Go Back   HeliFreak > Multi Rotor Support > Props-Duration, Performance, Stability
Props-Duration, Performance, Stability Props-Duration, Performance, Stability
Old 01-07-2013, 08:32 AM   #1
ZIMMY1958
Default new dji 1038 props
has anybody tried the new dji 1038 props yet? they stomped on them and did not break and took high rpm to
Just have fun
ZIMMY1958 is offline        Reply With Quote
Old 01-25-2013, 04:28 PM   #2
ZIMMY1958
anybody?
Just have fun
Old 01-26-2013, 03:17 AM   #3
TheHeliDude
Sorry didn't notice this thread but posted about these on another thread. I'd just like to post a link to it here in case people are searching for these props specifically:
http://www.helifreak.com/showthread.php?t=493134
Give them a try ZIMMY1958. They flew great for me (1 flight so far).
nqx, mcpx, mcpx BL, 130X, trex 250 pro DFC iKon, 450X, TBS Discovery, Trex 500 DFC iKon, dx9
TheHeliDude is offline        Reply With Quote
Old 01-26-2013, 06:25 AM   #4
ZIMMY1958
hope they turn out to last ( not explode ) like the video implies. if so they should be a good ( cheap & efficient ) prop at 1/3 the price of graunpers.
http://www.uavproducts.com/category.php?id_category=15
good place to get DJI and other stuff
thanks for all input
Just have fun
Old 01-26-2013, 11:10 AM   #5
lowflyer101
got some on the way, will try it on 450 , 3s.
lowflyer101 is offline        Reply With Quote
Old 02-09-2013, 10:24 PM   #6
Altimat
Got some and they look good to me. Now how do I get them mounted on a 6mm shaft with that flat spot in there?
700E V2 LHS, MX800 440KV, 12S Glacier, DX8/HC-3SX/120HV ESWLFSE on RR
Altimat is offline        Reply With Quote
Old 02-09-2013, 10:38 PM   #7
TheHeliDude
If 6mm is the stock dji motor diameter, I had to push really hard on 2 of my props to get them into place. Had to push way harder than I thought so I just lined up the notch and did it carefully by pushing on the center ring and not the prop part.
I flew today with these and still flying good and getting good video.
Old 02-09-2013, 10:40 PM   #8
Altimat
Sorry I should have said I have non-DJI motors with 6mm shafts. These are 8mm with flats inside.
Old 02-09-2013, 10:47 PM   #9
ZIMMY1958
well I ordered 2 sets for back ups for my graupners but may try them sooner to see if it changes the flight any
Just have fun
Old 02-09-2013, 10:50 PM   #10
ZIMMY1958
you should be able to find adapters for different size shafts I think gemfan and others come with them and file a flat on them
Just have fun
Old 02-09-2013, 11:20 PM   #11
Altimat
I didn't think of filing a flat on them. And my shafts are actually 5mm not 6mm. I ordered some 8>5mm adapters and a 8mm prop reamer to clean out the flats.
Looking forward to trying these!!
Old 02-10-2013, 12:12 AM   #12
corona007
Got some...
Wooohoo....
corona007 is offline        Reply With Quote
Old 02-10-2013, 11:04 AM   #13
saitoflyer
where can I get some of these props?? how does it compared to graupners? Igot some 9x5 on my 450 quad running 4S and my jello went away.. I had it on my discovery frame which may be good for FPV but for filming, too much jello. I gave up spendning several hrs, and $50 just on some foam pads/moon gel etc..
hello there!
saitoflyer is offline        Reply With Quote
Old 02-11-2013, 02:10 AM   #14
Altimat
You can get the props here. For jello look into this possible fix. I bought this ND filter just today because I can't fit the 55mm on my setup.
Old 02-11-2013, 01:16 PM   #15
dfruehwald
I just got a F450 kit from Heliproz.
Is there a visible difference betwen the old and the new?
I'd like to know before I take it out flying.
dfruehwald is offline        Reply With Quote
Old 02-12-2013, 08:55 AM   #16
02deuce
Default Blades
I don't believe the kits have the new blades in them yet, at least mine didn't (last week).
Old blade on top. New blade on bottom.
Trex 700N, 700E, 600E, 500E all Vbar 5.2 Pro FBL
Dji F550 WKM Data Link 900MHZ
DJI F450 Naza/GPS FPV 5.8 vtx
TBS Disco w Core Naza GPS FPV 1.2 vtx MT Tiger motors
02deuce is offline        Reply With Quote
Old 02-12-2013, 12:00 PM   #17
dfruehwald
Thanks. Mine look like the old ones in your photo.
Guess I'd better hunt down some new ones while I'm waiting on my KK2 controller to arrive. I can use the old ones to make sure I have all the motors setup right for now.
BTW - Where did you get your new ones from? I've been reading there are some bad clones of those and the Gemfam props people recommend.
Old 02-19-2013, 08:40 PM   #18
kidrice
Default Anyone?
Any flight experiences with these new 1038s?
kidrice is offline        Reply With Quote
Old 02-19-2013, 10:33 PM   #19
corona007
I don't like them. they have a lot less pitch to them than the older one.
I didn't realize that the name 1038 actually means 10" propeller with 3.8 pitch.
I like the old pitch way better, 10" 4.5 pitch. A lot more punch.
Oh well, Live and learn. Funny I flew planes for over 20 years and already knew this.
But I guess it didn't sink in.
I feel stupid now.
Wooohoo....
Old 02-20-2013, 06:51 AM   #20
quantumstate
3.8 pitch should be fine for light lift--a direct mounted GoPro and nothing else. I wouldn't use them on a setup much heavier than that.
I just ordered some of the 1038's myself and I have high hopes for them. I think with DJI wanting to improve their reputation after their last props, these new props will probably be made very well--better than many other brands out there. But that's just my guess.
quantumstate is offline        Reply With Quote
