Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Old 01-15-2013, 10:24 AM   #1
PKNEC
Default multi port charging or parallel
After reading many threads on charging the general opinion that I have come to understand is that parallel charging while very effective at getting multiple packs charged is not very good at addressing individual pack needs as the process only looks at the lowest discharged pack and treats it as one big capacity.
I hope I have understood this correctly,please advise.
So if individual charging is better for pack care why is it most flyers seem to go with parallel?
I am just trying to understand the pro's and con's of both setups in more detail to see whether it would be worth getting a couple of multiport chargers rather than the battery workstations pl6, 306b etc.
The remit for all this is, I plan to be charging multiple 6s packs of between 2600-3000 mah between 1 and 2c
Any advice greatly appreciated
PKNEC is offline        Reply With Quote
Old 01-15-2013, 01:19 PM   #2
bstanley72
Parallel charging isn’t necessarily good or bad for pack care. When you hook multiple batteries together in parallel power will flow between them until their voltage is equal. So once you start the charge process the packs will all have the same voltage. You want to make sure their voltage is similar before you hook them together or you could damage them.
Most parallel charge because it is so easy and convenient. I have a dual port charger (iCharger 4010). I parallel charge my six 6s batteries for my 500 while charging my six 3s batteries for my quad (6s on one port, 3s on the other). I run them at a 1C charge rate (which is nice and easy on the packs) and they are all done in about 35 minutes. Imagine if you tried to do all of those one at a time (you’re looking at close to eight hours).
I always check the voltage of each battery before I plug them up, the individual cell voltages are always within a 100th of a volt if each other and I’ve been parallel charging for over a year. I don’t think it is necessary but for piece of mind I will occasionally storage charge the packs individually so I know each cell within the pack is balanced.
As long as you make sure the voltages are similar between batteries before you hook them up and you only parallel charge batteries that have a similar number of cycles on them, you will not harm or degrade the batteries in any measurable way.
Edit: Here is a good site about parallel charging: https://sites.google.com/site/tjingu...allel-charging
FLIP Quad with Eagle Tree Vector (still in the box), DJI 450 Flame Wheel, Bunch of Planks, DX8, over-inflated sense of self worth!
Helis I've had: Trex 500, Compass 500, MCPX, Nano CPX
bstanley72 is offline        Reply With Quote
Old 01-15-2013, 07:26 PM   #3
PKNEC
Thanks for the advice bstanley72
Old 01-15-2013, 07:42 PM   #4
Slyster
Best of both worlds.... the new iCharger 4010B. Two ports and high output. 40A for both or 70A for one. Grab a couple of sets of parallel cables.. and you will have a lot of charging flexibility.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 01-20-2013, 09:31 PM   #5
josecr
Hi guys
I was wondering...can you storage charge or discharge in parallel too? I storage charge or discharge them one at a time when I get home afger flying and doing this one by one takes ages sometimes
Jo
Learning each step of the way in the R/C heli world!!!
Phoenix V4
Futaba T7C
T-rex 450Pro DFC w/ 3GX v3.0
josecr is offline        Reply With Quote
Old 01-20-2013, 10:34 PM   #6
Slyster
you can.. it will just take ages x the number of lipos.
Instead of using the charger I use one car headlamp for 3s packs and two car headlamps in series for 6s.
Old 01-21-2013, 09:02 PM   #7
heliman86
Default Re: multi port charging or parallel
Sent from my galaxy s
Ok not trying to jack thread but what does watts have to do with charging I finaly figured out the ...c rate lol now only the watts confuse me
S.A.D Society of Air craft Destroyers...aircraftus destructacus
heliman86 is online now        Reply With Quote
