Go Back   HeliFreak > R/C Electronics Support > Flybarless Helicopter Systems > AP and Scale
AP and Scale Discussions for Scale, Multi-blade and AP applications using CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix, Digimix-3.
Old 10-14-2007, 08:02 PM   #1
architorture
Default AP2000i w/ camera control?
I am wondering if the AP2000 system is stable enough to operate a second controller for the camera while the heli hovers in hold mode.
I have a DX7 that I was planning on using for flight control and was thinking of getting a DX6 for pan/ rotate/ tilt/ trigger on the cam mount. I would rather not have to rely on a second person to frame the shot, is anyone doing a single person, full control camera system? I was thinking of mounting both controllers on a tray so I can be close to the flight controls if I have to make adjustments. Can anyone provide any feedback on this?
architorture is offline        Reply With Quote
Old 10-15-2007, 02:54 AM   #2
Tonystott
That's what the AP2000i is all about. It will provide enough stability to enable the momentary distraction of taking the picture. Of course, many people prefer to work a two-person team, and for video, the benefit of a separate camera operator increase even more.
Tony Stott
Trex 450 XL,JGF450TH,GY240 500e fuse, and Hubdave CF frame, JGF450TH,GY401, A109 fuse
1/4 scale hot-air balloon and Rokkaku/Sutton FF16 kites, Brooxes KAP rig, Olympus SP350s
13m Spiderbeam mast, Askman mount, A640, all above with 2.4Ghz downlink
Tonystott is offline        Reply With Quote
Old 10-15-2007, 09:44 AM   #3
jrohland
Default There may be more to it
As I understand it, the AP2000i provides CCPM mixing and sensor processing. In and of itself, it does not stabilize the ship.
Stability comes from the various sensors attached. Such as:
Elevator and aeliron gyros. IR (horizon line) sensors, GPS, accelerometer, etc...
How stationary your heli will stay is a function of the sensors you have attached. Gyros will not keep the heli in place at all. Horizon line sensors will try to keep the heli level but, have no way to counter wind. Accelerometers can try to counter movement in any direction but, overtime the heli will still drift. GPS will try to keep it within their distance resolution. GPS with WAAS (Wide Area Augmentation System) may be slightly more accurate.
Bottom line is, if you can afford to have it drift around within a large area, with a combination of sensors, you can get 'good enough' stability. Still, I would tend to recommend at least a spotter to keep an eye on the heli and nearby hazards.
jrohland
jrohland is offline        Reply With Quote
Old 10-15-2007, 08:23 PM   #4
architorture
I guess I was just wondering how stable it keeps the heli. Stable enough to take my hands off the controls to frame up a shot with another TX? I'm also thinking about going flybarless with the AP2000i and 2 additional gyros. So with the 2 gyros and IR sensor am I pretty good to go? I'm not talking staying absolutely in place in 20 mph winds, just in a rough location to get the shot. Where can I find GPS RX for the AP2000?
Old 10-15-2007, 09:00 PM   #5
Tonystott
Stable enough to frame a shot? Yup! However, I think you have misunderstood the flybarless/2 gyro "option". It is my understanding that the benefits of flybarless +2 gyros relate to improved drivetrain efficiency compared to a flybar-equipped heli, but this is not directly linked to the ability of the heli to remain stationary enough for framing shots.
Mark Webber has direct experience of thie combination of AP2000i and flybarless+gyros, and will no doubt be along shortly
Tony Stott
Old 10-16-2007, 12:06 PM   #6
architorture
I understand that the flybarless gyros will not keep the heli in place, but I thought they could be configured to HH mode, so they will maintain their orientation (pitch and roll) better than a flybar heli would. I do mainly want flybarless for the additional efficiency and simplicity though.
Old 10-16-2007, 06:36 PM   #7
MarkWebber
HH mode and the IR stabilization are at odds with eachother as the AP2000i is configured now. Independantly, they work well. The problem is this: In HH mode, the gyros will fight to overcome the AP2000i's attempts to right the heli. In rate mode, it will work just as if you had a flybar installed. As a matter of fact, I could discern no difference in flight characteristics when the 401's were in rate over having the flybar installed.
