Old 10-17-2007, 11:49 PM   #1
ratorfreak
Angry Align RCE-G00 Governor
I purchased a couple day agos the new Governor by align, I recieved it today and installed it. Can someone tell me if there is a place I can see how to set it up properly.
My Addictions:_Electric Stuff-
AlignTREX 600E XL1650 Servo's Align TREXSE 3700KV Align TREX450 1550KV -Nitro Stuff- Align TREX 600N Hyper50 Servo's 8717's MultiGov 2.0 Raptor 90 YS TJPro Raptor 50 Titan Hyper50 GV1
and 2 Raptor 50 Standard Raptor Stuff
This is an addiction.
ratorfreak is offline        Reply With Quote
Old 10-18-2007, 11:56 AM   #2
jgeorgic
Hope this helps..............
http://www.align.com.tw/html/en/asse...50h0509_en.htm
rcbooya.com
jgeorgic is offline        Reply With Quote
Old 10-19-2007, 08:44 PM   #3
ratorfreak
Thanks for the reply.. I should have been more clear. But what I need to know is there a way to setup 2 different stunt modes.. Normal mode I want to run 1750rpms, idle1 1850rpms and idle2 2000rpms. My radio is a dx7. The initial setup was a snap.
Old 10-19-2007, 09:38 PM   #4
george0079
If I understand this right, you should be able to set it up just like a TJ Pro.
http://www.modelavionics.com/ And click on radio tip (bottom left)
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote
Old 10-19-2007, 10:02 PM   #5
cowboychris
Check out "Finless'" video series on the Trex 600N video. He shows how to do this exact thing on the DX7 with the Curtis Youngblood governor. I am sure the setup procedure will be the same.
cowboychris is online now        Reply With Quote
Old 10-19-2007, 11:12 PM   #6
tungym
Wink
Young blood and G600 is not the same. ATG has additional features of light indicating the desired rpm. Thought he initial ATV setup should be the same.
I wonder if JR 9X and DX7 share the same ATV, since the Align G600 manual states than JR 9x ATv setting of 100% will give desire rpm of 2200. Too lazy to tach the rpm, mike.
In additon, I was told that G600 has the "same" design as the raptor governor.
tungym is offline        Reply With Quote
Old 10-20-2007, 01:45 AM   #7
ratorfreak
Cool G600 Replies!
Thanks again for all the help and advice. I've setup the GV1 and I have the TJPro on another bird. I am going to try the TJPro setup for the additional rpm's http://www.modelavionics.com/Jockey/...rum%20DX7.html. I found this very helpful when I started programming the TJPro. I was just looking for a specific confirmation on how to do this with the G600. Let me tell you its great thing not to be out here alone with this stuff. If the setups work I will post my results.
HouseMD
GOD Rules!
Old 10-20-2007, 01:26 PM   #8
Finless
Team Taco VP
HouseMD
GOD Rules!
Very similar setup that I show in my video for getting 3 RPMs out of the ATG and a DX7! There is more than one way to skin a cat and use mixes
Bob
Old 10-21-2007, 04:16 AM   #9
ratorfreak
Bob your video's are very helpful. Thanks again.
Old 10-21-2007, 05:26 AM   #10
tungym
Talking
Right, Finless's video worth thousands words.
It would be great if someone can share their experience with a successful setup of Align G600 with DX7.
But one dummy question. How can one tell the exact rpm? Is a tach necessary?
Old 10-21-2007, 11:44 AM   #11
george0079
Yes, you will need a tach to check rpm. A tach should be part of every heli pilots field kit IMHO.
