfascination is offline        Reply With Quote
Old 02-28-2013, 06:41 AM   #20
vronny
In TH try - number like -10
