Go Back   HeliFreak > Multi Rotor Support > DJI Multirotor Support > Flamewheel Multirotor Support
Flamewheel Multirotor Support Flamewheel Multirotor Support
Old 01-20-2013, 03:24 PM   #1
daneger21
Default F450 Naza GPS help
I just got an f450 with naza from another member on here, before i even put it in the air i ordered the gps upgrade and installed it also. Ive completed the gps calibration with no errors, and get a slow green flashing led while in gps mode, which tells me i have good/enough satellite connections.
Heres what ive been doing, i get it to hover around 6' while in in ATT mode, then switch to GPS mode(i see the led change to slow green), center the throttle stick(if its not already there) and then release right stick. Then it just drifts away and i pretty much have to continue to fly it like i would in ATT mode.
Any ideas?
Thanks!
No I didn't misspell Daneger, my name is Dane..get it?
"Flyin' high again..." -Ozzy Osbourne
daneger21 is offline        Reply With Quote
Old 01-20-2013, 04:17 PM   #2
psylence519
How far have you let it drift? It's not millimeter precision, it won't stick exactly where you stop, sometimes it will drift into its closest location and settle in.
Also, I assume you've set the correct x/y/z distances in the Naza setup for the GPS?
psylence519 is offline        Reply With Quote
Old 01-20-2013, 04:24 PM   #3
JGrn
Have you calibrated the gps/compass outside away from anything magnetic?
JGrn is offline        Reply With Quote
Old 01-20-2013, 04:49 PM   #4
daneger21
Im talkin like 10'-15' drifting and it might keep going if not. I just noticed when i flip my switch into gps mode it dips forward and flys off and also slowly drifts left.
Calibration was done on my driveway. Closest thing would be my house and my pickup(about 15'), then powerlines. (25'+)
Old 01-20-2013, 05:15 PM   #5
JGrn
Is it drifting in a large circle? Going round and round?
Old 01-20-2013, 05:33 PM   #6
daneger21
nope, flying "tail" in it dips forward elevator and flys off. This last time I just test flew it, it was about 20' from where i hit the gps button and it would have for sure kept going but i flew it back.
Old 01-20-2013, 05:41 PM   #7
JGrn
Sounds like the gps may be bad. Contact the retailer maybe ?
Old 01-20-2013, 06:08 PM   #8
Pozzix
Maybe do you have some subtrims on tx?
And then have you right calibrate gimbals course of your tx in assistant sw, such as in mid stick should have green line indicators?
Sent from my IPhone using Tapatalk
Pozzix is offline        Reply With Quote
Old 01-20-2013, 06:12 PM   #9
daneger21
I think i just noticed a possible issue. Ive noticed that the naza itself may be facing the wrong direction according to the software and the arm colors. Software shows red arms as "nose". And the naza motor(esc) ports are facing the whites. I wonder if the original owner had issues. I just assumed the red arm were the "nose" and thats how i mounted the gps since i added it myself. I didnt even think or noticed when i plugged in the gps module. I will change mounting settings and my reversing and recalibrate....
Old 01-20-2013, 06:14 PM   #10
daneger21
Nope no subtrims or trim.
My previous post i found a possible issue the way the previous owner mounted it. Hopefully it didnt mess anything up.
Old 01-20-2013, 06:27 PM   #11
nuttzzy
Ok the Naza MC the motor ports face forward also the arrow on the GPS faces forward. You have to make sure of this. I don't think it will be a COG issues as I've changed my orientation several time and never changed the distance of COG in the software. And mine still hovers fine and RTH works. I'm not talking barly changed the set up. I'm talking major changes. From hex to quad and different spot for GPS and MC still never changed my COG in the software and no issues. So I would make sure the mechanical part is right first. Front of Naza and GPS forward as per the software states. Wether your flying X or +
Beep, Beep, Honk, Honk, Over and Out Rotorhead
Any Landing you can walk away from, is a good landing...
nuttzzy is offline        Reply With Quote
Old 01-20-2013, 06:34 PM   #12
daneger21
I got this from another member and i noticed the naza mc is facing the wrong direction, facing white arms and not red(atleast according to the software as "front/nose"). Which meant when i installed the gps facing the "front/nose" it was actually facing the "rear/tail". I redid my software setup and numbers and got my reversing correct. Ill go outside in a bit and recalibrate the gps module.
Old 01-20-2013, 06:47 PM   #13
nuttzzy
Ok man. It doesn't have to be to the red arm. As long as they both face the same and software agrees and motors turn the right way as met orientation of the MC GPS and software. Basically all i said was color of arm doesn't matter lol.
Old 01-20-2013, 07:02 PM   #14
daneger21
I understand this. But im admitting I didnt look or check, and i just assumed...
Old 01-20-2013, 07:20 PM   #15
daneger21
Just got back in from a test fly after correcting the gps arrow direction. Add also the mounting measurements in the software accordingly for that correction. I assumed the red arms were forward from references in the software, but the previous owner had it setup as white being the nose. My mistake for not noticing. I also had to switch back some reversing on elev and ailer channels in my tx since the orientation is not opposite. This is my first quad and figuring things out.
But after the test fly shes working great now! I didnt test the failsafe because it is dark out right now lol
Thanks guys for helping me weed out issues until i found; ME pretty much being the issue!
Old 01-20-2013, 07:31 PM   #16
psylence519
Awesome, always good when it's a simple problem!
X5 / Goblin 500 / Goblin 700
Old 01-20-2013, 09:03 PM   #17
nuttzzy
No problem man I was same way. Still am!! I'm still knew to quads. Just know a bit. Glad it worked its mostly simple stuff most the time. Get the flight worked out then worry bout fail safe. That's what I did now working on course modes and OSD..
