Old 10-22-2007, 09:29 AM   #1
Mathias
Default Align 35A Brushless ESC RCE-BL35X - Governor mode
Hi!
Do you hardore 3D guys use the governor mode on your Align 35A Brushless ESC RCE-BL35X on your T-Rex 450's? Yes I am of course interested in other's opinion, but I want to now what the people who flies hard 3D mean.
Mathias is offline        Reply With Quote
Old 10-22-2007, 09:37 AM   #2
HeliSmith
I am an upcoming hardcore 3D pilot. I run governor mode exclusively on CP helis. Most guys I see out there do not but honestly I didn't care what others were doing. I studied both options and made my decission.
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail)
Proud Field Representative for the following
HeliSmith is offline        Reply With Quote
Old 10-22-2007, 09:52 AM   #3
CompuFoil
I'm definitely not a hard core 3D guy, but I stared using gov mode. I like the consistence in head speed that I get. The one drawback I saw was when accidentally hit the throttle hold switch. Luckily, I was only about three feet up, but if I was higher, I would have been forced to auto before I was setup for it.
Eric
GAUI500, V30, Full Metal,9254/401+T600Tail, 500mmCarbons
TRex 450SEV2:HS65MG,3400G+DS760, Neu1107/1.5+11T, JAZZ40
Blade CP, ,RotoFly FP, Blade CX,
Other Blingers:
Deering Golden Era Banjo
LG100ZM competition air rifle w/20-50x60 scope (
Mathews SwitchbackXT Bow
CompuFoil is offline        Reply With Quote
Old 10-22-2007, 10:04 AM   #4
Mathias
So you can't shoot a auto if you are running gov mode.
If a have understood it right, you haven't a throttlecurve when using governor mode. Is that true?
I am now running 13T and throttlecurve 100-100-100-100-100 with the 430XL motor.
Old 10-22-2007, 10:50 AM   #5
HeliSmith
You can do an auto with gov mode but don't expect a restart midair if you get the approach wrong. Also if you forget to hit throttle up in gov mode and you bring the stick down you have 0% chance of getting the motor started before you hit the ground. :p
You have a throttle curve flat usually 75% if you are geared right in gov mode.
Alot of guys run straight 100% in non governor mode with the 430XL. I like the consitent head speed too so I chose gov mode.
Old 10-22-2007, 12:33 PM   #6
wbplomp
Question
I'm having the same question.
Ok... are you saying govener mode workt good with the stock Align RCE-BL35X ???
Boudewijn
wbplomp is offline        Reply With Quote
Old 10-22-2007, 01:39 PM   #7
HeliSmith
I only used my Align ESC for about a week. It worked fine in gov mode.
I just like Castle Creations ESC so I shelved my Align ESC for backup.
Old 10-22-2007, 01:57 PM   #8
Mathias
OK, thanks for answering. I have worked up my 3D skills in the last time. TicToc's, inverted hovering, flips and so on. That was why I was asking.
I think I will stick with the flat 100 curve and 13T pinion. If you can fly hard 3D with it, so...
I am still interested in more opinion's.
Old 10-22-2007, 02:10 PM   #9
CompuFoil
I may have misworded my answer. You can do autos in gov mode, it's just that once you hit throttle hold, you're not going to be able to take it out of TH and get any head speed to save an aborted auto. It takes a while to spool up, (which can be changed to spool up quick, but not safe).
Eric
Other Blingers:
Old 10-22-2007, 03:04 PM   #10
Mathias
Yep, I understand it.
Old 10-22-2007, 03:51 PM   #11
Rob Hair
I am nowhere near doing 3D stuff, but I switched from governor mode to non governor mode with my Align ESC.
See:
http://www.rcgroups.com/forums/showthread.php?t=739772
Another thing that bothered me about the Align ESC gov. mode is that it would recompute the governed speed if I brought the throttle to zero then brought it back up, as one would do when landing and taking off again (without removing power).
Rob Hair is offline        Reply With Quote
Old 10-23-2007, 02:39 AM   #12
Finless
Team Taco VP
You guys running gov WONT get the most out of your Trex with GOV mode on the Align ESC! If thats OK then fine enjoy it..... I aint trying to brag but in this training vid I did if you cant get this kind of performance (this is ALL Align stock stuff) then consider what I am saying.
http://video.helifreak.com/?subpath=...loopsrolls.wmv
Bob
"Don't Taco My Pack Dude!"
Old 10-23-2007, 08:14 AM   #13
Mathias
Can I use the 325 PRO Woodies on 13T and flat 100 curve with the 430XL motor?
Old 10-23-2007, 10:32 AM   #14
CompuFoil
Bob,
How about gov mode with the CC35?
Other Blingers:
Old 10-23-2007, 04:02 PM   #15
Finless
Team Taco VP
I havent tried a CC yet on a 450..... i probably should try it.
Bob
Old 10-24-2007, 08:00 AM   #16
Mathias
Anyone? What is the RPM limit for the 325 PRO Woodies?
Mathias
Mikado Logo 700 Xxtreme | JR XG8 & Spektrum DX8
Old 10-24-2007, 08:58 AM   #17
Street Flyer
If you were to do that you would probably swing 3300-3500rpm. That is considered to be pushing the limits on the wood blades(people don't like to run woodies past 3000rpm) . I would recommend getting the Align 325 carbon fibers (not the black ones that came with the V1 SE. The ones That come with the V2.) I use them and love them. They have a great airfoil on them which causes less bog. I'm pretty sure you would like them with your 430XL,13T, 100-100-100-100-100 throttle curve.
t-rex xl cde
t-rex se V2 with scorpion -8
t-rex 600n
t-rex 700n
Street Flyer is offline        Reply With Quote
Old 10-27-2007, 09:17 AM   #18
Mathias
I have the Radix 325's but I haven't put them on yet.
Mathias
Old 10-27-2007, 09:42 AM   #19
[]TEX[]
I have had excellent results running in gov mode over standard. I find the 35A to me more responsive in throttle changes and during 3D in gov mode compaired to setting a curve.
I am not sure setting 100 across the board is a good idea since the head will spool up higher when transitioning throught the zero pitch range. You can definitely hear it do this.
I run a 14T with MAH carbons and it's balls out on my T-Rex at 85% in stunt mode.
I run 75% in normal mode.
I get the same flight times either way, but gov mode gives me better flight.
[]TEX[] is offline        Reply With Quote