HH is a whole different feeling. No bad but different.
As far as efficiency, I'm not sure how much you'll really gain. The gyros did seem to consume quite a bit more of my rx battery than before the conversion.
If it's stricktly for AP, I'd stick with the AP2000i w/IR stabilization.
The reason I wanted to convert was for testing for 3D purposes and to correct an issue I was having with my gasser in the wind. Heavy flybar weights solved the gasser issue.
Mark Webber
wai-rc.com
MarkWebber is offline        Reply With Quote
Old 10-16-2007, 07:33 PM   #8
architorture
Thanks. Thats is what I need to know. I will just go with the AP2000i.
Old 09-22-2008, 10:43 PM   #9
hueyheli
Hi, the AP2000i together with IR sensor , they work very well ,when emergency situation all you need to do is : let the stick go back to center... AP 2000i will level your heli fast and safety... I used on my scale HUEY , Good luck.
hueyheli is offline        Reply With Quote
Old 12-07-2008, 12:58 AM   #10
charosenz
Default where did you put the sensor?
Hey Hueyheli,
Where did you put the IR sensor? Do you have any pics?
Charosenz
charosenz is offline        Reply With Quote
Old 12-31-2008, 03:59 PM   #11
aaaahma
excuse me hueyheli, can you describe in details what is requirement for flybarless plus ap especially by using ap2000i? I plan to install one on my heli. I heard its required another 2 gyros. Is that correct?
thanks in advance
aaaahma is offline        Reply With Quote
Old 01-01-2009, 06:50 AM   #12
MarkWebber
To use the AP2000i for stabilization and flybarless, you will need both the IR sensor and 2 gyros for cyclic. They need not be expensive gyros like you would want for the tail as the cyclic is less demanding of a top quality gyro.
The gyros must be connected between the rx and AP2000i, especially in a eCCPM heli. This also give you easy adjustment of rotor phasing in the AP2000i programming.
Mark Webber
wai-rc.com
Old 10-23-2010, 10:50 AM   #13
ed.ge
Hello
Was reading a lot of threads about the AP2000i now and still got one question left:
But some infos beforehand:
I am using it in an Octocopter - and it works quite awesome in terms of leveling the aircraft at any time out. What also works quite good is, it keeps the aircraft away from (big) obstacles, like trees, walls, etc...It does not (most of the time) keep the aircraft away from a person. Sometimes that works too - must have to do with the sensor direction/range.
Of course there is a fight between AP2000i and the aircraft gyro - but only when at around 70% and if you try to steer it. Let it alone and it works fine!
Reading through here and there it seems, that to counterfight wind / and to stay put in place it needs another sensor? Is that right and if yes - which one would you recommend / how to set it up?
Thanks in advance
It's a great product anyways!
ed.ge is offline        Reply With Quote
Old 10-24-2010, 07:13 AM   #14
MarkWebber
There isn't anything available to work as a position hold for the AP2000i.
Mark Webber
wai-rc.com
Old 10-24-2010, 10:51 AM   #15
ed.ge
Ok - it is how it is Not too bad anyways.
Today I programmed a mixer that lowers the gyro-gain when the gain for the Ap2000i goes up. The funny thing is, that when the aircraft gyro gain is very low, the Ap2000i tries very hard to push into one direction. I calibrated it in about 10Meters height and also beforehand on a big field. There were no obstacles in the way. --> ?
On the other hand I let it fly towards thick-standing trees and it won't push away from them. When trying the functions with my hand (sensor in front of hand) everything works perfectly.
Is there anything I missed? Are weather conditions important? Today there was overcast sky, no sun.
EDIT: Just found on the net, that overcast sky may decrease the performance. Ok and again - that's how it is )
Thanks in advance. It's really a great product, would be a shame to not use its full potential.
Old 10-24-2010, 03:02 PM   #16
MarkWebber
I agree
Mark Webber
wai-rc.com
